Plex Remote Transcoder - A distributed transcoding backend for Plex
Hi all,
I just stumbled across this, and I have been searching for a solution like this for ages now. Thank you wnielson!
I was just wondering if in a future release if it is possible to implement a sleep mode for the slave when the slave is idle. This should be woken up when there is a need for it. Let me try to illustrate what I have in mind:
PMS-> wake up slave 1.
Slave 1 run with >90% CPU for 1 min. then wake up slave 2.
Slave 2 run with >90% CPU for 1 min. then wake up slave 3.
Etc until you have no more slaves.
When going to sleep:
Slave 3 run with <10% CPU for 10 min. then go to sleep.
Slave 2 run with <10% CPU for 10 min. then go to sleep.
Slave 1 run with <10% CPU for 10 min. then go to sleep.
Now this constellation requires that the cache/buffer is set to 3-4 mintues in order to have some time to wake another slave, so the user(s) do not experience any degradation nor lag.
Now let me make one thing 100% clear I am NOT a developer. I am just an ā€œidiotā€ with strange ideas. :wink: (and too many computers at home)
/Teddy
would be a fun project for a huge stack of raspberry pi 3 boards if gpus could be utilized.
with current 1.9.7 version PMS which release is ok or which project github is working and active for remote plex transcoding?
The current latest version works on the latest PMS version.
is possible to change uid from plex user on master server because on slave when i create user the uid is already used on other as i see from nfs i am asking if is possible to change uid from master server to some else and then create plex user with the same uid on slave…
thanks
does anyone know? :stuck_out_tongue:
Did anyone tested with the v1.11.0.4666 ? :slight_smile:
Tested working on 1.11.1.4730, however plex VR does NOT work with it at all, comes back unable to connect.
Some quick questions:
  1. If you install PRT with no clients, or if clients cannot be reached it will still transcode locally?
  2. . If you are using /dev/shm for the transcoder temp directory, would you share this out, and does one think it would become a problem with multiple clients writing to it?
Yes. The master is always a fallback transcoder.
  1. . If you are using /dev/shm for the transcoder temp directory, would you share this out, and does one think it would become a problem with multiple clients writing to it?
I’ve never tried network sharing the shared memory device before. I suppose it’ll work but it is untested.
I’ve been trying to get PRT to work master salve… I keep getting
JobManager: child process returned: 1 (Operation not permitted)
Jobs: ā€˜/usr/lib/plexmediaserver/Plex Transcoder’ exit code for process 2725 is 1
no other errors and the web browser that I started the movie will wait forever till i stop it. If I put the original Plex Transcoder back it works fine…
I just setup a spare server tonight, and installed PRT on the master. I need to change the transcoding directory and then setup a client transcoder and see how it works.
Theoretically the number of transcodings wont change anymore than what they are now. The processing load would just spread out, although if the number of transcodings were to go up I suppose I could run into an issue.
Thanks!
So I got it working without using /dev/shm as the transcoding directory, but the minute I switched to /dev/shm, and update my mounts, it quit working.
In the logs I see the transcode request sent, and a second later I see the Transcode stopped message.
So looks like I have to decide between writing to /dev/shm or using separate hosts for transcoding.
Thanks!
I have PRT working now. I’ve set the slaves to sleep if there is no activity. I can send a WOL command from the terminal and wake each one up. Would like to add that command into PRT, so when it needs the additional processing power it could wake up the node on its own, just not sure how to go about doing that. Any pointers would be greatly appreciated.
Good Evening.
Can you use prt on a CentOS 7 setup using a xfs files system or does prt require nfs?
You can use it on CentOS… but I don’t know of anyone that actually has gotten it to work per say on it. It was developed for ubuntu and works quite well on that.
Filesystem wise, it does not matter, you will just be sharing out the folders as exports, so the underlying FS does not really matter.
I tried to install it on Centos 7… PMS worked just fine but PRT would not work. The problem seemed to be that PRT would create the transcode job but Centos would report,
With no other errors… And PMS would just keep acting as if everything was fine. The client that started the video would just keep waiting for it to start till it was manually stopped.
Hope this information helps you find an answer.
Why doesn’t hardware transcodeing work when the slaves are identical to the master?
Is this project still being developed?
Hi, I dont know if this as been already anwsered but i’m planning to move my instalation to Unraid OS and I was wondering if I can make PRT working through a docker ? Otherwise I think a Ubuntu server VM can be a work around.
