PMS 1.29.1 HW Tonemapping Testing, Questions , and Answers
With this new version PMS 1.29.1.6260 the tone mapping does not work for me. I’m running on Ubuntu 22.04.1 and I have a J4105 processor. In order for tone mapping to work in the current stable version I had to install beignet-opencl-icd_1.3.2 myself.
I’ve gone back to 1.29.0 and it’s working fine again.
@Cfl
I need your PMS logs which captures the failure PRIOR to installing Beignet.
I’ve tested this on everything from KabyLake up through CometLake (desktop and NAS) without anything failing.
FYI: Ubuntu 22.04.1 does not offer Beignet. Intel withdrew all that with the launch of 22.04
[chuck@NUC10i5FNK Plex Media Server.252]$ apt list | grep -i beignet
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
[chuck@NUC10i5FNK Plex Media Server.253]$
For the purposes of confirming that it’s not using any of the old libraries, this is my NUC11 transcoding 4K HDR10 to 1080P SDR H.264. Specifically, lsof against the transcoder process running under plex.
The only access I see is to the files in the drivers folder. I’ve redacted the IPs and a few other small things, nothing relevant to this.
plex@plex:~$ lsof -p 65822
COMMAND     PID USER   FD      TYPE             DEVICE   SIZE/OFF      NODE NAME
Plex\x20T 65822 plex  cwd       DIR              259,2      20480  28967069 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-f53352464zbtqpi5ik9asfak-194e5bce-c234-4a36-bbf7-f4196b68db51
Plex\x20T 65822 plex  rtd       DIR              259,2       4096         2 /
Plex\x20T 65822 plex  txt       REG              259,2     322920  34868062 /usr/lib/plexmediaserver/Plex Transcoder
Plex\x20T 65822 plex  mem       REG               0,13                14490 anon_inode:i915.gem (stat: No such file or directory)
Plex\x20T 65822 plex  mem       REG              259,2  502595768  18220288 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Drivers/icr-9-linux-x86_64/libigc.so.1.0.1
Plex\x20T 65822 plex  mem       REG              259,2   71783176  18220283 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Drivers/icr-9-linux-x86_64/libopencl-clang.so.11
Plex\x20T 65822 plex  mem       REG              259,2   13014752  18220434 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Drivers/icr-9-linux-x86_64/libigdfcl.so.1.0.1
Plex\x20T 65822 plex  mem       REG              259,2    1152880  34868104 /usr/lib/plexmediaserver/lib/libc++.so.2
Plex\x20T 65822 plex  mem       REG              259,2  129576896  18220436 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Drivers/icr-9-linux-x86_64/libigdrcl.so
Plex\x20T 65822 plex  mem       REG              259,2     757520  34868091 /usr/lib/plexmediaserver/lib/libigdgmm.so.plex
Plex\x20T 65822 plex  mem       REG              259,2   32665376  34868110 /usr/lib/plexmediaserver/lib/dri/iHD_drv_video.so
Plex\x20T 65822 plex  mem       REG              259,2    1675816  19661386 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libh264_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2    1565664  19661385 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libhevc_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2     143688  19661384 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libac3_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2    1790024  19661383 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/liblibx264_encoder.so
Plex\x20T 65822 plex  mem       REG              259,2     200520  19661382 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libaac_encoder.so
Plex\x20T 65822 plex  mem       REG              259,2     131752  19661187 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libmp2_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2     897640  19661186 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libmpeg4_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2     630584  19661185 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libmsmpeg4v3_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2    1256784  19661184 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libvc1_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2     675552  19661183 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libmpeg2video_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2     222040  19661182 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/liblibmp3lame_encoder.so
Plex\x20T 65822 plex  mem       REG              259,2     304912  19661180 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libdca_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2     131752  19661179 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libmp3_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2     278600  19661178 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/c4efa15-4387-linux-x86_64/libaac_decoder.so
Plex\x20T 65822 plex  mem       REG              259,2      35576  34868097 /usr/lib/plexmediaserver/lib/libpciaccess.so.0
Plex\x20T 65822 plex  mem       REG              259,2      79408  34868118 /usr/lib/plexmediaserver/lib/libdrm.so.2
Plex\x20T 65822 plex  mem       REG              259,2       9040  34868125 /usr/lib/plexmediaserver/lib/libva-drm.so.2
Plex\x20T 65822 plex  mem       REG              259,2     165360  34868131 /usr/lib/plexmediaserver/lib/libva.so.2
Plex\x20T 65822 plex  mem       REG              259,2     711448  34868077 /usr/lib/plexmediaserver/lib/libavutil.so.56
Plex\x20T 65822 plex  mem       REG              259,2     769480  34868130 /usr/lib/plexmediaserver/lib/libswscale.so.5
Plex\x20T 65822 plex  mem       REG              259,2     146064  34868100 /usr/lib/plexmediaserver/lib/libswresample.so.3
Plex\x20T 65822 plex  mem       REG              259,2    4337816  34868129 /usr/lib/plexmediaserver/lib/libavcodec.so.58
Plex\x20T 65822 plex  mem       REG              259,2    5073424  34868067 /usr/lib/plexmediaserver/lib/libavformat.so.58
Plex\x20T 65822 plex  mem       REG              259,2    7974584  34868098 /usr/lib/plexmediaserver/lib/libavfilter.so.7
Plex\x20T 65822 plex  mem       REG              259,2      58688  34868121 /usr/lib/plexmediaserver/lib/libgcompat.so.0
Plex\x20T 65822 plex  mem       REG              259,2     747264  34868102 /usr/lib/plexmediaserver/lib/ld-musl-x86_64.so.1
Plex\x20T 65822 plex    0r      CHR                1,3        0t0         5 /dev/null
Plex\x20T 65822 plex    1u     unix 0x0000000000000000        0t0    984549 type=STREAM
Plex\x20T 65822 plex    2u     unix 0x0000000000000000        0t0    984549 type=STREAM
Plex\x20T 65822 plex    3u     IPv4            1640864        0t0       TCP localhost:40756->localhost:32400 (ESTABLISHED)
Plex\x20T 65822 plex    4u      CHR            226,128        0t0       351 /dev/dri/renderD128
Plex\x20T 65822 plex    5r      REG               0,59 8917735613 146728119 REDACTED.mkv
Plex\x20T 65822 plex    6w      REG              259,2          0  28968745 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-f53352464zbtqpi5ik9asfak-194e5bce-c234-4a36-bbf7-f4196b68db51/chunk-stream0-00320.m4s.tmp
Plex\x20T 65822 plex    7u     IPv4            1637836        0t0       TCP plex:36268->REDACTED:https (ESTABLISHED)
Plex\x20T 65822 plex    8w      REG              259,2          0  28968746 /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-f53352464zbtqpi5ik9asfak-194e5bce-c234-4a36-bbf7-f4196b68db51/chunk-stream1-00320.m4s.tmp
Plex\x20T 65822 plex    9u      CHR            226,128        0t0       351 /dev/dri/renderD128
Plex\x20T 65822 plex   60u     IPv4             990222        0t0       TCP localhost:32898->localhost:41729 (ESTABLISHED)
Plex\x20T 65822 plex   61u     IPv4             990223        0t0       TCP localhost:41729->localhost:32898 (ESTABLISHED)
Plex\x20T 65822 plex   67u  netlink                           0t0    989546 ROUTE
Plex\x20T 65822 plex   70u     IPv4            1585382        0t0       TCP plex:54104->REDACTED:32400 (ESTABLISHED)
Plex\x20T 65822 plex   84u     IPv4             981990        0t0       TCP plex:46026->REDACTED:https (ESTABLISHED)
This may be out of scope, I apologize if so. Will 1.29,1 address hardware transcoding with NVidia GPUs as well?
Not out of scope at all.
I didn’t know there was a problem with Nvidia GPUs.
I use a P2200 without any issues whatsoever. Our Lab NAS has a GT1050 which we use for all QA testing.
Please feel free to create a new thread, explain what’s happening, attach your server logs which capture it.
Then ping me @chuckpa
Can anyone confirm that hw tone mapping works with v1.29.1 using linuxserver.io docker repo?
I’m using Beelink U59 Pro (N5015-processor).
Ideally I’d like to run Plex in LXC (Proxmox) with HW transcoding support, but I’m having major issues getting iGPU working with Plex or with anything with that matter, except perhaps for Windows. So before I proceed to that, I’ve been fiddling more directly with the hardware, ie. Ubuntu server directly on it without proxmox or anything like that.
I’m getting age old errors, which I assume shouldn’t be anymore receiving:
plex h264_vaapi @ 0x7f14c68c7b40] Driver does not support any RC mode compatible with selected options (supported modes: CQP).
I have plex pass, hw transcoding is enabled, but as seen from above, it is not being used.
Currently I’m running vanilla installation with only latest Ubuntu server 22.04.1 and latest plex 1.29.1.6260-420892357
It does. Using the linuxserver Plex docker on Unraid 6.11 and it’s working as it should.
I use the official Plex docker under unRAID, I presume no action is needed ?
Version PMS 1.29.0.6244
Logs with beignet::
Plex Media Server Logs_2022-09-30_14-56-37.zip (346.7 KB)
Logs without beignet:
Plex Media Server Logs_2022-09-30_14-57-48.zip (369.0 KB)
@Cfl
You turned off DEBUG logging so the logs are of little use.
HOWEVER,
  1. With PMS 1.29.1, it recognized the QSV ASIC as GeminiLake and prepared the driver.
Sep 29, 2022 20:38:37.358 [0x7f4a7a5fcb38] INFO - Plex Media Server v1.29.1.6260-420892357 - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT 02:00
Sep 29, 2022 20:38:37.359 [0x7f4a7a5fcb38] INFO - Linux version: 22.04.1 LTS (Jammy Jellyfish), language: en-US
Sep 29, 2022 20:38:37.359 [0x7f4a7a5fcb38] INFO - Processor: 4-core Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
Sep 29, 2022 20:38:37.359 [0x7f4a7a5fcb38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Sep 29, 2022 20:38:37.359 [0x7f4a7a5fcb38] INFO - /usr/lib/plexmediaserver/Plex Media Server
Sep 29, 2022 20:38:37.453 [0x7f4a7f49c6f0] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Sep 29, 2022 20:38:37.591 [0x7f4a7f49c6f0] INFO - Running migrations. (EPG 0)
Sep 29, 2022 20:38:37.839 [0x7f4a7f49c6f0] INFO - Running migrations. (EPG 0)
Sep 29, 2022 20:38:37.921 [0x7f4a783d3b38] INFO - Preemptively preparing driver icr for GPU GeminiLake [UHD Graphics 600]
Sep 29, 2022 20:38:38.438 [0x7f4a77ec6b38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Sep 29, 2022 20:38:38.438 [0x7f4a77ec6b38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Sep 29, 2022 20:38:38.488 [0x7f4a7748fb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Sep 29, 2022 20:38:38.488 [0x7f4a7748fb38] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Sep 29, 2022 20:38:39.340 [0x7f4a7728cb38] WARN - Crash: Crash reporting disabled
  1. You have permission problems accessing some of your media.
Sep 29, 2022 22:25:43.075 [0x7f32fcd16b00] ERROR - IsDirectory failed boost::filesystem::status: Permission denied: "/media/Nas/Fotos/Camara Elena/PICT0001.jpg"
Sep 29, 2022 22:25:43.168 [0x7f32fcd16b00] ERROR - IsDirectory failed boost::filesystem::status: Permission denied: "/media/Nas/Peliculas/300 [4K UHDremux][2160p][HDR10][DTS-HD 5.1 Castellano-AC3 5.1-Ingles+Subs][ES-EN]/Peliculas y Series estrenos gratis - atomixhq.one.URL"
When you have an opportunity:
  1. Enable DEBUG logging
  2. Install 1.29.1
  3. Retest
  4. Download logs of a failed session,
  5. Attach the ZIP
New logs with PMS 1.29.1
Plex Media Server Logs_2022-09-30_17-56-42.zip (789.0 KB)
@ChuckPa
Version 1.29.0.6244
binaryjay@binaryplex:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server$ ls -l
total 44
drwxr-xr-x  6 plex plex 4096 Sep 30 11:36  Cache
drwxr-xr-x  4 plex plex 4096 Sep 29 16:07  Codecs
drwxr-xr-x 12 plex plex 4096 Sep 29 16:07 'Crash Reports'
drwxr-xr-x  2 plex plex 4096 Jun 23 02:01  Diagnostics
drwxr-xr-x  3 plex plex 4096 Sep 30 04:03  Logs
drwxr-xr-x  3 plex plex 4096 Jun 17 16:26  Media
drwxr-xr-x  6 plex plex 4096 Jun 17 16:44  Metadata
-rw-r--r--  1 plex plex    3 Sep 29 16:51  plexmediaserver.pid
drwxr-xr-x  2 plex plex 4096 Jun 17 16:15  Plug-ins
drwxr-xr-x  7 plex plex 4096 Jun 17 16:18 'Plug-in Support'
-rw-r--r--  1 plex plex 1046 Sep 30 02:46  Preferences.xml
binaryjay@binaryplex:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server$ cat /etc/os-release
PRETTY_NAME="Ubuntu 22.04.1 LTS"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04.1 LTS (Jammy Jellyfish)"
VERSION_CODENAME=jammy
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=jammy
Definitely no Drivers folder being created here. Is there something I can search for myself in logs when it is supposed to attempt to create this? I can’t get to attaching them right now.
No luck here
See the logs
Plex Media Server Logs_2022-09-30_18-17-41.zip (2.0 MB)
@BinaryJay
PMS 1.29.0 – No Drivers directory
PMS 1.29.1 – Has Drivers directory
(As stated in my OP) :slight_smile:
@ChuckPa Ah, crap! I’m sorry… I totally missed the .1 and just saw 6240 and thought “yep, 6244 is higher than 6240”.
By the way, installing the proper version it works fine. Drivers folder is created and tone mapping with HW reported is working again. Thanks!
@Cfl
Thank you. I see the HEVC - MPEG2TS stream fail.
Might you be able to cut off a snip of the file (10-15 MB or so) using dd so I may include it with the trouble report?
This is very unexpected. I’ve not seen it fail this way before.
Here is the file…
sample.zip (14.8 MB)
But this happens with any HEVC HDR video.
Thanks for your time.
@Cfl
Thank you for the sample.
Your CPU is a Gemini Lake and those are the easiest thing to make work along with KabyLake/ApolloLake. There are no surprises with the CPU. It’s super stable.
I do think there’s a problem with the host itself.
I would like to know where and how you installed Beignet on Ubuntu 22.04 when neither Canonical nor Intel provide beignet-opencl-icd in 22.04. They expressly remove it as Ubuntu 22.04 upgrades from 20.04
(I know this because I had to rework the Linux package around the problem when 22.04 was released to beta)
I downloaded beignet-opencl-icd_1.3.2-8_amd64.deb from Debian 11 ftp , installed and it worked.
