Hello,
Sorry that it has been a while. I just tried your latest update and it didn’t work. Here is the log on the master.
2016-08-16 22:47:38,324 - prt - INFO - Host with minimum load is ‘192.168.0.205’
2016-08-16 22:47:38,324 - prt - INFO - Using transcode host ‘192.168.0.205’
2016-08-16 22:47:38,325 - prt - INFO - Launching transcode_remote with args [‘ssh’, u’plex@192.168.0.205’, ‘-p’, u’22’, u’export LANG=en_US.UTF-8;export PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/var/lib/plexmediaserver/Library/Application Support;export SHELL=/bin/bash;export XDG_DATA_HOME=/usr/lib/plexmediaserver/Resources/;export XDG_CACHE_HOME=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/;export X_PLEX_TOKEN=1HjpRCeyTpMsvvDAqxcf;export PLEX_MEDIA_SERVER_HOME=/usr/lib/plexmediaserver;export PWD=/;export LOGNAME=plex;export USER=plex;export FFMPEG_EXTERNAL_LIBS=/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/ecd8c57-1099-linux-ubuntu-x86_64/;export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin;export HOME=/var/lib/plexmediaserver;export PLEX_MEDIA_SERVER_TMPDIR=/tmp;export LD_LIBRARY_PATH=/usr/lib/plexmediaserver;export PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6;export PRT_ID=f523301e642411e6ad0f50b7c3708c10;cd /opt/plex/tmp/plex-transcode-ujnbd3adp5nwvplsf07ctyb9-ca54fecd-0e79-4087-98da-5ac9d5a4eb9b;prt_local -codec:0 mpeg4 -ss 1313.77698 -i ‘/media/zack/Zack(Home)/TV Shows/Hogan’"’"‘s Heroes/Hogan’"’"‘s Heroes Season 1/Hogan’"’"‘s Heroes S01E07 - German Bridge Is Falling Down.avi’ -filter_complex ‘[0:0]scale=w=min(608\,iw):h=min(448\,ih):force_original_aspect_ratio=decrease[0]’ -map ‘[0]’ -codec:0 libx264 -crf:0 16 -pix_fmt:0 yuv420p -maxrate:0 2260k -bufsize:0 4520k -r:0 23.975999999999999 -preset:0 veryfast -x264opts:0 subme=2:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -map ‘0:#0x01’ -codec:1 copy -copypriorss:1 0 -f matroska -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 - -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://192.168.0.200:32400/video/:/transcode/session/ujnbd3adp5nwvplsf07ctyb9/progress’]
2016-08-16 22:47:39,150 - prt - INFO - Transcode stopped on host ‘192.168.0.205’
And the log on the slave.
2016-08-16 22:47:38,998 - prt - INFO - Launching transcode_local: [’/usr/lib/plexmediaserver/Resources/plex_transcoder’, ‘-codec:0’, ‘mpeg4’, ‘-ss’, ‘1313.77698’, ‘-i’, “/media/zack/Zack(Home)/TV Shows/Hogan’s Heroes/Hogan’s Heroes Season 1/Hogan’s Heroes S01E07 - German Bridge Is Falling Down.avi”, ‘-filter_complex’, ‘[0:0]scale=w=min(608\,iw):h=min(448\,ih):force_original_aspect_ratio=decrease[0]’, ‘-map’, ‘[0]’, ‘-codec:0’, ‘libx264’, ‘-crf:0’, ‘16’, ‘-pix_fmt:0’, ‘yuv420p’, ‘-maxrate:0’, ‘2260k’, ‘-bufsize:0’, ‘4520k’, ‘-r:0’, ‘23.975999999999999’, ‘-preset:0’, ‘veryfast’, ‘-x264opts:0’, ‘subme=2:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none’, ‘-map’, ‘0:#0x01’, ‘-codec:1’, ‘copy’, ‘-copypriorss:1’, ‘0’, ‘-f’, ‘matroska’, ‘-avoid_negative_ts’, ‘disabled’, ‘-map_metadata’, ‘-1’, ‘-map_chapters’, ‘-1’, ‘-’, ‘-start_at_zero’, ‘-copyts’, ‘-y’, ‘-nostats’, ‘-loglevel’, ‘quiet’, ‘-loglevel_plex’, ‘error’, ‘-progressurl’, ‘http://192.168.0.200:32400/video/:/transcode/session/ujnbd3adp5nwvplsf07ctyb9/progress’]
Thank you.
