Moving library on new plex install broke library access
That is correct. My system has “snap” but I installed via terminal using DPKG.
Can you show me the output of /tmp/plexinstaller.log ?
it is not there.
troy@zigserver:~$ /tmp/plexinstaller.log
bash: /tmp/plexinstaller.log: No such file or directory
troy@zigserver:~$
If you rerun the package install (dpkg -i plexmediaserver-version.dpkg), it will reinstall the binaries without touching anything else.
It will also generate the reports (console and log file in /tmp)
I stopped PMS,then ran “dpkg -i plexmediaserver-version.dpkg” for my version of plex.
Restarted the OS and plex looks like it is running with the library files running from their original location at “/var/lib/plexmediaserver/Library/Application Support”.
Now before I mess anything up I want to check with you, to move the library do I reapply the instructions in linux tips? I thought it would have already recognized the other location because the override file is still there to direct systemd to it but that is not what I am seeing. The override file and the previously moved plex library folders are still in the location that I described in earlier posts.
Please show me the contents of /tmp/Plexinstaller.log ?
It will show me if there is anything special to be concerned with.
Here:
Plex Media Server installation configuration info: Mon Jun 15 15:49:06 PDT 2020
Init=0
Systemd=1
Custom=0
LinuxContainer=0
NewInstall=0
HaveOverride=0
OverrideFile=""
PlexUser=“plex”
PlexGroup=“plex”
VideoGroup=“video”
AppSuppDir="/var/lib/plexmediaserver/Library/Application Support"
PlexTempDir="/tmp"
LangEncoding=“en_US.UTF-8”
ExistingVersion=11904
HaveHardware=1
HaveTranscoderPref=0
NeedUser=0
NeedGroup=0
NeedVideo=0
Verbose=1
Running=0
Errors=0
Warnings=0
Platform=“To Be Filled By O.E.M.”
Processor=“Intel® Core™ i3-2105 CPU @ 3.10GHz”
Distro=“Ubuntu 18.04.4 LTS”
Kernel=“Linux zigserver 5.3.0-56202005281620-generic #0+mediatree+hauppauge~hwe-Ubuntu SMP Fri May 29 18:32:07 UTC 20 x86_64 x86_64 x86_64 GNU/Linux”
Memory=“11687 1928 266”
Troy
Thanks,
These two variables are the key
NewInstall=0
HaveOverride=0
  1. It’s an update to an existing installation
  2. There are no custom settings in overrides (override.conf or /etc/default/plexmediaserver)
To move the installation,
  1. Without deleting the existing /var/lib/plexmediaserver
  2. and with it stopped
  3. Follow the How-To to make a tar file (you must be full sudo bash (command shell) to do this.
  4. you can use `cd /var/lib/plexmediaserver ; tar cf - ./Library | (cd /new/location ; tar xf - )
  5. Remember to check the ownership of the top most directories so user plex can write. Also check permissions
  6. Then create the override before starting.
I am unable to move the library files, when I try, the move fails because it says the files are changing while trying to move them.
I ran systemctl stop plexmediaserver before trying, but somthing is still running.
Did you STOP plex? By what you describe, you didn’t.
I apperantly don’t know how to stop plex.
The original /var/lib/plexmediaserver is intact.
I tried ‘sudo systemctl stop plexmediaserver’ and ‘sudo service plexmediaserver stop’, neither stopped the library files from changing when attempting tar (see terminal sessions below).
I also ran ‘sudo snap services’ to see if something was left from the snap version I had previously removed.
‘root@zigserver:/var/lib/plexmediaserver# sudo snap services
Service Startup Current Notes
canonical-livepatch.canonical-livepatchd enabled active -’
I am befuddled.
In new terminal session:
troy@zigserver:~$ cd /var/lib/plexmediaserver
troy@zigserver:/var/lib/plexmediaserver$ sudo su
[sudo] password for troy:
root@zigserver:/var/lib/plexmediaserver# sudo service plexmediaserver stop
root@zigserver:/var/lib/plexmediaserver# tar cf - ./Library | (cd data/plex ; tar xf -)   # this will take some time
bash: cd: data/plex: No such file or directory
tar: ./Library/Application Support/Plex Media Server/Logs/Plex Media Server.1.log: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/Plex Media Server.5.log: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/Plex Media Server.2.log: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/com.plexapp.system.log.2: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/tv.plex.agents.movie.log: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/com.plexapp.agents.localmedia.log: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/com.plexapp.system.log.5: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/com.plexapp.agents.imdb.log.1: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/com.plexapp.system.log.3: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/com.plexapp.system.log.1: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs/com.plexapp.system.log.4: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/PMS Plugin Logs: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs/Plex Media Server.4.log: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Logs: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Cache: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.tubitv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.fallback: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.stumbleupon: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.rt: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.cbcnewsnetwork: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.breakcom/URL/Break.com/ServiceCode.pys: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.breakcom/URL/Break.com: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.breakcom: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.gametrailers: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.pixelcorps: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.ted: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.search.videosurf/Resources/SourceIcon-YouTube.png: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.search.videosurf/Resources/SourceIcon-Vimeo.png: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.search.videosurf/Resources: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.search.videosurf: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.theguardian: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.xxx: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.indieclicktv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.theonion: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.imovies: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.abc: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.brightcove: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.toutv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.freakonomics: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.cnn: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.ndtv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.locotv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.slice: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.schweizerfernsehen: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.abcfamily: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.mtv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.aolon: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.liveleak: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.rtlxl: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.foxnews: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.teamhww: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.fox: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.dailymotion: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.rutube: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.theberrics: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.snagfilms: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.wsj: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.tested: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.videostrip: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.moviefone: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.lifetime: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.viasat: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.rtbf: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.revision3: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.zideo: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.orftvthek: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.vine: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.pbs: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.youtube/URL/YouTube: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.youtube: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.newsy: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.vimeo: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.videobash: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.dumpert: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.oratv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.annakimphotography: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.bing: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.googledrive: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.cnettv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.tvone: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.nationalgeographic: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.teamcoco: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.mpora: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.absoluteradio: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.theverge: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.aetv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.golfchannel: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.foodnetwork: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.amt: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.hollywoodreporter: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.bodybuilding: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.npo: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.drdk: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.triplem: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.pitchforktv: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.tv4play/URL/TV4 Play: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.tv4play: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.historychannel: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Resources/icon-default.png: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Resources: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Databases: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.none: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.agents.htbackdrops: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Caches/com.plexapp.system/HTTP.system/3e/f05b5f17249d5b14b0bab077317a8fb34a4002.content: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Caches/com.plexapp.system/HTTP.system/3e: file changed as we read it
tar: ./Library/Application Support/Plex Media Server/Plug-in Support/Caches/com.plexapp.system/HTTP.system: file changed as we read it
tar: ./Library/Application Support/Plex Media Server: file changed as we read it
in seperate terminal session:
troy@zigserver:~$ sudo systemctl stop plexmediaserver
troy@zigserver:~$ sudo su
root@zigserver:/home/troy# cd /var/lib/plexmediaserver
tar: ./Library/Application Support/Plex Media Server/Plug-ins/Services.bundle/Contents/Service Sets/com.plexapp.plugins.metacafe: file changed as we read it
Moderator Edit: Placed in code snippet (``` bracketing) for legibility.
The effort to move PMS to a new APPLICATION_SUPPORT_DIR location will have to wait until you learn / figure out how to control PMS on your system.
  1. Which package did you install? dpkg , Docker, or Ubuntu Store ?
  2. Distro and Version?
dpkg
plexmediaserver_1.19.4.2902-69560ce1e_amd64.deb
I have been unable to do anything since June 18, I’m really tired of not getting anywhere. Does anyone know of an alternative to plex that works with Ubuntu?
Review everything in my How-To. This procedure works every time.
I replied:
dpkg
I did not get any reply. I have been unable to stop plex to move the library. Please reread the previous posts.
