Mains is working fine no matter the updates i only had someones change the command to delete show whit special characters. this version is without the two last change yall help whit. Also to keep in mind the program you edit you code is important sometimes it just spoil everything because they don't use the same character settings.
#!/usr/bin/python
# -*- coding: utf-8 -*-
## INFORMATION
## Developed by: Steven Johnson (minor modifications by egretsareherons)
## (a minor modifications by aross01)
## (a minor modification by STEEVo)
## Last Updated: 02/26/2014 5:05PM MST
## Description: Auto-Delete Watched Items In Plex
## Required Configurations:
## - PC (Blank = AutoDetect | W = Windows | L = Linux/Unix/MAC)
## - Host (Hostname or IP | Blank = 127.0.0.1)
## - Port (Port | Blank = 32400)
## - SectionList - A list of sections to operate on. If this is blank, the script
## will get a list of all sections from the server & operate on all, except
## for the sections listed in IgnoreSections
## - IgnoreSections - Only used if SectionList is blank. When SectionList is blank,
## the script will operate on all available sections of your install
## except for the ones listed here.
## - Delete (1 = Delete | Blank = 0 (For Testing or Review))
## - Move (1 = move files to DestinationDir, 0 = don't move)
## - Copy (1 = copy files to DestinationDir, 0 = don't copy)
## - Shows ( ["Show1","Show2"]; = Kept Shows OR [""]; = DEL ALL SHOWS )
## - OnDeck ( 1 = Keep If On Deck | Blank = Delete Regardless if onDeck )
## - DestinationDir - the place to move or copy your watched files for later manual deletion
## - DestinationSection - if your destination dir is also a configured section, set the
## number here so TriggerRescan knows to rescan that section when changes are made.
## only used if TriggerRescan is True;
## - TriggerRescan - automatically trigger a deep rescan of changed sections. True or False.
## - KeepMode (Blank = Disabled | W = "Watched" | A = "Added")
## Method used to keep items for X number of days (specified by DaysToKeep below.)
## You may choose to base the keep on the last "watched" or "added" date.
## - DaysToKeep ("30" = Keep items for 30 days following the KeepMode selected)
PC = “”
Host = “”
Port = “”
SectionList = []
IgnoreSections = []
Delete = “”
Move = “0”
Copy = “0”
Shows = []
OnDeck = “”
DestinationDir = “”
DestinationSection = “”
TriggerRescan = True
KeepMode = “”
DaysToKeep = 30
NO NEED TO EDIT BELOW THIS LINE
import os
import xml.dom.minidom
import platform
import re
import shutil
import datetime
import glob
try:
import urllib.request as urllib2
except:
import urllib2
Check On Deck
def CheckOnDeck( CheckDeckFile ):
InTheDeck = 0
for DeckVideoNode in deck.getElementsByTagName(“Video”):
DeckMediaNode = DeckVideoNode.getElementsByTagName(“Media”)
for DeckMedia in DeckMediaNode:
DeckPartNode = DeckMedia.getElementsByTagName(“Part”)
for DeckPart in DeckPartNode:
Deckfile = DeckPart.getAttribute(“file”)
if CheckDeckFile==Deckfile:
InTheDeck += 1
else:
InTheDeck += 0
return InTheDeck
Check Shows And Delete If Configured
def CheckShows( CheckFile ):
global FileCount
global DeleteCount
global MoveCount
global CopyCount
global FlaggedCount
global OnDeckCount
global ShowsCount
global DestinationDir
FileCount += 1
CantDelete = 0
ShowFound = “”
changed = 0
– CHECK SHOWS –
for Show in Shows:
Show = re.sub(’[^A-Za-z0-9 ]+’, ‘’, Show).strip()
if Show=="":
CantDelete = 0
else:
if (’ ’ in Show) == True:
if all(str(Word) in CheckFile for Word in Show.split()):
CantDelete += 1
ShowFound = “[” + Show + “]”
ShowsCount += 1
else:
CantDelete += 0
else:
if Show in CheckFile:
CantDelete += 1
ShowsCount += 1
else:
CantDelete += 0
– Check OnDeck –
if OnDeck==“1”:
IsOnDeck = CheckOnDeck(CheckFile);
if IsOnDeck==0:
CantDelete += 0
else:
CantDelete += 1
ShowFound = “[OnDeck]” + ShowFound
OnDeckCount += 1
– Check if video older than days to keep [Viewed method] –
if KeepMode==“W”:
if DaysToKeep > DaysSinceVideoLastViewed:
CantDelete += 1
ShowsCount += 1
ShowFound = " | Days Since Viewed:" + str(DaysSinceVideoLastViewed) +" |" + ShowFound
– Check if video older than days to keep [Added method] –
if KeepMode==“A”:
if DaysToKeep > DaysSinceVideoAdded:
CantDelete += 1
ShowsCount += 1
ShowFound = " | Days Since Added:" + str(DaysSinceVideoAdded) +" |" + ShowFound
– DELETE SHOWS –
if CantDelete == 0:
if Delete==“1”:
#print("[DELETED] " + CheckFile)
similairFiles = re.sub(’[’, ‘[[]’, os.path.splitext(file)[0]) + “*”
print(“Looking for " + similairFiles)
for deleteFile in glob.glob(similairFiles):
try:
os.remove(deleteFile)
print(”[DELETED] " + deleteFile)
changed = 1
DeleteCount += 1
except Exception as e:
print (“error deleting file: %s” % e)
elif Move == “1”:
try:
os.utime(os.path.realpath(CheckFile), None)
shutil.move(os.path.realpath(CheckFile), DestinationDir)
print("[MOVED] " + CheckFile)
changed = 1
print (“error moving file: %s” % e)
if os.path.islink(CheckFile):
os.unlink(CheckFile)
MoveCount += 1
elif Copy == “1”:
try:
shutil.copy(os.path.realpath(CheckFile), DestinationDir)
changed = 1
print (“error copying file: %s” % e)
print("[COPIED] " + CheckFile)
CopyCount += 1
else:
print("**[FLAGGED] " + CheckFile)
FlaggedCount += 1
else:
print("[KEEPING]")
return changed
Checking URL
if Host=="":
Host=“127.0.0.1”
if Port=="":
Port=“32400”
print("----------------------------------------------------------------------------")
print(" Detected Settings")
print("Host: " + Host)
print("Port: " + Port)
#print("Section: " + Section)
#print("URL: " + URL)
#print("OnDeck URL: " + OnDeckURL)
if KeepMode==“W”:
print(“Keep Mode: Keeping for " + str(DaysToKeep) + " days following the date last viewed”)
elif KeepMode==“A”:
print(“Keep Mode: Keeping viewed items that were added to the library less than " + str(DaysToKeep) + " days ago”)
else:
print(“Keep Mode: DISABLED”)
Checking Shows
NoDelete = " | "
ShowCount = len(Shows)
print("Show Count: " + str(ShowCount))
for Show in Shows:
if Show=="":
NoDelete += "(None Listed) | "
ShowCount -= 1
else:
NoDelete += Show + " | "
print("Number of Shows Detected For Keeping: " + str(ShowCount))
print (“Shows to Keep:” + NoDelete)
Checking Delete
if Delete==“1”:
print(“Delete: Enabled”)
else:
print(“Delete: Disabled - Flagging Only”)
if OnDeck==“1”:
print(“Delete OnDeck: No”)
else:
print(“Delete OnDeck: Yes”)
Checking OS
AD = “”
if PC=="":
AD = “(Auto Detected)”
if platform.system()==“Windows”:
PC = “W”
elif platform.system()==“Linux”:
PC = “L”
elif platform.system()==“Darwin”:
PC = “L”
FileCount = 0
DeleteCount = 0
MoveCount = 0
CopyCount = 0
FlaggedCount = 0
OnDeckCount = 0
ShowsCount = 0
RescannedSections = []
Get list of sections
if PC==“L”:
print("Operating System: Linux " + AD)
import urllib2
elif PC==“W”:
print("Operating System: Windows " + AD)
else:
print(“Operating System: ** Not Configured ** (” + platform.system() + “) is not recognized.”)
exit()
if not SectionList:
URL = (“http://” + Host + “:” + Port + “/library/sections/”)
doc = xml.dom.minidom.parse(urllib2.urlopen(URL))
for Section in doc.getElementsByTagName(“Directory”):
if Section.getAttribute(“key”) not in IgnoreSections:
SectionList.append(Section.getAttribute(“key”))
SectionList.sort(key=int)
print (“Section List Mode: Auto”)
print ("Operating on sections: " + ‘,’.join(str(x) for x in SectionList))
print ("Skipping Sections: " + ‘,’.join(str(x) for x in IgnoreSections))
else:
print (“Section List Mode: User-defined”)
print ("Operating on user-defined sections: " + ‘,’.join(str(x) for x in SectionList))
Loop on sections
rescan_destination = False
for Section in SectionList:
Section = str(Section)
URL = (“http://” + Host + “:” + Port + “/library/sections/” + Section + “/recentlyViewed”)
OnDeckURL = (“http://” + Host + “:” + Port + “/library/sections/” + Section + “/onDeck”)
Setting OS Based Variables
if PC==“L”:
deck = xml.dom.minidom.parse(urllib2.urlopen(OnDeckURL))
elif PC==“W”:
doc = xml.dom.minidom.parse(urllib.request.urlopen(URL))
deck = xml.dom.minidom.parse(urllib.request.urlopen(OnDeckURL))
SectionName = doc.getElementsByTagName(“MediaContainer”)[0].getAttribute(“title1”)
print("")
print("--------- Section “+ Section +”: " + SectionName + " -----------------------------------")
Get Files for Watched Shows
changed = 0
for VideoNode in doc.getElementsByTagName(“Video”):
view = VideoNode.getAttribute(“viewCount”)
if view == ‘’:
view = 0
view = int(view)
###Find number of days between date video was viewed and today
lastViewedAt = VideoNode.getAttribute(“lastViewedAt”)
d1 = datetime.datetime.today()
d2 = datetime.datetime.fromtimestamp(float(lastViewedAt))
DaysSinceVideoLastViewed = (d1 - d2).days
###Find number of days between date video was added and today
addedAt = VideoNode.getAttribute(“addedAt”)
da2 = datetime.datetime.fromtimestamp(float(addedAt))
DaysSinceVideoAdded = (d1 - da2).days
MediaNode = VideoNode.getElementsByTagName(“Media”)
for Media in MediaNode:
PartNode = Media.getElementsByTagName(“Part”)
for Part in PartNode:
file = Part.getAttribute(“file”)
#NEW (Removed by Mustang):
#if PC == ‘L’:
#file = urllib2.unquote(file.encode(‘utf-8’)).decode(‘utf-8’)
#else:
#import urllib
#file = urllib.parse.unquote(file.encode(‘utf-8’)).decode(‘utf-8’)
if str(view)!="0":
print(" ")
if KeepMode=="W":
if str(view)!="0":
print ("Viewed:" + str(view) + "x | Days Since Viewed: " + str(DaysSinceVideoLastViewed) + " | " + file)
if view > 0:
if os.path.isfile(file):
changed += CheckShows(file);
else:
print("##[NOT FOUND] " + file)
if KeepMode=="A":
if str(view)!="0":
print ("Viewed:" + str(view) + "x | Days Since Added: " + str(DaysSinceVideoAdded) + " | " + file)
if view > 0:
else:
if KeepMode=="":
if str(view)!="0":
print ("Viewed:" + str(view) + "x | Days Since Viewed: " + str(DaysSinceVideoLastViewed) + " Added: " + str(DaysSinceVideoAdded) + " | " + file)
if view > 0:
else:
rescan this section if necessary
if TriggerRescan and changed:
URL = (“http://” + Host + “:” + Port + “/library/sections/” + Section + “/refresh?deep=1”)
blah = urllib2.urlopen(URL)
RescannedSections.append(SectionName + ‘(’ + Section + ‘)’)
rescan_destination = True
rescan destination section if necessary
if TriggerRescan and DestinationSection and rescan_destination:
URL = (“http://” + Host + “:” + Port + “/library/sections/” + str(DestinationSection) + “/refresh?deep=1”)
RescannedSections.append(’[destination dir]’ + ‘(’ + str(DestinationSection) + ‘)’)
print("")
print(" Summary – Script Completed Successfully")
print("")
print(" Total File Count " + str(FileCount))
print(" Kept Show Files " + str(ShowsCount))
print(" On Deck Files " + str(OnDeckCount))
print(" Deleted Files " + str(DeleteCount))
print(" Moved Files " + str(MoveCount))
print(" Copied Files " + str(CopyCount))
print(" Flagged Files " + str(FlaggedCount))
print(" Rescanned Sections " + ', '.join(str(x) for x in RescannedSections) )
print("")
