still the point is a decent good GPU can handle multiple 4K HDR transcoding the issue relys with plex to do it right , if you do some research you will see that even consumer version can do it fast enough but problem is how pms handling it. and btw nvidia shield can handle it (as a server) so you think a new gaming pc can’t ?
4k HDR to 1080p or anything it should be within grasp with most users with recent gpu and 2 streams, till you get quadro to unlock that number.
PS: a rough ETA H.265 will need about double the performance of H.264.
lets say your server handle 7 streams of H.264 then it should handle 3 streams H.265 so little bit less than half. so again that means a recent gaming server should be perfectly capable of doing 4K HDR H.265 transcoding perfectly fine.
can check him comparing performance hits of H.265 vs H.264 and use the stubborn brain you got to ETA how much it will be in 4K performance + don’t forget that he is using old hardware and no Quadro p2000
and you can see sometimes its working for him sometimes its not , so the major problem is plex working probably as it should to transcode not the format, again once we get a reliable server that works as it should be under the fully claims of supported formats then we can proceed to argue with you about 4K HDR should be doable on majority of pms users or not. and btw you can get handbrake to test and see how fast you can do 4K HDR or another software to do it and find out that the problem is plex or not.
H265 or H264 isn’t the issue , HDR or SDR also is not the issue , and i gave you link to my post proof of that , plex isn’t stable as you think it is and its not working correctly with hardware transcoding which is what cozing the fuss and we cant even get a reliable tests or results to be able to discuss it with you.
in my link (post) you can see clearly that both are H.264 but still one is not even transcoding and stays buffering forever while the other works perfectly and very fast with very low amount of resources.
so forget H.265 or HDR
and am not alone the majority of plex users have issues with transcoding stuff that should be supported 100% by plex.
so when they get that fixed then we can talk about H.265 or H.264 and HDR issues bla bla …
but first you need to know that the car is broken before you decide to drive it towards whatever city you want to drive it.
so once plex is fixed then we can discuss how it impact performance and what can handle it but so far plex isn’t even optimized well for discrete gpu’s as well as internal one’s and have plenty of performance issues.
yes the i gpu UHD 630 perform better than GTX 1080 Ti both in single transcoding and in stability/compatibility in plex.
