Plex Server is unavailable after power outage
okay, will try this with the current (newly corrupted) appdata plex folder and post logs again.
restored the most recent appdata plex folder (corrupted) back, edited the version of the docker, and started the container. now, i’m back to the newly created instance after the power outage, and the original instance (six years old) is no where in the options for selection!
here’s the a tar.gz of entire logs folder.
Logs.tar.gz (2.0 MB)
anyone able to chime in about this?
It’s difficult to see exactly what happened.
You turned DEBUG logging off but I do see the BLOBS DB has a problem
Aug 04, 2025 21:49:04.731 [23190140943160] WARN - [Req#b110dc] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Aug 04, 2025 21:52:06.089 [23190101875512] INFO - [Req#b1138f] SQLITE3:0x80000001, 17, statement aborts at 102: [INSERT INTO blobs (`linked_type`,`linked_id`,`linked_guid`,`blob_type`,`created_at`,`blob`) VALUES (:U1,:U2,:U3,:U4,:U5,:U6) ON CONFLICT(`linked_type`,`linked_id`,`blob_type`) DO UPDATE SET `linked_guid`=excluded.`linked_guid`,`created_at`=excluded.`created_at`,`blob`=excluded.`blob` RETURNING `id`] database schema has changed
Aug 04, 2025 21:52:06.091 [23190101875512] INFO - [Req#b1138f] SQLITE3:0x80000001, 17, statement aborts at 8: [SELECT LENGTH(bl.`blob`) FROM blobs bl WHERE bl.`id`=:C1] database schema has changed
Aug 04, 2025 21:54:15.783 [23190132525880] WARN - [Req#b116fb/Transcode] Got a request to stop a transcode session without a valid session GUID.
Aug 04, 2025 22:05:17.386 [23190105975608] INFO - It's been 86535 seconds, so we're starting scheduled library update for section 1 (Movies)
Aug 04, 2025 22:26:06.259 [23190140943160] WARN - [Req#b134e7/Transcode] Got a request to stop a transcode session without a valid session GUID.
Aug 04, 2025 22:45:17.394 [23190148311864] INFO - It's been 86400 seconds, so we're starting scheduled library update for section 6 (7othala)
Aug 05, 2025 00:15:46.255 [23191878351672] WARN - [HttpClient/HCl#81c94] HTTP error requesting GET https://77-69-210-196.ea1ae628a1a6477eb1ca1ede4de
It shouln’t take days of running to hit this. It should be found almost immediately after upgrading PMS..
I think DBRepair can help with this.
okay, seems to be back after updating and dbrepair but no thumbnails for older imported files, just the newly added ones.
pump, anyone
Sorry I missed this.
Did you do the Multi-select, Analyze for those missing thumbs?
Chapter Thumbs will generate during nightly maintenance (presuming it runs long enough)
