Thanks again… i will wait for this case!
thanks!!! very thanks
@wpcorgan said:
HI @sa2000 Today I woke up and then i can see in my PMS a new deadlock… then I followed all the steps and i have send you the request files… can you check please… (i have send you a private message)thanks again !!!
The issue causing the deadlock has been identified and a fix will be worked on
Linking to another forum topic for a deadlock caused by the same issue
http://forums.plex.tv/discussion/comment/1675015/#Comment_1675015
HI @sa2000
Thank you for you responde…
My question is… Will there be a new release to fix this?
Thanks Again
Thanks Again
Yes there will be, after the fix for the bug is worked out and included in a release - which would normally be through beta first. I will let you know when the fix is out - Also the release notes would mention a fix for deadlocks
Thanks AgainYes there will be, after the fix for the bug is worked out and included in a release - which would normally be through beta first. I will let you know when the fix is out - Also the release notes would mention a fix for deadlocks
Thank you very much @sa2000 … i will wait for the new release…
A fix is being reviewed. I am hoping that it will get released in version 1.13.4 -
I do not have any definitive information. As mentioned before, the cause of the problem has been found and it is a matter of developing a fix for it and releasing that fix.
It is my intention to make an early development build available to the users that had this specific deadlock to confirm the fix
Hi @sa2000… How are you…
What about 1.13.3.5208 version…
can this new version fix my problem o I must wait 1.13.4???
thanks
I am afraid you do have to wait for that
My exact words were
and this statement is still true. I am hoping that it will get released in 1.13.4 and I will try and get an early development build for you to confirm the fix
Ok @sa2000 … thank you very much!!
and sorry…
have a nice day
I have sent you a PM with development build 1.13.4.5217 to update to. Changes were made to address this deadlock.
thanks again @sa2000 , i will install this release tomorrow early… and then i will tell you if its works,
thanks very much!!!
Plex Media Server version 1.13.4.5251 has just been released as beta. It has fixes for two deadlocks following investigations from diagnostics provided in this forum thread
See Release Notice Plex Media Server
