Hi.
I added the /k and got below screen shot
Hi.
Ok. According to this latest screen shot, the script and SQL statement ran fine and according to your previous screenshot, it did not return any results. Try the script again, after you see this latest DOS screen, the results should be saved in the windows clipboard. Open up a notepad window and just hit paste. This will show you what the script returned as a result. If it is anything other then blank, Please PM me the result so I can take a look as that would be a bug.
Looks great! Can you share the icons and process?
Just getting round to changing the library icons :)
Can you give me an example of "HTML formatted" text for the image location?
Thanks!
I need to change that. Pms no longer supports local files only files from the internet. To add that, just copy the url to the image you want to use and paste that into the box.
Script is back. See first post.
Thanks MovieFan for including the Export functionality for the database tables
I am having difficulties running the script.
I have created a folder: C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan
In that folder I have all the scripts and exe files and ini file as well as a copy of the PMS database
C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\com.plexapp.plugins.library.db C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MortScript.exe C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0 - Collection.mscr C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0 - Database.mscr C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0 - Library.mscr C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0 - Other.mscr C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0 - Playlist.mscr C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0 - User.mscr C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0.exe C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\MovieFan's Database Tool for Plex v0.3.0.mscr C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\setting.ini C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\sqlite3.exe
# MovieFan's Database Tool for Plex v0.3.0[database]
location=C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\com.plexapp.plugins.library.db[command]
location=C:\Windows\System32\cmd.exe[sqlite3]
location=C:\Users\Plex\AppData\Local\Plex Media Server\MovieFan\sqlite3.exe[plex]
location=C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Server.exe[setting]
debug=True
Sorry, i forgot to mention this in my instructions. Right click the mortscript.exe and run as administrator. This registers the extension with the program. It does not have to be the default program but does need to be registered.
wow - that did the trick ! I had registered it before but not as administrator !
Thank you so much - i now have my 20 csv files with just one click !
Whilst the exports to csv files work ok and the files are generated with valid contents, when i then close the command line window where it ran the SQlite3 export, i then get a dialogue box indicating errors. The db_export.log file has
Error exporting accounts... Error exporting directories... Error exporting library_sections... Error exporting media_items... Error exporting media_part_settings... Error exporting media_parts... Error exporting media_streams... Error exporting metadata_item_accounts... Error exporting metadata_item_settings... Error exporting metadata_item_views... Error exporting metadata_items... Error exporting metadata_relations... Error exporting play_queue_generators... Error exporting play_queue_items... Error exporting play_queues... Error exporting plugin_prefixes... Error exporting plugins... Error exporting section_locations... Error exporting taggings... Error exporting tags...
But i don;t think there are any errors in the export. I will look closely tomorrow
The only reason to run as admin is to register the extension properly. After that i don’t think it runs as admin for normal use.
The error handling is very simple. It just looks if the file was created. Could be a race condition where the file is still writing when it does it’s check. I’ll look into making that check more rebust to avoid this potential.
Still having issues with movie-fanart.jpg files not getting created, even though the log file says it did.
Bug found, I think. Check your PM.
Yes, thank you... all is working well now.
how to work it? i can't open .exe
You need to pick the version of the program (mortscript.exe) you want to use 32-bit (PC) or 64-bit (PC64) from those directory and put it into this folder. Then right click on it and run as administrator. Then you can run the script exe file.
just found this! will have a play this weekend!
nice one!
