I fixed the category selection issue. We were missing an item in the list, added it and it should be good to go now.
New bug on M3:
- When I try to launch an episode, the left pannel open, and no way to play it.
In fact is seems that at this level, th OK button act like the MENU button.
Episodes now have a on screen touchable menu that gets focus at times. Make sure that is not highlighted blue in the upper left corner. If so press down and that will take you to the gallery and you can select the episode.
I made a change in rc3 last night that should help indicate when the gallery has focus.
No way...
In fact, I was able to reproduce the issue...
This issue (cannot start the selected episode sending the message "The queue is empty") happen only when there is only one episode in the season. Elsewhere all goes right. In this case, I was not able to start the episode with the ok button from the remote, but it starts with mouse.
Another small thing, the reminder box starts two times; you’ll have to closes two boxes at the first start.
Other small thing, but was already there on previous versions.
- Some season posters are not displayed. In my case star trek TOS only the first season poster is displayed and not the other three.
No way...
I'll see if I can reproduce the issue with the Message queue. The queue will only play back items if there are items in the queue and you have to manually add them with the long press. I'll post an RC4 with some additional tweaks around this that should help make sure we aren't running into focus issues.
I'm going to remove the Change Log and Reminder code for now. Will add them back in during a Point release so that I can get this release out this weekend.
This I'll need a bug report on so that I can duplicate the issue.
See: https://github.com/NineWorlds/serenity-android/wiki/Serenity-for-Android#wiki-bugreports for how to report a bug. Please file it on the Issue tracker and include the necessary XML files.
1.4.0 RC4
https://github.com/NineWorlds/serenity-android/wiki/Downloads#140-rc4-available
Features and Improvements:
- Fix issue for Logitech Revue and 1st generation Sony Google TVs not displaying some main menu background images. (Thanks to Thomas and Denys for reporting and testing)
- Make sure focus is going to Gallery's first instead of menu icon.
- Make it clearer when the Gallery has focus. Blue box focus, gray box selected but not focused.
- Removed Change Log...will add it back during a maintenance release.
Moscard please test this to see if it fixes the issue you are having with the Episodes and playback.
Yes, the unplayable alone episode is fixed in RC3.
Remark: the sound voices (2.0, 5.1,..) are still to big, the other icons are just fine. Nevertheless, I would prefer the fractional aspect ratio 16/9 instead of 1.78:1 but that is only my opinion
Forget it, it is a Plex "THETVDB" Issue. I reproduce the problem in Plexweb app.
I've adjusted the sizes a bit on the channel icons, they match up a bit better now.
Thanks for testing. 1.4.0 should hit the play store in the next 24 hours.
