Good stuff! you're almost there!
in the init.py file make the changes below or copy/paste:
import os
PREFIX = "/video/l0ck"
PASSWORD = "012345"
BASEPATHL0CK = 'var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support/l0ck.sh'
BASEPATHUNL0CK = 'var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support/unl0ck.sh'
GENERATE_DATE = "2nd NOV 2014"
DEV_MODE = False
NAME = 'L0ck'
ART = 'art-default.jpg'
ICON = 'icon-default.png'
L0CK_ICON = 'L0ck.png'
UNL0CK_ICON = 'unL0ck.png'
SUCCESS_ICON = 'success.png'
ERROR_ICON = 'error.png'
UPDATES_ICON = 'updates.png'
def Start():
HTTP.CacheTime = 0
ObjectContainer.art = R(ART)
DirectoryObject.thumb = R(ICON)
Plugin.AddViewGroup(“Details”, viewMode=“InfoList”, mediaType=“items”)
Plugin.AddViewGroup(“List”, viewMode=“List”, mediaType=“items”)
ObjectContainer.view_group = ‘Details’
Logger(‘Platform: ’ + Platform.OS +’ Version: '+Platform.OSVersion, force=True)
Logger('PMS Server: ’ + Platform.ServerVersion, force=True)
Logger('Plex Media Server at ’ + Core.app_support_path, force=True)
Logger('Plug-in bundles are located in ’ + Core.storage.join_path(Core.app_support_path, Core.config.bundles_dir_name), force=True)
Logger('Plug-in support files are located in ’ + Core.storage.join_path(Core.app_support_path, Core.config.plugin_support_dir_name), force=True)
Logger('L0ck Bundle path is ’ + Core.storage.join_path(Core.storage.join_path(Core.app_support_path, Core.config.bundles_dir_name), ‘L0ck.bundle’), force=True)
Logger('BASEPATHL0CK: ’ + BASEPATHL0CK, force=True)
Logger('BASEPATHUNL0CK: ’ + BASEPATHUNL0CK, force=True)
Logger('L0ck plugin generated on: ’ + GENERATE_DATE, force=True)
@handler(PREFIX, NAME, ICON, ART)
@route(PREFIX + ‘/mainmenu’)
def MainMenu():
oc = ObjectContainer(no_cache=True)
oc.add(DirectoryObject(key=Callback(L0ck, path=BASEPATHL0CK, task=‘L0cked’, query=“”), title=“L0ck”, thumb=R(L0CK_ICON)))
oc.add(InputDirectoryObject(key=Callback(L0ck, path=BASEPATHUNL0CK, task=‘UnL0cked’), title=“UnL0ck”, thumb=R(UNL0CK_ICON), prompt=“Enter your password”))
oc.add(DirectoryObject(key=Callback(Updates), title=“Update Feed”, thumb=R(UPDATES_ICON)))
return oc
@route(PREFIX + ‘/Updates’)
def Updates():
oc = ObjectContainer(title2=‘You generated the L0ck plugin on [’+ GENERATE_DATE +‘]’, view_group=‘List’, no_cache=True)
updatedata = ‘’
updatedate = ‘’
xml = RSS.FeedFromURL(‘https://raw.githubusercontent.com/ish0w/L0ck-for-plex-media-server/gh-pages/xml/updates.xml’)
for item in xml.entries:
updatedata = item.description
updatedate = item.title
Logger(updatedate, force=True)
Logger(updatedata, force=True)
oc.add(DirectoryObject(key=Callback(MainMenu),title=‘[’ + updatedate +'] - ’ + updatedata))
if len(oc) < 1:
Logger(‘Something went wrong while pulling xml’, force=True)
return oc.add(DirectoryObject(key=Callback(MainMenu),title=‘Pl. ensure your connected to the internet and try again!’))
else:
return oc
@route(PREFIX + ‘/L0ck’)
def L0ck(query, path, task):
oc = ObjectContainer(title2=“L0ck”, no_cache=True)
if task == ‘UnL0cked’:
if query == PASSWORD:
Logger(‘Password correct about to launch unL0ck’, force=True)
#filepath = path.replace(’ ', '\ ')
os.system(‘sh ’ + path)
Logger(‘Launched unL0ck’, force=True)
oc.add(PopupDirectoryObject(key=Callback(MainMenu), title=“UnL0cked”, duration=3, summary=“Section(s) successfully UnL0cked!”, thumb=R(SUCCESS_ICON)))
return oc
else:
Logger(‘Password Incorrect, someone is trying to get in!’, force=True)
oc.add(PopupDirectoryObject(key=Callback(MainMenu), title=“Incorrect Password”, duration=3, summary=“Try Again!”, thumb=R(ERROR_ICON)))
return oc
elif task == ‘L0cked’:
Logger(‘L0cking’, force=True)
os.system('sh ’ + path)
Logger(‘L0cked’, force=True)
oc.add(PopupDirectoryObject(key=Callback(MainMenu), title=“L0cked”, duration=3, summary=“Section(s) successfuly L0cked!”, thumb=R(SUCCESS_ICON)))
return oc
@route(PREFIX + ‘/logger’)
def Logger(message, force=False):
if DEV_MODE:
force = True
if force:
Log.Debug(‘======L0CK======’+message)
else:
pass
FYI - every instance of "filepath" needed to be changed to "path"
Now make the necessary changes to unl0ck.sh
change this below
./sqlite3 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Plug-in\ Support/Databases/com.plexapp.plugins.library.db "$unl0ckplex"
to
...and lastly dont forget to run the below commands in terminal again!
...Dont forget to run the below in terminal, it is critical! Copy and paste the below in terminal
cd "var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/"
sudo chown -R plex:plex L0ck.bundle
hit enter!
then copy/paste the below and hit enter
cd "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support"
sudo chmod a+x l0ck.sh
sudo chmod a+x unl0ck.sh
sudo chmod a+x sqlite3
If you are logged in as root try:
hit enter!
chmod a+x l0ck.sh
chmod a+x unl0ck.sh
chmod a+x sqlite3
/iSh0w
thx for your answer, but unfortunately it will not work. the libary "home videos" is locked, but i cant unlock it.
2014-11-03 17:57:01,266 (7f93148a5700) : INFO (core:347) - Starting framework core - Version: 2.5.0, Build: a51033b (Mon Jul 28 12:19:14 UTC 2014)
2014-11-03 17:57:01,267 (7f93148a5700) : DEBUG (core:359) - Using the elevated policy
2014-11-03 17:57:01,267 (7f93148a5700) : DEBUG (core:448) - Starting runtime component.
2014-11-03 17:57:01,268 (7f93148a5700) : DEBUG (core:448) - Starting caching component.
2014-11-03 17:57:01,268 (7f93148a5700) : DEBUG (core:448) - Starting data component.
2014-11-03 17:57:01,268 (7f93148a5700) : DEBUG (core:448) - Starting networking component.
2014-11-03 17:57:01,268 (7f93148a5700) : DEBUG (networking:288) - Loaded HTTP cookies
2014-11-03 17:57:01,269 (7f93148a5700) : DEBUG (networking:458) - Setting the default network timeout to 20.0
2014-11-03 17:57:01,269 (7f93148a5700) : DEBUG (core:448) - Starting localization component.
2014-11-03 17:57:01,269 (7f93148a5700) : INFO (localization:408) - Setting the default locale to en-us
2014-11-03 17:57:01,269 (7f93148a5700) : DEBUG (core:448) - Starting messaging component.
2014-11-03 17:57:01,270 (7f9309409700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.plugins.l0ckunl0ck'
2014-11-03 17:57:01,270 (7f93148a5700) : DEBUG (core:448) - Starting debugging component.
2014-11-03 17:57:01,270 (7f93148a5700) : DEBUG (core:448) - Starting services component.
2014-11-03 17:57:01,271 (7f93148a5700) : DEBUG (core:448) - Starting myplex component.
2014-11-03 17:57:01,271 (7f93148a5700) : DEBUG (core:448) - Starting notifications component.
2014-11-03 17:57:01,369 (7f93148a5700) : DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.plugins.l0ckunl0ck in namespace 'metadata'
2014-11-03 17:57:01,373 (7f93148a5700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2014-11-03 17:57:01,490 (7f9309409700) : DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2014-11-03 17:57:01,493 (7f9309409700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2014-11-03 17:57:01,490 (7f93148a5700) : DEBUG (runtime:1111) - Created a thread named 'load_all_services'
2014-11-03 17:57:01,494 (7f9303fff700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400'
2014-11-03 17:57:01,494 (7f93148a5700) : DEBUG (runtime:1111) - Created a thread named 'get_server_info'
2014-11-03 17:57:01,497 (7f93148a5700) : DEBUG (core:150) - Finished starting framework core
2014-11-03 17:57:01,497 (7f93148a5700) : DEBUG (core:558) - Loading plug-in code
2014-11-03 17:57:01,546 (7f93148a5700) : DEBUG (core:564) - Finished loading plug-in code
2014-11-03 17:57:01,548 (7f93148a5700) : DEBUG (runtime:640) - Adding a prefix handler for 'L0ck' ('/video/l0ck')
2014-11-03 17:57:01,550 (7f93148a5700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400'
2014-11-03 17:57:01,552 (7f9303fff700) : DEBUG (core:536) - Machine identifier is 5de14e0adcefdc1185d317ad0dd7e14b2b2de26b
2014-11-03 17:57:01,553 (7f9303fff700) : DEBUG (core:537) - Server version is 0.9.11.1.678-c48ffd2
2014-11-03 17:57:01,554 (7f93148a5700) : DEBUG (core:519) - Attribute 'platformVersion' set to ' (#1 SMP Debian 3.16.3-2~bpo70+1 (2014-09-21))'
2014-11-03 17:57:01,554 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======Platform: Linux Version: (#1 SMP Debian 3.16.3-2~bpo70+1 (2014-09-21))
2014-11-03 17:57:01,555 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======PMS Server: 0.9.11.1.678-c48ffd2
2014-11-03 17:57:01,555 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======Plex Media Server at /var/lib/plexmediaserver/Library/Application Support/Plex Media Server
2014-11-03 17:57:01,555 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======Plug-in bundles are located in /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins
2014-11-03 17:57:01,555 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======Plug-in support files are located in /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support
2014-11-03 17:57:01,555 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======L0ck Bundle path is /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle
2014-11-03 17:57:01,555 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======BASEPATHL0CK: var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support/l0ck.sh
2014-11-03 17:57:01,556 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======BASEPATHUNL0CK: var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/L0ck.bundle/Contents/Resources/l0ck_support/unl0ck.sh
2014-11-03 17:57:01,556 (7f93148a5700) : DEBUG (__init__:91) - ======L0CK======L0ck plugin generated on: 2nd NOV 2014
2014-11-03 17:57:01,556 (7f93148a5700) : INFO (core:609) - Started plug-in
2014-11-03 17:57:01,556 (7f93148a5700) : DEBUG (socketinterface:160) - Starting socket server
2014-11-03 17:57:01,557 (7f93148a5700) : DEBUG (runtime:1111) - Created a thread named 'start'
2014-11-03 17:57:01,557 (7f93148a5700) : INFO (socketinterface:184) - Socket server started on port 47720
2014-11-03 17:57:01,557 (7f93148a5700) : INFO (pipeinterface:25) - Entering run loop
2014-11-03 17:57:01,557 (7f93148a5700) : DEBUG (runtime:717) - Handling request GET /:/prefixes
2014-11-03 17:57:01,559 (7f93148a5700) : DEBUG (runtime:814) - Found route matching /:/prefixes
2014-11-03 17:57:01,650 (7f9309409700) : DEBUG (services:362) - Loaded services
2014-11-03 17:57:01,651 (7f93148a5700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 448 bytes
2014-11-03 17:57:01,655 (7f9308c08700) : DEBUG (services:438) - No shared code to load
2014-11-03 17:57:01,657 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck
2014-11-03 17:57:01,658 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:01,659 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck
2014-11-03 17:57:01,660 (7f9308c08700) : DEBUG (base:125) - Checking if com.plexapp.plugins.l0ckunl0ck is broken
2014-11-03 17:57:01,661 (7f9308c08700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMzAKY29tLnBsZXhhcHAucGx1Z2lucy5sMGNrdW5sMGNrczEwCmlkZW50aWZpZXJyMAo_'
2014-11-03 17:57:01,667 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:01,667 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:01,707 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck/mainmenu
2014-11-03 17:57:01,708 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:01,709 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck/mainmenu
2014-11-03 17:57:01,711 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:01,711 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:02,685 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck
2014-11-03 17:57:02,686 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:02,688 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck
2014-11-03 17:57:02,688 (7f9308c08700) : DEBUG (base:125) - Checking if com.plexapp.plugins.l0ckunl0ck is broken
2014-11-03 17:57:02,689 (7f9308c08700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMzAKY29tLnBsZXhhcHAucGx1Z2lucy5sMGNrdW5sMGNrczEwCmlkZW50aWZpZXJyMAo_'
2014-11-03 17:57:02,698 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:02,698 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:02,721 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck/L0ck?path=var%2Flib%2Fplexmediaserver%2FLibrary%2FApplication+Support%2FPlex+Media+Server%2FPlug-ins%2FL0ck.bundle%2FContents%2FResources%2Fl0ck_support%2Fl0ck.sh&task=L0cked&query=
2014-11-03 17:57:02,722 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:02,723 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck/L0ck
2014-11-03 17:57:02,724 (7f9308c08700) : DEBUG (__init__:91) - ======L0CK======L0cking
2014-11-03 17:57:02,727 (7f9308c08700) : DEBUG (__init__:91) - ======L0CK======L0cked
2014-11-03 17:57:02,729 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:02,730 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 576 bytes
2014-11-03 17:57:03,542 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck
2014-11-03 17:57:03,544 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:03,545 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck
2014-11-03 17:57:03,546 (7f9308c08700) : DEBUG (base:125) - Checking if com.plexapp.plugins.l0ckunl0ck is broken
2014-11-03 17:57:03,547 (7f9308c08700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMzAKY29tLnBsZXhhcHAucGx1Z2lucy5sMGNrdW5sMGNrczEwCmlkZW50aWZpZXJyMAo_'
2014-11-03 17:57:03,556 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:03,556 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:03,570 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck/mainmenu
2014-11-03 17:57:03,572 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:03,573 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck/mainmenu
2014-11-03 17:57:03,576 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:03,576 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:04,453 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck
2014-11-03 17:57:04,454 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:04,456 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck
2014-11-03 17:57:04,456 (7f9308c08700) : DEBUG (base:125) - Checking if com.plexapp.plugins.l0ckunl0ck is broken
2014-11-03 17:57:04,457 (7f9308c08700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMzAKY29tLnBsZXhhcHAucGx1Z2lucy5sMGNrdW5sMGNrczEwCmlkZW50aWZpZXJyMAo_'
2014-11-03 17:57:04,466 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:04,466 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:04,484 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck/L0ck?path=var%2Flib%2Fplexmediaserver%2FLibrary%2FApplication+Support%2FPlex+Media+Server%2FPlug-ins%2FL0ck.bundle%2FContents%2FResources%2Fl0ck_support%2Fl0ck.sh&task=L0cked&query=
2014-11-03 17:57:04,485 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:04,486 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck/L0ck
2014-11-03 17:57:04,487 (7f9308c08700) : DEBUG (__init__:91) - ======L0CK======L0cking
2014-11-03 17:57:04,490 (7f9308c08700) : DEBUG (__init__:91) - ======L0CK======L0cked
2014-11-03 17:57:04,493 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:04,493 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 576 bytes
2014-11-03 17:57:05,312 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck
2014-11-03 17:57:05,314 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:05,315 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck
2014-11-03 17:57:05,316 (7f9308c08700) : DEBUG (base:125) - Checking if com.plexapp.plugins.l0ckunl0ck is broken
2014-11-03 17:57:05,317 (7f9308c08700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMzAKY29tLnBsZXhhcHAucGx1Z2lucy5sMGNrdW5sMGNrczEwCmlkZW50aWZpZXJyMAo_'
2014-11-03 17:57:05,325 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:05,326 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:05,343 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck/mainmenu
2014-11-03 17:57:05,344 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:05,345 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck/mainmenu
2014-11-03 17:57:05,347 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:05,348 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:07,018 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck
2014-11-03 17:57:07,019 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:07,020 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck
2014-11-03 17:57:07,021 (7f9308c08700) : DEBUG (base:125) - Checking if com.plexapp.plugins.l0ckunl0ck is broken
2014-11-03 17:57:07,022 (7f9308c08700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMzAKY29tLnBsZXhhcHAucGx1Z2lucy5sMGNrdW5sMGNrczEwCmlkZW50aWZpZXJyMAo_'
2014-11-03 17:57:07,031 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:07,031 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:07,045 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck/L0ck?path=var%2Flib%2Fplexmediaserver%2FLibrary%2FApplication+Support%2FPlex+Media+Server%2FPlug-ins%2FL0ck.bundle%2FContents%2FResources%2Fl0ck_support%2Funl0ck.sh&task=UnL0cked&query=012345
2014-11-03 17:57:07,047 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:07,048 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck/L0ck
2014-11-03 17:57:07,048 (7f9308c08700) : DEBUG (__init__:91) - ======L0CK======Password correct about to launch unL0ck
2014-11-03 17:57:07,051 (7f9308c08700) : DEBUG (__init__:91) - ======L0CK======Launched unL0ck
2014-11-03 17:57:07,054 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:07,054 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 581 bytes
2014-11-03 17:57:08,183 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck
2014-11-03 17:57:08,184 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:08,186 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck
2014-11-03 17:57:08,187 (7f9308c08700) : DEBUG (base:125) - Checking if com.plexapp.plugins.l0ckunl0ck is broken
2014-11-03 17:57:08,188 (7f9308c08700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMzAKY29tLnBsZXhhcHAucGx1Z2lucy5sMGNrdW5sMGNrczEwCmlkZW50aWZpZXJyMAo_'
2014-11-03 17:57:08,196 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:08,197 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
2014-11-03 17:57:08,252 (7f9308c08700) : DEBUG (runtime:717) - Handling request GET /video/l0ck/mainmenu
2014-11-03 17:57:08,254 (7f9308c08700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2014-11-03 17:57:08,255 (7f9308c08700) : DEBUG (runtime:814) - Found route matching /video/l0ck/mainmenu
2014-11-03 17:57:08,257 (7f9308c08700) : DEBUG (runtime:106) - Sending packed state data (111 bytes)
2014-11-03 17:57:08,257 (7f9308c08700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1175 bytes
