Thank you for the feedback. I gave up on this approach and did a full-scale copy.
An easy way to find the section ID is to look at the Plex XML info of a media item in that library.
Itās right in the first line librarySectionID="xx"
Well seeing as this whole thing seems pretty dead (in the same vain as Plex-trakt -scrobbler) is there actually any way to retrieve Plex-tokens for home users so I can set up https://github.com/jacobwgillespie/plex-sync
It works really well for myself and with a combination of this and webhooks, watch status syncing and trakt scrobbling is covered.
It would be really cool If I could get this set up for my family. But as much as I have looked there seems to be no way to get the required tokens for anyone but myself.
@dane22 tipped me off
Another way would be to use the web browser developer console, Iām told.
Awesome thanks Otto and @dane22 . I will take a look at both options.
In general, access:
https://plex.tv/api/servers?X-Plex-Token=MY-PLEX-TOKEN to get a list of your servers
Note the machineIdentifier for each server
Then query servers one by one, using:
https://plex.tv/api/servers/MACHINEIDENTIFIER/shared_servers?X-Plex-Token=MY-PLEX-TOKEN to get access token
If a user hasnāt got a name, then itās a home user, and to identify which one, use:
https://plex.tv/pms/users?X-Plex-Token=MY-PLEX-TOKEN to get a list of all your users
Thanks Tommy.
Managed to get the tokens but sadly it was all to no avail after all.
Why so?
It seems even with the tokens plex-sync refuses to work for anyone other than myself.
I wouldnt even have a clue deciphering the messages in nodeJS. Finally though it looks like that project died even earlier than all the other alternatives.
So Plex-trakt-scrobbler. Dead project but mostly still working.
Plex-Sync. Dead project but working for a single user.
Plex-db-sync. Seemingly dead also but regardless seems to require a Linux server so no idea if its working.
Never mind I live in hope that Plex or Tautulli pull something out of the bag with regards server syncing. Iām not too worried about the trakt side of things as webhhooks work great for that.
+1
what is plex team waiting for to use webhooks between Plex servers natively?
Currently, sync is only working for my account, but not all my users. didnāt tested Plex-db-sync yet.
If it may help lonewolf people, Iām using webhooks to perform updates toward trakt (with XanderStrike/goplaxt) and Plex-trakt-scrobbler in pull only mode every hour to sync back all my activities to my 2 servers. It should works for all platforms. Each time I had non-sync stuff or errors in Plex-trakt-scrobbler it was related to push actions.
What makes you say that? The GitHub repo shows a commit 17 days ago (9/2019)
Want to give me a clue or better yet a link as I mentioned three different apps?
Plex-Sync
Plex-db-sync
This still work? And can it work on Windows?
You can run it in Docker.
https://hub.docker.com/search?q=plex-db-sync&type=image
Does it work with Plex server on Windows ?
Can we get a little more detail on how to setup plex-db-sync once we have the docker installed? I have been scouring for some more details on how to get this up and going. Mainly just a breakdown of each step would be great. I have a QNAP NAS that I used Container Station to install the plex-db-sync docker. But I dont know where to go from there exactly.
Hi all, yes plex-dv-sync still works and I maintain it. Yes it works with Windows. I donāt really follow this forum, but happy to answer stuff on GitHub.
I keep it running, but my end goal is to work on the ticket for Jellyfin porting the database out from Sqlite to MariaDB so that multiple server sync can be a native feature there. Big advantage of FOSS.
