since the last update I cannot match using TheTVDB anymore, here is an excerpt from the Log:
2016-12-03 10:15:25,253 (80884c400) : DEBUG (model:229) - Serializing to /usr/local/plexdata-plexpass/Plex Media Server/Metadata/TV Shows/2/d2b5d3f7f61d930c34f916add98da14c76fd9b9.bundle/Contents/com.plexapp.agents.thetvdb/Info.xml
2016-12-03 10:15:25,254 (80884c400) : DEBUG (runtime:88) - Sending packed state data (107 bytes)
2016-12-03 10:15:25,255 (80884c400) : DEBUG (runtime:924) - Response: [200] str, 16 bytes
2016-12-03 10:15:30,270 (80884bc00) : DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKZW5zNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzNQoxMTc4MnM0CmRiaWRpMApzNwp2ZXJzaW9ubnMxMApwYXJlbnRHVUlEbnM4CnBhcmVudElEczcKVFZfU2hvd3MxMAptZWRpYV90eXBlczQzCmNvbS5wbGV4YXBwLmFnZW50cy50aGV0dmRiOi8vMjQ4NjgyP2xhbmc9ZW5zNApndWlkczYKMjQ4NjgyczIKaWRyMAo_
2016-12-03 10:15:30,270 (80884bc00) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2016-12-03 10:15:30,271 (80884bc00) : DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlVwZGF0ZU1ldGFkYXRh/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMTAKczIKZW5zNApsYW5nYjFzNQpmb3JjZWIwczgKcGVyaW9kaWNzNQoxMTc4MnM0CmRiaWRpMApzNwp2ZXJzaW9ubnMxMApwYXJlbnRHVUlEbnM4CnBhcmVudElEczcKVFZfU2hvd3MxMAptZWRpYV90eXBlczQzCmNvbS5wbGV4YXBwLmFnZW50cy50aGV0dmRiOi8vMjQ4NjgyP2xhbmc9ZW5zNApndWlkczYKMjQ4NjgyczIKaWRyMAo_
2016-12-03 10:15:30,272 (80884bc00) : DEBUG (model:32) - Loading model with GUID com.plexapp.agents.thetvdb://248682?lang=en
2016-12-03 10:15:30,272 (80884bc00) : DEBUG (model:234) - Deserializing from /usr/local/plexdata-plexpass/Plex Media Server/Metadata/TV Shows/1/839336d2509bee3940d0461f2b7465f8f28cb0f.bundle/Contents/com.plexapp.agents.thetvdb/Info.xml
2016-12-03 10:15:30,481 (80884bc00) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/library/metadata/11782/tree’
2016-12-03 10:15:30,562 (80884bc00) : INFO (init:781) - def update()
2016-12-03 10:15:30,563 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/login’
2016-12-03 10:15:30,594 (80884bc00) : INFO (init:140) - JWT Error: (‘module’ object has no attribute ‘sslwrap’) - ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,598 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/series/248682?lang=en’
2016-12-03 10:15:30,630 (80884bc00) : INFO (init:175) - Problem with the request: ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,630 (80884bc00) : INFO (init:1077) - Bad series data, no update for TVDB id: 248682 (lang: en)
2016-12-03 10:15:30,631 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/login’
2016-12-03 10:15:30,674 (80884bc00) : INFO (init:140) - JWT Error: (‘module’ object has no attribute ‘sslwrap’) - ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,678 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/series/248682/actors’
2016-12-03 10:15:30,717 (80884bc00) : INFO (init:175) - Problem with the request: ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,717 (80884bc00) : INFO (init:1077) - Bad actor data, no update for TVDB id: 248682
2016-12-03 10:15:30,718 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/login’
2016-12-03 10:15:30,750 (80884bc00) : INFO (init:140) - JWT Error: (‘module’ object has no attribute ‘sslwrap’) - ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,755 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/series/248682/episodes?page=1’
2016-12-03 10:15:30,786 (80884bc00) : INFO (init:175) - Problem with the request: ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,787 (80884bc00) : DEBUG (threadkit:234) - Starting a parallel task set named UpdateEpisodes with 0 tasks
2016-12-03 10:15:30,787 (80884bc00) : DEBUG (threadkit:244) - Parallel task set UpdateEpisodes ended
2016-12-03 10:15:30,788 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/login’
2016-12-03 10:15:30,823 (80884bc00) : INFO (init:140) - JWT Error: (‘module’ object has no attribute ‘sslwrap’) - ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,828 (80884bc00) : DEBUG (networking:166) - Requesting ‘https://tvdb2.plex.tv/series/248682/images?lang=en’
2016-12-03 10:15:30,860 (80884bc00) : INFO (init:175) - Problem with the request: ‘module’ object has no attribute ‘sslwrap’
2016-12-03 10:15:30,860 (80884bc00) : INFO (init:685) - Bad image type data for TVDB id: 248682
2016-12-03 10:15:30,861 (80884bc00) : DEBUG (threadkit:234) - Starting a parallel task set named DownloadImages with 0 tasks
2016-12-03 10:15:30,861 (80884bc00) : DEBUG (threadkit:244) - Parallel task set DownloadImages ended
2016-12-03 10:15:30,862 (80884bc00) : INFO (init:1084) - Series Extra XML is empty - therefore, no season XML
2016-12-03 10:15:30,863 (80884bc00) : INFO (init:1084) - Series Extra XML is empty - therefore, no season XML
Looks like a python/sslwrap related bug. Anyone else with similar problems?
Best regards,
Tilman
PS: Downgrading from 1.3.0 to 1.2.7 immediately fixes the issue.
