bonjour
vivement cet V0.9 car toujours pas compris pour Openssl
merci pour ce travail
bonjour
Version 0.9 (beta) has been released (see first post):
v0.9 (beta)
Hello
thank you for the update works perfect
This is excellent and exactly what I was looking for, thanks
Do you have any plans for putting the code into a git repository for easier updating? I’m looking at building a Docker container for it and would make grabbing the latest version much easier.
You are welcome. I am pleased to see, that others are looking for such a program too and that my project finds recognition.
Regarding git: I never have used git or similar software for version controlling. I took a look at git once but it seemed quite difficult to use and honestly I did not understand the concept of branches and commits. Therefore and because this is currently my only programming project, I don’t think it is worth the time for me to learn how to use it. Sorry!
hi @mlocher75, good job!
would be very usefull if you implement the possibility to sync the selected movies with an external drive, like do plex downloader that work great but have very poor interface
Thanks for your compliment!
Unfortunately I have to tell you that I have absolutely no intention to implement such a functionality. As stated in my initial post, the very reason for this program was to present the library to my relatives and friends WITHOUT the possibility for them to download or watch the movies.
I need a little bit of help with this. I downloaded the file, unzipped it and copied it to my nginx www folder.
I renamed the folder to “new” and i can access domain.com/new/settings.php and set it up. But, when i go to domain.com/new it loads but I get a blank page.
I can’t for the life of me figure out whats going on. Been trying for a few hours.
Thank you in advance for the help
Can you describe this a little bit in more detail?
Do you see the title on top and the menu bar on the left or is the complete page blank? (a screenshot or link to your page would be helpful)
Is the debug mode (/settings.php → User Settings → Debug) set to “True”? If not, set it to “True” and see whether you have any PHP errors when loading the page. You will maybe have to view the HTML source of the loaded page to see them.
@mlocher75 said:
@jrdnlc said:
But, when i go to domain.com/new it loads but I get a blank page.Can you describe this a little bit in more detail?
No title on the menu bar or anything. Just a complete blank page. I turned on debug mode and when I try accessing the page it gives me this error:
Fatal error: Call to undefined function curl_init() in /config/www/new/php/class.plexAPI.php on line 614
OK, so your PHP installation is missing the required cURL extension.
See here: http://www.tomjepson.co.uk/enabling-curl-in-php-php-ini-wamp-xamp-ubuntu/
Or google for it…
See here: Enabling CURL in PHP (PHP.ini, WAMP, XAMPP, Ubuntu) - Tom Jepson
Or google for it…
Thanks. Curl wasn’t even installed so I had to install it manually and now it’s working great other than the thumbnails. Do they take a few minutes to fetch?
The thumbnails should normally start showing up immediately.
However, if image caching is enabled in the settings, the first time a thumbnail is loaded, it is saved to the cache directory on the web server. Therefore it might take quite some time until all thumbnails are loaded and they might show up slowly one after the other. Once the images are cached the images should then load much faster.
If image caching is disabled, the thumbnails are not saved to the web server but loaded every time directly from the plex server. Also in this case it might take some time until all thumbnails are loaded and they might show up slowly one after the other.
If you do not see any thumbnails at all, try to connect to the plex server in plain http (/settings.php -> Plex Server -> Secure connection -> http://).
If you do not see any thumbnails at all, try to connect to the plex server in plain http (/settings.php → Plex Server → Secure connection → http://).
I tried everything you suggested and thumbnails still don’t load. Not sure what the issue is
Here is the error I got from chrome console: http://hastebin.com/xenufuyopu.js
This is really cool
Now gotta find a way to use it…
used my godaddy set up. The only issue I keep having is no matter what i set my server to it wont connect and keeps giving me the cant connect to server error.
@mlocher75 Many thank for your app, i like it.
It’s a great job.
is this still active?
Windows 10E X64
Webserver: IIS 10
Do you know why I’m getting this error in the browser?
Seems that I can get to the front end, but oddly when using a Chrome incognito session, I get this error.
index.php:71 Uncaught TypeError: $(...).trunk8 is not a function
at HTMLDocument.<anonymous> (index.php:71)
at c (jquery-1.10.2.min.js:2)
at Object.fireWith [as resolveWith] (jquery-1.10.2.min.js:2)
at Function.ready (jquery-1.10.2.min.js:2)
at HTMLDocument.q (jquery-1.10.2.min.js:2)
Still want to include some functionality but unfortunately don’t have time to do so for the time being. I will certainly fix errors e.g. if the API changes.
This is a JavaScript error. I did not do the JavaScript myself but used some free jquery plugins. So I actually can’t help you on this error.
My guess is that the incognito mode prevents chrome from loading the jquery library which is required to execute the jquery plugins.
