Here is playing the jellyfish file, with “HDR tonemapping” enabled:
Here’s a movie, again with hdr tonemapping enabled
And here’s the same movie but with HDR tonemapping disabled:
Edit- to be clearer the second one shows “hdr” and “sdr” while the jellyfish one doesn’t - unsure why, if the jellyfish one is HDR. The first two use software transcoding, while the last one uses hardware transcoding. Ideally the first two would also use hw transcoding.
It looks like you’re getting 4k HDR → 1080p SDR using hardware, that’s good! Are you running the latest PMS on an ubuntu 21 system, or an earlier ubuntu?
Oh mostly just noting that it is hardly an upgrade if the only difference seems to be breaking useful things but I am sure there’s other stuff going on in 21 that justifies it. I’d just like to figure out why this is happening because at the moment it ends up feeling like a step back.
Edit: Aside from that, I suppose this leaves us at a spot where it looks like the HW transcoding simply isn’t running with HDR tonemapping enabled on 21 for now, at least without rolling back to an earlier version. I’m not sure if there’s much else to do except hope that a later version of ubuntu or plex changes something, then?
I have worked around this issue to some degree- I have not solved the fundamental HDR → SDR failure to use (hw) on the latest Plex/linux but I did figure out the reason the Apple TV 4K was transcoding unexpectedly - I went and bought an Nvidia shield to test and it reported transcoding due to audio compatibility - once I fixed that, it reported still transcoding due to “bandwidth limitations” - I discovered that I had previously set “100mbps” as my upload speed from my previous internet, and Plex was capping the outbound at 80% of that - meaning the peak bitrate would be at times over the 80% cap, so instead the server insisted on transcoding the entire thing. I bumped the upload bandwidth setting up to 800mbps and now it is direct playing the 4k HDR correctly, bypassing the issue for now. Hopefully either an ubuntu fix or something will repair the hw accelerated tone mapping but it is at least now not so urgent. That’s good!
