Migration Questions
The old server has no way that I can stop it myself. I have to get the owners to stop it. One reason I’m going elsewhere.
It would be much easier to change the new server, what do you think?
Well, not eventually. I was planning on setting up the new server, test it and then stop the old one.
Thanks for telling me this.
Oh well, I didn’t want to mess with the docker
BUT :roll_eyes:
Change the pathnames I gave you above to work in the filesystem on the new docker container.
This means, something like, /some/path/config/Library/Application Support/Plex Media Server
Now you can use the procedure I have written above.
Since there’s a conflict with server management, If you need to change the server’s account, now is the time.
While in Preferences.xml, remove the following Name="Value" pairs:
  • PlexOnlineUsername
  • PlexOnlineMail
  • PlexOnlineToken
  • PlexOnlineHome (if it exists)
IF you do this, you WILL need to claim the server.
Being remote, there’s a trick we can use .
If you do change the account, let me know and I’ll show you how to do that.
All done!!
No need to change the account.
Going to server my IP gives:
I see two current servers and three deleted servers
I see ‘omv’ and the other ‘USB’.
What should I see?
That screen you’re seeing means there is no “Home” page settings for the server.
Clicking “MORE>” should take you to where you can see both servers listed.
Confirm?
I have 3 PMS’s.
My OMV NAS - This is disabled at the moment.
My old server called SH - Plex Server
My new server called USB Plex Server
Good, I do see USB :slight_smile:
It doesn’t have a certificate. That seems to be the problem.
Can you
  1. stop PMS
  2. make a tar.gz of the Logs directory under PMS.
I need to see what’s happening in there. I suspect the old cert needs to be manually removed as well.
Here are the logs.
Logs.zip (1.6 MB)
NAILED IT! LOL
Apr 21, 2022 06:16:08.806 [0x7f2f09872b38] INFO - Plex Media Server v1.25.9.5721-965587f64 - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 debian - GMT 00:00
Apr 21, 2022 06:16:08.807 [0x7f2f09872b38] INFO - Linux version: 4.19.0-18-amd64, language: en-US
Apr 21, 2022 06:16:08.807 [0x7f2f09872b38] INFO - Processor: 128-core AMD EPYC 7702P 64-Core Processor
Apr 21, 2022 06:16:08.807 [0x7f2f09872b38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv b587490162c22e078c314e3f7dc560c691d126aa)
Apr 21, 2022 06:16:08.807 [0x7f2f09872b38] INFO - /usr/lib/plexmediaserver/Plex Media Server
Apr 21, 2022 06:16:10.704 [0x7f2f0d0560c8] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:10.704 [0x7f2f0d0560c8] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:10.714 [0x7f2f0d0560c8] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:10.782 [0x7f2f08247b38] WARN - Crash: Crash reporting disabled
Apr 21, 2022 06:16:10.826 [0x7f2f0d0560c8] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:10.826 [0x7f2f0d0560c8] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:11.000 [0x7f2f07cb5b38] ERROR - MyPlex: Error 403 requesting XML from: https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Apr 21, 2022 06:16:11.000 [0x7f2f07cb5b38] ERROR - MyPlex: Couldn't get list of access tokens from myPlex.
Apr 21, 2022 06:16:11.098 [0x7f2f07cfbb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Apr 21, 2022 06:16:11.098 [0x7f2f07cfbb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Apr 21, 2022 06:16:11.120 [0x7f2f07e7fb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Apr 21, 2022 06:16:11.120 [0x7f2f07e7fb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Apr 21, 2022 06:16:13.264 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:13.264 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:13.315 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:13.315 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:13.641 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:13.641 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:13.684 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:13.684 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:13.832 [0x7f2f081edb38] WARN - [EventSourceClient/pubsub] MyPlex: attempted a reachability check but we're not yet mapped.
Apr 21, 2022 06:16:13.902 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:13.902 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:13.903 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:13.946 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:13.946 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:13.947 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:13.947 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:13.985 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:13.985 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:13.986 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:13.986 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:14.028 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:14.028 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:14.029 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:14.029 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:14.068 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:14.069 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:14.069 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:14.069 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:14.070 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:14.109 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:14.109 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:14.110 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
Apr 21, 2022 06:16:14.110 [0x7f2f08210b38] ERROR - [CERT] Found a certificate, but couldn't install it.
Apr 21, 2022 06:16:14.152 [0x7f2f08210b38] ERROR - [CERT] MyPlex: Error 404 requesting XML from: https://plex.tv/api/v2/devices/307539e3c07d18463a17b458666c7d8e71c32ac9/certificate/subject
Apr 21, 2022 06:16:14.152 [0x7f2f08210b38] ERROR - [CERT] CERT: Error acquiring new certificate: error fetching Subject
Apr 21, 2022 06:16:14.153 [0x7f2f08210b38] ERROR - [CERT] PKCS12_parse failed: error:23076071:PKCS12 routines:PKCS12_parse:mac verify failure
  1. With Plex stopped,
  2. At the same level as the Logs directory, you’ll see the Cache directory.
  3. cd into it.
  4. sudo rm cert*.p12 (there should be a cert-v2.p12 file if you want to look)
  5. Now start the server
  6. It will see it has no cert and go ask for one from Plex.tv
After we get this server claimed, it’s a good idea to turn DEBUG logging back on.
It doesn’t use more disk space (logs are fixed size) but it will let us see more when issues arise
I see the server is awake but no certificate yet.
Check the UID/GID of everything. Something got missed.
UID/GID look OK.
Screenshot below. Old server is not there either.
Did you rerun the chown -R command on the entire Plex Media Server tree?
Go look at Preferences.xml
I’m going to send you a PM so you can paste the contents.
Preferences.xml now has the entries I removed, but different ones.
Paste it all in the PM I sent you please
Yes.
All seems good except for one TV Series with is showing like below. Have done a Scan & Metadata Refresh and it has not helped. Any ideas appreciated.
If you have ONE series that’s not showing up / showing that –
Check the file system permissions / path.
Something is out of whack with the media if it’s isolated to one item
All looks OK there:
Hmmm. It must think it’s elsewhere
Dance the season.
  1. Move the whole season out
  2. Empty Trash
  3. Clean Bundles
  4. Move season back
  5. Scan Files
That did the trick.
I must say @ChuckPa your support has been amazing and I cannot thank you enough for your time and effort in helping this old noob. I could not have done it without you and I just wish I realised from the beginning we would be mirroring the old server. Makes sense once you told me but just never crossed my mind.
Once again, thank you.
