Thank you so much for your help.
Any ideas about the console spam of unknown meta data on a fresh install?
No, sorry.
Its gathering the covers just fine for full speed , but the console gets spammed. Dont recall Iāve seen that before.
I do have some influence there
Iāll reach out and touch some folks ![]()
Iām chatting with the team now.
Independent of the libraries being 11 months old in the Docker container - Are there any functional issues ?
This test package should resolve the reference to the now-obsolete intel-ocloc.
No checks will be made if installed nor errors generated if not.
Please advise.
None that I know of.
If there were a known bug fixed between that initial version and now, updating the container would be easier to justify but ⦠I still have some powers of persuasion.
Feedback on the developerās package above ?
Hey,
So I ran into this issue as well.
I downloaded the package above from you and when I attempted to install it I go the following.
N: Download is performed unsandboxed as root as file '/root/plexmediaserver_1.24.5.5173-8dcc73a59_amd64.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
I deleted everything and attempted a second run and received a different error.
Not sure if its helpful or not.
Iām at work, Iāll check in a bit to see if it is running.
[LOL]
I couldnāt help it and looked. It does appear to be running.
Just updated to latest beta *** 1.25.0.5220*** but Intel OCLoc: Not Installed still is an issue?
PlexMediaServer install: PlexMediaServer-1.25.0.5220-de6e61df7 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Intel i915 Hardware: Found
PlexMediaServer install: Nvidia GPU card: Not Found
PlexMediaServer install: OpenCL: Installed
PlexMediaServer install: Intel Gmmlib: Installed
PlexMediaServer install: Intel IGC Core: Installed
PlexMediaServer install: Intel IGC OpenCL: Installed
PlexMediaServer install: Intel OpenCL: Installed
PlexMediaServer install: Intel OCLoc: Not Installed
PlexMediaServer install: Intel Zero GPU: Installed
PlexMediaServer install: WARNING: The Intel Ocloc library, required for Intel Compute Runtime support, is missing.
PlexMediaServer install: Please install package: 'intel-ocloc' from https://github.com/intel/compute-runtime/releases
PlexMediaServer install: Intel Compute Runtime packages are available from: https://github.com/intel/compute-runtime/releases
PlexMediaServer install: Please be certain to install them in the listed order.
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.25.0.5220-de6e61df7 - Installation successful. Errors: 0, Warnings: 1
Processing triggers for mime-support (3.64ubuntu1) ...
Also it seems that the transcoder should be fixed for 11gen - but there is no info regarding requirements of the linux kernel?
Well updated mine - Seems to run smooth
Even transcoding a 4K movie ( HDR ) to a LG OLED . HDR is enabled and registered by the TV
HDR Tonemapping is set to OFF and its working PERFECTLY
( SO FAR
Iām waiting for Engineering to include my previous update
In light of the transcoder updates, I now need to recheck everything. (This is the first Iām seeing the final release as well)
Thanks for the info
Im really pleased. Seems to work great so far.
I tried to do a transcode locally with a 4K HDR movie. I set the tv quality to 10mbps . Normally when transcoding 4K HDR content, HDR on the tv wont be enabled , but its working perfectly . The movie will typically transcode for me if I forget to change sound from 7.1 to 5.1 . I can instantly see that the tv wont run with HDR . Now its just running without any problems
I can also via the Intel tools gpu see that its actually using the GPU and not the CPU .
Awsome job - Huge Thanks to the Plex team. No more NUC vaccuming
I just got a new TV so no more transcoding ā PERIOD
Hehe great .
still seems to be an issue in 1.25.0.5282-2edd3c44d
PlexMediaServer install: Video Group: video
PlexMediaServer install: Please install package: āintel-oclocā from Releases Ā· intel/compute-runtime Ā· GitHub
PlexMediaServer install: Intel Compute Runtime packages are available from: Releases Ā· intel/compute-runtime Ā· GitHub
Just updated on 5.11.0-41-generic x86_64
Setting up plexmediaserver (1.25.1.5286-34f965be8) ...
PlexMediaServer install: PlexMediaServer-1.25.1.5286-34f965be8 - Installation starting.
PlexMediaServer install: PlexMediaServer-1.25.1.5286-34f965be8 - Installation successful. Errors: 0, Warnings: 0
I put in the change to remove ocloc from the requirements ā per this transcoder update.
It is in there . I verified myself.
Hi @ChuckPa
Great but I was just replying to show that I didnt see this error anymore
