Resize left panel
Hi, is there a way to resize the left side panel so I can see the entire title of the library?
There’s no option for that.
I’m wondering… is there a particular reason why you keep the same prefix in the name of every library of yours?
i’m not sure if you remember or not (or even know), but the Joe Bob moveis were double and triple features so i wanted the commentary to match the slot. i figured i’d remove the Joe Bob from the title, that seemed to have worked.
You don’t need separate libraries for different movie groups / franchises.
now that you mention it, i forgot about the “sort title” field.
There’s also collections.
i’ll look into that, thanks
