Check your playback settings to make sure it’s not trying to transcode
There is no possible transcoding for Profile 5
It is trying to transcode. It’s a 4K DoVi file that Chrome can’t handle. Plex/Web transcodes this to 1080p, usually. Not anymore.
That’s odd… As I said, these files used to play back absolutely fine, without weird colors. I can live with it, since I only use Plex/Web to manage the server, but my family streaming remotely is probably not liking this.
Can we ask the team what made them go down this route?
Please look above.
A little qnap & Plex/web … Works just fine with non-Profile 5 input.
You’re trying to transcode a “Streaming-only” copy . Won’t work.
I guess I must have been dreaming all these years when these exact same files played back perfectly fine before 1.291.
Anyways, I don’t want to derail this thread. I’ll open a separate one.
If it’s regarding Profile 5, there’s nothing to discuss.
FYI… Still seeing beignet-opencl-icd being reported as recommended.
Drats! that should also be removed. I’ll get that.
There were a lot of changes.
EDIT: Added the package change recommendation to the list of issues for 1.29.1
Just installed, tonemapping working perfectly right out of the box. Thanks so much for all of your effort!
FYI… the beignet-opencl-icd recommended has been removed with 1.29.1.6316-f4cdfea9c (thankfully).
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'plexmediaserver' instead of '/data/Personal/Software/ubuntu/plexmediaserver_1.29.1.6316-f4cdfea9c_amd64.deb'
The following packages will be upgraded:
plexmediaserver
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/85.0 MB of archives.
After this operation, 4,096 B of additional disk space will be used.
Get:1 /data/Personal/Software/ubuntu/plexmediaserver_1.29.1.6316-f4cdfea9c_amd64.deb plexmediaserver amd64 1.29.1.6316-f4cdfea9c [85.0 MB]
(Reading database ... 239654 files and directories currently installed.)
Preparing to unpack .../plexmediaserver_1.29.1.6316-f4cdfea9c_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.29.1.6316-f4cdfea9c) over (1.29.1.6276-4a96dd5b1) ...
Setting up plexmediaserver (1.29.1.6316-f4cdfea9c) ...
PlexMediaServer install: PlexMediaServer-1.29.1.6316-f4cdfea9c - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Processor: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
PlexMediaServer install: Intel i915 Hardware: Not found
PlexMediaServer install: Nvidia GPU card: Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.29.1.6316-f4cdfea9c - Installation successful. Errors: 0, Warnings: 0
Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu3) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Thanks.
I put in that change and am glad to see it’s made its way out to everyone.
Thanks very much @ChuckPa! I’ve been waiting for this update for a very long time. It’s working fantastic for me, and I can now transcode HDR content with tone mapping on my DS1520+ with no lags or huge buffering. One transcode takes about 20% CPU, give or take, and that’s perfectly acceptable to me.
