Hello everyone, I used 2 physical machines with ubuntu server and prt. I can see the transcoding process on the slave for each streaming but it is not working on the server. Even if I added 127.0.0.1 via prt add_host all transcoding session keep going to the slave. Any idea ?
@archangel00 said:
sounds interesting, would be keen to see how the Windows development come along
Just another monthly âWindows Please!â ping
@matdesmarais said:
@an3k I tried to decompile and ended up with lots of unreadable code.Idealy Plex should take on this development. Anyone know the best way to approach them about this?
You are correct, they should, especially since the transcoder is already a separate process and could easily be made to run from slave nodes by them without much effort on their part at all. Basically, they are already creating slaves nodes, just locally on the same machine. The fact that they still have not made the Windows version run as a service instead of the dinky tray application probably precludes that they wonât be getting to it anytime soon.
The problem stems from the fact that the code base came from XBMC which runs from a single computer or instance, so that is likely their target market and most of the casual users with small libraries make up the majority so these more advanced pro like features are way less of a priority, if at all. If it could be added as an extra paid pro addon or something they might consider it.
They have done a great job so far with it, I would just like to see it taken to the next level. With x265, the need to spawn new trancoding nodes is even greater.
@segator said:
guys do you know if exist any way to control which user request the transcoding? i would like to deny transcoding to some users or atless no video transcoding only audio and remuxing.
and If you finally relĂ©ase your script to digitalocean autodeployment machine if you want i can make dockerâs to be very easy installation for the mass
Hey,
Unfortunately as far as I know the decision process for how/what gets transcoded is taken care of prior to prt gets its hands on the stream so any decisions made by prt is likely to be considered an error by plex as it expects things to be transcoded if the request has been made and thus likely to throw up an error if you start forcing (if at all possible at that point as) direct streaming. I could be wrong but even if Iâm wrong it would likely be quite a chunk of r&d to achieve it. Itâs not an option I have really thought about personally at this point. Iâm happy to put it in a list of things to consider but until either I look into it more or someone points out something which will help achieve it id say it would be unlikely considering what Iâve said and how plex is currently built.
Hey,
Thatâs quite unusual, from when I first started pulling plex & prt apart trying to get things to work I found the opposite. As in when I played with the code and broke things the stream would always default to local rather than to the slave. My initial guess would be that because what prt does is check to see which system had the lowest amount of load on it then allocate the transcoding stream to that system itâs likely your slave is less loaded that the master. Prt takes into account how many cores each system had when it does its decision. If you search of prt.log you should see it state that itâs deciding to use a system on a load basis. If you have multiple streams going with the master in the config as a slave (127.0.0.1) it should use it as well. On each system if you run âprt get_loadâ even with no transcodes running you should get 3 numbers which are a percentage out of 100. Is the remote slave less than the local slave aka the master?
@alternativesurfer said:
@archangel00 said:
sounds interesting, would be keen to see how the Windows development come alongJust another monthly âWindows Please!â ping
A windows port is likely to be a considerable way off, I would suggest you look at migrating to linux either to a physical system or a virtual guest (using something like virtualbox). Linux is much more stable & less overhead than windows, even if youâve never used linux before I would expect you will get it working that way in a much shorter time than waiting for a port.
I actually ran both side by side utilizing the same media storage and for whatever reason the Linux version was always behind or wouldnât find certain items compared to the Windows version. Of course, that was early on when they first released so hopefully it does a better job now as it seems their core development is Windows. Maybe I will spin up another instance and see how it works out now to compare.
@matdesmarais said:
@an3k @saitoh183 I have a exe drop in replacement for plexnewtranscoder.exe that currently captures all flags passed to it and dumps them to a log text file for analysis.
Combine this with FFServer/FFMPEG and you probably have 99.99% of the code.
I am sure all they did was wrap the code to convert commands from PMS to FFServer CLI options. Hell, it might even just be a straight compile and they are just spawning it with CLI options for that matter.
Currently, there is no builtin way to do this. However, there might be a way you can hack it together. The first issue is that PRT does not receive details about who is requesting the file, only what file is requested. Plex has a sessions endpoint that letâs you see what file is being played and by whom. In PRT you can define the path_script config variable which is a user-defined script that is passed the full path to the requested file. So, you could try writing a simple script that reads in the path, checks the Plex sessions and figures out which user is requesting the file. If you deem that user unworthy, then the script can return a fake file path, which will cause the transcoder to fail and no video will play back.
Like I said, this is pretty hacky, but it might just work. Good luck!
Just as suspected, all they are doing is calling the Plex New Transcoder via command-line and almost all options are a direct correlation to FFMPEG with a few of their own sprinkled in there. : )
/usr/lib/plexmediaserver/Resources/Plex New Transcoder -noaccurate_seek -i /media/movies/Adventure/10,000 BC (2008).mkv -map 0:0 -metadata:s:0 language=eng -codec:0 copy -bsf:0 h264_mp4toannexb,h264_plex -map 0:1 -metadata:s:1 language=eng -codec:1 aac -strict:1 experimental -cutoff:1 15000 -channel_layout:1 stereo -b:1 256k -f matroska -avoid_negative_ts disabled -map_metadata -1 - -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/1mkofa7z2ofajor/progress
There is your file and session info as well.
@Jusedawg said:
Just as suspected, all they are doing is calling the Plex New Transcoder via command-line and almost all options are a direct correlation to FFMPEG with a few of their own sprinkled in there. : )/usr/lib/plexmediaserver/Resources/Plex New Transcoder -noaccurate_seek -i /media/movies/Adventure/10,000 BC (2008).mkv -map 0:0 -metadata:s:0 language=eng -codec:0 copy -bsf:0 h264_mp4toannexb,h264_plex -map 0:1 -metadata:s:1 language=eng -codec:1 aac -strict:1 experimental -cutoff:1 15000 -channel_layout:1 stereo -b:1 256k -f matroska -avoid_negative_ts disabled -map_metadata -1 - -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/1mkofa7z2ofajor/progress
That is completely correct, that is how it passes itâs information around. I am a little confused thoughâŠwas this just a general âhey, FYI I found thisâ? or are you responding to a particular comment/question? If itâs the latter itâs kind of hard to follow if youâre not quoting or mentioning the original item in your comment.
@wnielson said:
@segator said:
guys do you know if exist any way to control which user request the transcoding? i would like to deny transcoding to some users or atless no video transcoding only audio and remuxing.Currently, there is no builtin way to do this. However, there might be a way you can hack it together. The first issue is that
PRTdoes not receive details about who is requesting the file, only what file is requested. Plex has a sessions endpoint that letâs you see what file is being played and by whom. InPRTyou can define thepath_scriptconfig variable which is a user-defined script that is passed the full path to the requested file. So, you could try writing a simple script that reads in the path, checks the Plex sessions and figures out which user is requesting the file. If you deem that user unworthy, then the script can return a fake file path, which will cause the transcoder to fail and no video will play back.Like I said, this is pretty hacky, but it might just work. Good luck!
Itâll be interesting to see how PMS reacts to thatâŠbecause if itâs expecting transcoding across both video/audio you might just get a fail if it doesnât get what it expects on the client end.
Iâm actually interested what the logic is behind having the users able to access your library yet not allowed to transcode video but only audio. Apart from sheer curiosity, if we were to understand the reasoning behind it, perhaps thereâs another path to what youâre trying to achieve rather than going down this path.
Yeah, I was mostly answering myself. : ) I donât like how you have to quote everything in here instead of just being able to reply to a particular post. I was also referring to the direct previous post above it. Sorry about that.
Iâve been able to get PRT working perfectly with three remote Ubuntu VMâs for local network and remote network transcoding. Thanks for this awesome feature add! An issue Iâm running into is that when I attempt to sync content, no transcoders seem to get chosen to handle the task and the sync job fails.
Any thoughts? Server Version 0.9.15.1
Virtualbox + Ubuntu 14.04 on my Windows 10 physical works great as a third transcode server. Took about 15 minutes to install/configure and it was golden. Almost as easy as the vmware guests that are the other two transcoders.
@jclifton said:
Iâve been able to get PRT working perfectly with three remote Ubuntu VMâs for local network and remote network transcoding. Thanks for this awesome feature add! An issue Iâm running into is that when I attempt to sync content, no transcoders seem to get chosen to handle the task and the sync job fails.Any thoughts? Server Version 0.9.15.1
Hey there @jclifton ,
I have a couple of ideas because I suspect that the sync transcoder is hitting one of the bugs/features from plex that Iâve seen and is on my list of things to either add into the code or change the setup to ensure thereâs a work around in placeâŠ
Before setting up my crash & burn environment to replicate what youâve described I checked something to see if my hypothesis is correct and it would appear soâŠ
Iâm guessing you donât get your systems to generate the image index files for your videos do you? Otherwise you would have noticed a similar issue during that process.
I think the issue youâre seeing is that while you have the option in the plex server setting of where you can set your âTranscoder temporary directoryâ, that only by default seems to apply for live transcoding (e.g. streams to players) and thereâs another couple of transcoding types which donât use it by default (thanks plex for not keeping everything the same!).
SoâŠhow to manually work around it (and Iâm still mulling over if thereâs a better way of doing this as I donât like leaving that whole tree RW)
In the guide it says for the NFS sharing you only need /opt/plex/tmp shared as rw but then Iâve noticed that the bif generation fails and as youâve described so would sync as they seem to use the same separate area.
Instead of in /etc/exports having this :
/var/lib/plexmediaserver 192.168.0.3(ro,sync,no_subtree_check)
Have this :
/var/lib/plexmediaserver 192.168.0.3(rw,sync,no_subtree_check)
Which is changing the ro to rw
then re-export your shares and on your slaves you can just do a
mount -o rw,remount /var/lib/plexmediaserver
Hereâs an example of a sync I just ran and where PRT was directing the transcode (by plexâs request) :
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+/4033693/da/70356.mp4.temp
Hopefully that gets your back running again and Iâll chew on this a bit more and see if I canât come up with a more elegant solution that changing that whole share to RW moving forward.
Cheers,
Liviy
(P.S. excuse all the edits as itâs still early and I think I need another coffee!
I think the issue youâre seeing is that while you have the option in the plex server setting of where you can set your âTranscoder temporary directoryâ, that only by default seems to apply for live transcoding (e.g. streams to players) and thereâs another couple of transcoding types which donât use it by default (thanks plex for not keeping everything the same!).SoâŠhow to manually work around it (and Iâm still mulling over if thereâs a better way of doing this as I donât like leaving that whole tree RW)
Have this :
Which is changing the ro to rwthen re-export your shares and on your slaves you can just do a
mount -o rw,remount /var/lib/plexmediaserverHereâs an example of a sync I just ran and where PRT was directing the transcode (by plexâs request) :
Cheers,
Liviy
(P.S. excuse all the edits as itâs still early and I think I need another coffee!)
Wow thank you for such a quick turn around! Interestingly enough, that resolution didnât work for me. I made the rw change, bounced nfs, remounted slaves (even rebooted as a test) and still the sync function doesnât work.
Hey @jclifton
No worries!
InterestingâŠIâm quite shocked it didnât work as I have the same setup as yourself, including the PMS version. Only difference is Iâve come across some issues with PMS like this and have applied fixes. To try and help you can you gather some information for me please?
On the master, (for the first command as root or use sudo but the rest can be as plex user) run :
exportfs -v
ls -la /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Cache/Transcode/Sync\+/
tail -100 /opt/plex/tmp/prt.log
tail -100 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\Server.log
on one of the slaves, (as plex user) run :
cd /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Cache/Transcode/Sync\+/
df -h .
touch writetest && rm -f writetest
I donât mean to sound patronising but if I was to make a guess it is that something didnât work correctly with the rw export or you got the /usr/lib/plexmediaserver and the /var/lib/plexmediaserver mounts mixed up (I really despise plexâs decisions on where they keep their application files).
Hopefully the output from the above commands should shed some light on the issue. Feel free to PM me rather than spamming this thread if you wish. Or alternatively log an issue at :
github.com/wnielson/Plex-Remote-Transcoder/issues
Cheers,
Liviy
@liviy said:
Hey @jclifton
No worries!
exportfs -v
tail -100 /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\Server.logon one of the slaves, (as plex user) run :
df -h .
touch writetest && rm -f writetestI donât mean to sound patronising but if I was to make a guess it is that something didnât work correctly with the rw export or you got the /usr/lib/plexmediaserver and the /var/lib/plexmediaserver mounts mixed up (I really despise plexâs decisions on where they keep their application files).
github.com/wnielson/Plex-Remote-Transcoder/issuesCheers,
Liviy
Much appreciated. DM incoming!
Just to follow up with everyone watching. I fail. My CIFS mount to the freenas host I use for storage was dying on the slaves for some reason. Got that sorted out and then @liviyâs solution worked flawlessly.
-1 for me today.
