Writing profiles for DLNA devices
Introduction
This post describes the semantics of writing a DLNA client profile for Plex Media Server version 0.9.7.24 and above. It assumes you understand the basics of editing an XML file.
What's a client profile?
DLNA is a broad and flexible standard, on that's interpreted by different devices in different ways: some by design, some due to device bugs or accident. This makes it impossible for a media server that supports DLNA to provide a one-size-fits-all implementation of the standard. Instead, the server must adapt to different clients by recognizing them and changing its behavior accordingly.
The client profile is the basic unit of information that Plex Media Server uses to customize its behavior for different client devices.
Do I have to write my own profile?
If your device isn't supported in a profile out of the box, then you might need to. Devices without profiles may work using generic settings, but they might not work very well. The primary purpose of a profile is to define the media formats that the device can play natively, as well as which media format Plex Media Server will use to transcode video, music and photos when media is not natively supported by the device. Some devices also have hard requirements for particular aspects of DLNA or HTTP behavior, which can be altered through client profile settings.
The initial release of Plex Media Server's DLNA support comes with profiles that support a few devices, including Xbox 360 and PlayStation 3. Over time new profiles will be added as we test new devices and as our friends in these forums post working profiles for us to use.
Where are profiles located?
Plex Media Server uses two different kinds of profile files:
System profiles
System profiles are provided and supported by Plex Inc. and are updated automatically when a new version of the server is installed. System profile files are stored in the Plex Media Server installation, under the Resources/Profiles directory. They should be assumed to be read-only from a user's perspective, because any changes made will be lost when the server installation is updated.
User profiles
User profiles are authored by individual users and are never changed by the server. User profile files are located in the Plex Media Server user directory, in a directory called Profiles. If you have never authored a user profile before, this directory will not exist.
User profiles may provide support for devices not supported by system profiles, as well as override devices supported by system profiles. A system profile can be overridden by creating a client profile file with the same file name as the system profile file that is intended to be overridden.
How do I know if my user profiles are being used?
If you look at the contents of Plex DLNA Server.log after PMS starts up, you will see entries along the lines of the following:
Jul 08, 2013 13:16:18:024 [47244] DEBUG - Overriding system profile Xbox 360 with user profile
Jul 08, 2013 13:16:18:037 [47244] DEBUG - Reading user profile Xbox 720
The first line indicates an override, the second that a new user profile has been found. If the server has a problem parsing your file, it will report an error and continue execution. So it’s important to double-check the log after you’ve made edits to your user profile files.
Elements of a client profile
A client profile consists of the following elements:
  • Name: how Plex Media Server refers to the profile. Must be identical to the profile’s file name.
  • Identification: how Plex Media Server recognizes a device, given an incoming HTTP request.
  • Protocol Info: how Plex Media Server reports its own DLNA protocol support to devices.
  • Device Description: how Plex Media Server identifies itself to other devices during DLNA network discovery.
  • Settings: configuration options that change the DLNA server’s behavior when talking to a particular device.
  • Transcode Targets: the video, music and photo media formats to which PMS will transcode content devices can’t play natively.
  • DirectPlay Profiles: the set of video, music and photo formats the device can play natively.
  • Codec Profiles: settings and limitations on the video, music and photo formats that the device can play natively.
  • Container Profiles: settings and limitations on the container formats that the device can play natively.
  • Transcode Target Profiles: settings for transcode targets.
  • DLNA Media Profiles: customization of media format representations for very picky DLNA devices.
Creating a client profile is essentially the process of filling out a form with all this information. Once that’s complete, Plex Media Server will know how to recognize your device and how to serve up content to it in a way it can play natively.
Where would I find the information needed to create a profile?
Usually from your device manufacturer. E.g.
and so forth.
Failing that, you may be able to find information using a search engine, via the device’s GetProtocolInfo method, or via ad-hoc experimentation. Other DLNA server products have put together similar profiles, and sometimes we reuse information from those, since we’re all in this together. Such is the nature of DLNA. :smiley:
How do I know whether my device is supported or not?
If the device works, then there's nothing you really need to do. If the device isn't working right with Plex Media Server, it may be unsupported. To determine this, you can search for an entry in the system profile file, or you can scan your Plex DLNA Server.log file. A recognized device will look like this in the log when the server sees it making a request:
Mar 30, 2012 14:15:59:760 [13304] DEBUG - Mapped client to profile Xbox 360
An unrecognized device will look like this:
Mar 30, 2012 14:12:53:688 [11524] DEBUG - Mapped client to generic profile: Cache-Control: no-cache; Connection: Close; Pragma: no-cache; Content-Type: text/xml; charset="utf-8";
User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player/12.0.7601.17514 DLNADOC/1.50 (MS-DeviceCaps/1024); SOAPAction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"; Content-Length: 886; Host: 192.168.11.10:32469
Note the mapping to a generic profile, as well as the presence of the headers from the HTTP request. The server provides these to make it easier for profile authors to see what the device is actually sending the server when making a request.
What's the generic profile?
The generic profile is the profile that defines Plex Media Server's behavior when a device is unrecognized. The generic profile can be overridden by a user profile file, just like any other profile. The default behavior of the generic profile is to offer up all content as Direct Play, with no transcoding or limitations. This will work reasonably well with more capable devices, but will fail with pickier ones.
How do I know the right names to use for containers and codecs?
Here's a list of containers and codecs we've observed in the wild. This is not intended to be comprehensive or exhaustive, but most media you'll ever use will be on this list:
container = { asf, avi, mov, mp4, mkv, mpegts, wtv, mpeg, m4v }
video = { h264, mpeg1video, mpeg2video, mpeg4, msmpeg4, mjpeg, wmv2, wmv3, vc1, cinepak, h263 }
audio = { aac, ac3, truehd, eac3, dca, mp3, mp2, pcm, wmapro, wmav2, wmavoice, wmalossless }
That said, the best way to find the container and codec names for your specific media is to look at your Plex Media Server’s XML. In the Plex Media Server web client, click on the media’s Info button, then on “View XML”. Here’s an example:
<Video addedAt="1343078395" grandparentRatingKey="66" grandparentTitle="Neverwhere" guid="com.plexapp.agents.thetvdb://70490/1/3?lang=en" index="3" key="/library/metadata/70" lastViewedAt="1435091413" originallyAvailableAt="1996-09-26" parentIndex="1" rating="8.5" ratingKey="70" title="Earl's Court to Islington" type="episode" updatedAt="1343078422" viewOffset="680798" year="1996" duration="1711012">
  <Media id="66" aspectRatio="1.33" audioChannels="2" audioCodec="aac" bitrate="1353" container="mp4" duration="1711012" height="480" optimizedForStreaming="1" videoCodec="h264" videoFrameRate="NTSC" videoResolution="480" width="640">
    <Part id="68" container="mp4" duration="1711012" has64bitOffsets="0" optimizedForStreaming="1" size="289319079" transcodeState="transcoded" key="/library/parts/68/file.mp4">
      <Stream bitDepth="8" bitrate="1088" cabac="1" chromaSubsampling="4:2:0" codec="h264" codecID="avc1" colorSpace="yuv" duration="1711012" frameRate="29.970" frameRateMode="cfr" hasScalingMatrix="0" height="480" index="0" level="30" profile="high" refFrames="4" scanType="progressive" streamIdentifier="1" streamType="1" width="640" id="1"/>
      <Stream audioChannelLayout="stereo" bitrate="256" bitrateMode="cbr" channels="2" codec="aac" codecID="40" duration="1711006" index="1" profile="lc" samplingRate="48000" streamIdentifier="2" streamType="2" id="2" selected="1"/>
    </Part>
  </Media>
</Video>
From the full XML metadata, you can use the names from the Part’s container attribute and the codec names on the streams. Video streams are of type 1 and audio streams of type 2.
(NB - if you see very little metadata on the streams, you may need to reanalyze your media. To do this, simply refresh the section.)
Profile XML details
Name
The name of a profile allows Plex Media Server to uniquely identify it. Usually this is the commercial name of the device. It is expressed as the name attribute on the Client element:
<Client name="Xbox 360">
Identification
The Identification section defines how Plex Media Server recognizes a device in order to apply a profile to a request. Two different identification mechanisms are used by the server: incoming HTTP header recognition, and IP address matching based on a-priori network discovery.
An Identification section consists of one or more Header or DeviceDescription elements. Multiple such elements represent alternative means of identification, and not multiple requirements.
A Header element allows the profile to detect clients using headers in an incoming HTTP request. A Header element must have a name attribute, containing the name of the relevant HTTP header in a case-insensitive manner. It also must have either a substring attribute or a regex attribute, but not both. The value of a substring attribute is any matching case-insensitive substring (no wildcards) inside the header’s value, while the value of regex is a case-insensitive regular expression that applies to the value of the HTTP header.
If any of the elements under a Header element matches, the device is considered to match. I.e. multiple elements under a Header element are ORed together.
For example, a device that occasionally uses two different User-Agent headers could be identified as follows:
  <Header name="User-Agent" substring="Xbox"/>
  <Header name="User-Agent" substring="Xenon"/>
Authoring
When authoring a new profile, it helps to know which headers are being sent by the device. As noted above, these can be found in the Plex DLNA Server.log file when the device is being mapped to the generic profile. A more complete way to monitor device activity is to use Wireshark or Microsoft Network Monitor.
One thing that’s VERY IMPORTANT: when creating profiles for other people to use, you have to think about the device ecosystem in which your profile will be used. Most people using Plex Media Server won’t have your device, but they may have a different device that sends vaguely similar headers. So when authoring this section, PLEASE make sure you’re being as restrictive as possible when writing substrings or regular expressions for Header elements. Overly broad header elements can cause erroneous profiles matching, which people will find immensely confusing.
A DeviceDescription element allows the profile to detect clients using the properties they advertise in their device XML when responding to a search request. This is useful when a device does not provide a distinctive HTTP header on each request. For performance reasons, the HTTP header mechanism is preferable, when possible.
A DeviceDescription element may have a type element, indicating the type of device that exposes the relevant property. This is useful for DLNA clients that expose themselves as multiple devices in this XML, e.g. the Samsung LE32C650. In general, when using a DeviceDescription element, it is recommended to use this attribute with a specific device type. Otherwise, Plex Media Server will attempt to match these properties against any device type it sees, which may lead to unexpected results if the matching data is not unique.
The following sub-elements are supported inside a DeviceDescription element:
  • FriendlyName
  • ModelName
  • ModelNumber
  • ModelUrl
  • ModelDescription
  • Manufacturer
  • ManufacturerUrl
  • SerialNumber
Each element must have either a substring attribute or a regex attribute. These attributes follow the same rules as with the Header element. Multiple elements under a DeviceDescription must all match in order for the DeviceDescription to be considered a match. I.e. all sub-elements under a DeviceDescription element are ANDed together.
The following is a (fictional) example of a DeviceDescription element:
<Identification>
  <DeviceDescription type="urn:samsung.com:device:RemoteControlReceiver:1">
    <FriendlyName substring="LE32C650" />
    <ModelName substring="UE" />
    <ModelNumber substring="700" />
    <ModelUrl substring="samsung.com" />
    <ModelDescription substring="An nyoung ha seh yo" />
    <Manufacturer substring="Samsung" />
    <ManufacturerUrl substring="samsung.com" />
    <SerialNumber substring="1234" />
  </DeviceDescription>
</Identification>
A device’s friendly name, device type and other properties can be discovered using the Device Spy tool
The following is an real example of device XML provided by a DLNA client, in this case a version of Windows Media Player:
<device>
  <friendlyName>SERVER: mfeingol:</friendlyName>
  <deviceType>urn:schemas-upnp-org:device:MediaServer:1</deviceType>
  <manufacturer>Microsoft Corporation</manufacturer>
  <manufacturerURL>http://www.microsoft.com</manufacturerURL>
  <modelName>Windows Media Player Sharing</modelName>
  <modelNumber>12.0</modelNumber>
  <modelURL>http://go.microsoft.com/fwlink/?LinkId=105926</modelURL>
  <serialNumber>{06C328CF-8EC5-4F1E-BAA4-D67CDAD172FB}</serialNumber>
</device>
Protocol Info
When a DLNA client discovers a DLNA server on the network, it may inquire as to its capabilities. One important capability is the set of media formats supported by the server. Some DLNA clients (e.g. televisions) often have fairly strong opinions about which formats it wants to see. This section allows the response Plex Media Server provides to that question to be customized.
A ProtocolInfo element must have a single Source element. The inner value of that source element is the value that Plex Media Server will use when responding to GetProtocolInfo requests from the device.
For example:
<ProtocolInfo>
  <Source>http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000</Source>
</ProtocolInfo>
If no ProtocolInfo is specified, Plex Media Server will reply with a default value. That value is customizable by the user, and may change in different versions of Plex Media Server. The default is currently the following:
http-get:*:video/mpeg:*,http-get:*:video/mp4:*,http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:video/avi:*,http-get:*:video/x-matroska:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/wtv:*,http-get:*:audio/mpeg:*,http-get:*:audio/mp3:*,http-get:*:audio/mp4:*,http-get:*:audio/x-ms-wma*,http-get:*:audio/wav:*,http-get:*:audio/L16:*,http-get:*image/jpeg:*,http-get:*image/png:*,http-get:*image/gif:*,http-get:*image/tiff:*
Settings
The Settings section contains configuration options that change the DLNA server's behavior when a device is recognized. The following settings are currently supported:
  • OnlyPlainVideoItems - true/false, default is false - all videos are represented in DIDL as “object.item.videoItem” instead of a more specific type, such as “object.item.videoItem.movie”.
  • OnlyStorageFolders - true/false, default is false - all folders are represented in DIDL as “object.container.storageFolder” instead of a more specific type, such as “object.container.person.musicArtist”.
  • IgnoreTranscodeByteRangeRequests - true/false, default is false - byte range requests issued for transcode video streams are handled as if no range request had been made
  • EmitAlbumArtResources - true/false, default is false - emit res items inside video DIDL representing album art for the video in question. Some devices prefer this mechanism to others for obtaining album art. Other devices can’t handle this and are unable to play video when this option is enabled.
  • TimelineBufferOffset - integer representing seconds, default is zero - how far ahead the device generally buffers when playing video. Used to improve accuracy when recording playback progress on the server for a given video when the video is played by a DLNA device.
  • IconResolution - string - resolution of icons exposed via upnp:icon, derived from Plex Media Server thumbnails. Default is 256x256.
  • AlbumArtResolution - string - resolution of album art exposed via upnp:albumArtURI, derived from Plex Media Server album art or thumbnails. Default is 512x512.
  • AlbumArtPN - string - the DLNA.ORG_PN value used for album art, aka the dlna:profileID attribute on upnp:albumArtURI. Default is JPEG_SM. (Some devices are very picky about wanting a specific value, regardless of the actual size of the image.)
To determine which settings to use when authoring a profile, the general rule of thumb is to fix on failure via trial and error. E.g. the OnlyStorageFolders setting is worth trying if the device can’t seem to browse into folders, or thinks folders are media, or folders can be browsed, but no videos show up. If folders work after changing the setting, then it’s worth keeping in the profile. Similarly, the OnlyPlainVideoItems setting is worth trying if folders containing video appear empty.
For example:
<Settings>
  <Setting name="OnlyPlainVideoItems" value="true" />
  <Setting name="OnlyStorageFolders" value="true" />
  <Setting name="IgnoreTranscodeByteRangeRequests" value="true" />
  <Setting name="TimelineBufferOffset" value="40" />
  <Setting name="IconResolution" value="512x384" />
  <Setting name="AlbumArtResolution" value="512x384" />
  <Setting name="AlbumArtPN" value="JPEG_TN" />
</Settings>
Device Description
When a DLNA client discovers a DLNA server on the network, the client may use information provided by the server to deduce the server's characteristics. Which server is this? Who made it? Etc.
Some clients exhibit specific behaviors when these values are set to specific parameters. This DeviceDescription element allows Plex Media Server’s device characteristics to be customized per client, influencing a set of fields in the device’s XML description. These fields can also be left empty, specifying that no content is to be emitted, or elided entirely, in which case default values will be used. The default values used by Plex Media Server may vary from release to release, and can be observed in a program like Device Spy.
The following is an example of a default Plex Media Server device description:
<device>
  <friendlyName>Plex Media Server: Orpheus</friendlyName>
  <manufacturer>Plex, Inc.</manufacturer>
  <manufacturerURL>http://www.plexapp.com/</manufacturerURL>
  <modelDescription>Plex Media Server</modelDescription>
  <modelName>Plex Media Server</modelName><modelURL>http://www.plexapp.com/</modelURL>
  <modelNumber>0.9.7.28</modelNumber>
  <serialNumber/>
  <UDN>uuid:6911532c-85f2-2072-9776-656536c01ca4</UDN>
  <dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMS-1.50</dlna:X_DLNADOC>
</device>
The following fields can be overridden:
  • FriendlyName: controls the content of the friendlyName element in the urn:schemas-upnp-org:device-1-0 namespace.
  • Manufacturer: controls the content of the manufacturer element in the urn:schemas-upnp-org:device-1-0 namespace.
  • ManufacturerUrl: controls the content of the manufacturer element in the urn:schemas-upnp-org:device-1-0 namespace.
  • ModelName: controls the content of the manufacturerURL element in the urn:schemas-upnp-org:device-1-0 namespace.
  • ModelNumber: controls the content of the modelNumber element in the urn:schemas-upnp-org:device-1-0 namespace.
  • ModelUrl: controls the content of the modelUrl element in the urn:schemas-upnp-org:device-1-0 namespace.
  • ModelDescription: controls the content of the modelDescription element in the urn:schemas-upnp-org:device-1-0 namespace.
  • X-DlnaDoc: controls the content of the X_DLNADOC element in the urn:schemas-dlna-org:device-1-0 namespace.
  • X-DlnaCap: controls the content of the X_DLNACAP element in the urn:schemas-dlna-org:device-1-0 namespace.
  • Sony-AggregationFlags: controls the content of the aggregationFlags element in the urn:schemas-sonycom:av.
For example:
<DeviceDescription>
  <FriendlyName>Hi, I'm a friendly device</FriendlyName>
  <Manufacturer>Microsoft Corporation</Manufacturer>
  <ManufacturerUrl>http://www.microsoft.com/</ManufacturerUrl>
  <ModelName>Windows Media Player Sharing</ModelName>
  <ModelNumber>12.0</ModelNumber>
  <ModelUrl>http://www.microsoft.com/</ModelUrl>
  <ModelDescription>Something or other</ModelDescription>
  <X-DlnaDoc>DMS-1.50</X-DlnaDoc>
  <X-DlnaCap />
  <Sony-AggregationFlags>10</Sony-AggregationFlags>
Transcode Targets
Transcode Targets define the video, music and photo formats to which PMS will transcode media when the media's format is not listed inside a DirectPlay Profile. A TranscodeTarget element contains a set of VideoProfile elements, a single MusicProfile element and a single PhotoProfile element. All elements are optional, in that the absence of a transcode target profile for a given media type simply means that no media of that type will be transcoded.
A VideoProfile element has the following attributes:
  • protocol: either http (a standard video stream), slss (a Silverlight Smooth Streaming manifest + stream) or hls (an HTTP Live Streaming manifest + stream). No protocol attribute means http.
  • container: the video container used to encapsulate the video. This should be mpegts or asf for the http protocol, mp4 for the slss protocol and mpegts for the hls protocol.
  • codec: the video codec used to encode the video. This should generally be h264, but it could be any codec compatible with the chosen container. Some protocols may impose certain restrictions on this value.
  • audioCodec: the audio codecs that may used to encode this video. This attribute can be a list of audio codecs representing Direct Streaming options. If the source codec matches none of these, generally the first codec in the list will be used.
  • context: the context in which the video profile will be used. For DLNA profiles, this value should be set to streaming or elided entirely.
A VideoProfile element may also have Settings sub-elements, with name and value attributes. The following settings are supported:
  • VideoEncodeFlags - string - provides additional command line arguments to the transcoder. Use this at your own peril.
  • SubtitleSize - integer - a value from 25 to 500 representing scaling of burned subtitle font sizes, where 100 represents no scaling and is the default.
  • AudioSyncFlags - integer - a value from 0 to 3, where 0 means no special audio sync handling, 1 means to sync audio on start, 2 means to sync audio on resume, and 3 means both.
  • MpegtsM2tsMode - true/false, default is false - use M2TS mode when emitting mpegts streams, aka 192-byte packets with a valid timestamp.
A MusicProfile element has the following attributes:
  • container: the audio container used to encapsulate the music. This should generally be mp3.
  • codec: the audio codec used to encode the music. This should generally be mp3.
A PhotoProfile element has the following attributes:
  • container: the image container used to encode the photo. This should generally be jpeg.
For example:
<TranscodeTargets>
  <VideoProfile protocol="http" container="mpegts" codec="h264" audioCodec="aac,ac3,eac3" context="streaming">
    <!-- Inspired by Handbrake's Universal profile -->
    <Setting name="VideoEncodeFlags" value="-x264opts cabac=0" />
    <Setting name="SubtitleSize" value="100" />
  </VideoProfile>
  <VideoProfile protocol="slss" container="mp4" codec="h264" audioCodec="aac" context="streaming">
    <Setting name="VideoEncodeFlags" value="-x264opts cabac=0:keyint=50:min_keyint=50:scenecut=0" />
    <Setting name="AudioSyncFlags" value="3" />
  </VideoProfile>
  <VideoProfile protocol="hls" container="mpegts" codec="h264" audioCodec="aac" context="streaming">
  </VideoProfile>
  <MusicProfile container="mp3" codec="mp3" />
  <PhotoProfile container="jpeg" />
</TranscodeTargets>
The best combination for transcoded video is usually mpegts as container, h264 as video codec, and aac or ac3 as audio codecs. Older devices that cannot play h264 might prefer mpeg4 or mpeg2video as video codecs.
DirectPlay Profiles
DirectPlay Profiles define the set of video and photo formats that the device understands natively. If the device is highly capable, this may be a long list. A DirectPlayProfile element may contain multiple VideoProfile and PhotoProfile elements, each with its own set of attributes (as above). Each container, codec or audioCodec attribute may contain multiple entries, separated by commas. The cross-product of the combination of all attribute entries represent possible combinations of containers and codecs. For example, in the XML below, the asf container may contain various wmv codecs, but not h264.
<DirectPlayProfiles>
  <VideoProfile container="asf" codec="wmv2,wmv3,vc1" audioCodec="wmav2,wmapro" />
  <VideoProfile container="avi" codec="mpeg4" audioCodec="ac3,mp3" />
  <VideoProfile container="mp4,mov,mpegts" codec="h264,mpeg4" audioCodec="ac3,aac" />
</DirectPlayProfiles>
Codec Profiles
Codec Profiles provide a way to express the limitations of a device when playing specific video or music codecs. If the limitation applies to a given piece of media, then the media will be transcoded, even if the relevant codec is natively supported by the device.
A CodecProfiles element contains one or more VideoCodec, VideoAudioCodec or MusicCodec elements. Each element has a name attribute that identifies the relevant codec, as well as a set of limitations expressed under a Limitations element. The name attribute may also be "*", representing all codecs.
There are several types of limitation elements:
  • Match: the value of the metadata attribute must match the value of the limitation.
  • NotMatch: the value of the metadata attribute must not match the value of the limitation.
  • UpperBound: the value of the metadata attribute must be less than or equal to the value of the limitation.
  • LowerBound: the value of the metadata attribute must be greater than or equal to the value of the limitation.
Each limitation element must have a name attribute which identifies the name of the metadata to which the limitation applies, as well as a value, substring or regex attribute. The name of the limitation can be determined by viewing the metadata XML for a given video (see example above). The format of a name attribute is prefix.suffix. The suffix is the name of the relevant metadata attribute, while the prefix can be one of the following:
  • video: applies to the selected video stream element of a media item.
  • audio: applies to the selected audio stream of a media item.
  • part: applies to the relevant part element of a media item.
  • photo: applies to the media element of a photo media item.
A limitation may also have an isRequired attribute (set to true or false, and defaulting to true) indicating behavior if the metadata attribute is not present on the media. A required limitation whose name attribute that is absent in the media’s metadata is considered to apply to the media, while the absence of a non-required attribute is not.
Some examples follow:
<CodecProfiles>
  <VideoCodec name="mpeg4">
    <Limitations>
      <UpperBound name="part.size" value="4294967295" />
      <UpperBound name="video.width" value="1280" />
      <UpperBound name="video.height" value="720" />
      <UpperBound name="video.videoFrameRate" value="30" />
      <UpperBound name="video.bitrate" value="5120" />
    </Limitations>
  </VideoCodec>
  <VideoCodec name="wmv2,wmv3,vc1">
    <Limitations>
      <UpperBound name="video.width" value="1920" />
      <UpperBound name="video.height" value="1080" />
      <UpperBound name="video.frameRate" value="30" />
      <UpperBound name="video.bitrate" value="15360" />
    </Limitations>
  </VideoCodec>
  <VideoAudioCodec name="ac3,wmav2,wmapro">
    <Limitations>
      <UpperBound name="audio.channels" value="6" />
    </Limitations>
  </VideoAudioCodec>
  <VideoAudioCodec name="aac">
    <Limitations>
      <NotMatch name="audio.profile" substring="he-aac" />
    </Limitations>
  </VideoAudioCodec>
  <MusicCodec name="mp3">
    <Limitations>
      <UpperBound name="audio.bitrate" value="320" />
      <UpperBound name="audio.channels" value="2" />
    </Limitations>
  </MusicCodec>
</CodecProfiles>
Container Profiles
Container Profiles provide a way to express the limitations of a device when playing specific video containers. If the limitation applies to a given piece of media, then the media will be transcoded, even if the relevant container is natively supported by the device.
A ContainerProfiles element contains one or more VideoContainer, MusicContainer or PhotoContainer elements. Each element has a name attribute that identifies the relevant container, as well as a set of limitations expressed under a Limitations element. The Limitation elements are the same as the ones described in the section above.
For example, the following container profiles expresses two limitations: the device cannot handle mp4 containers with 64-bit offsets (aka co64 atoms), nor mkv containers whose video stream has stripped headers, nor very large jpegs:
<ContainerProfiles>
  <VideoContainer name="mp4">
    <Limitations>
      <Match name="part.has64bitOffsets" value="0" />
    </Limitations>
  </VideoContainer>
  <VideoContainer name="mkv">
    <Limitations>
      <Match name="video.headerStripping" value="0" isRequired="false" />
    </Limitations>
  </VideoContainer>
  <PhotoContainer name="jpeg">
    <Limitations>
      <UpperBound name="photo.width" value="4096" />
      <UpperBound name="photo.height" value="4096" />
    </Limitations>
  </PhotoContainer>
</ContainerProfiles>
Transcode Target Profiles provide a way to express the limitations of a device when consuming transcoded video. If the limitation applies to a given piece of media, then the media will be transcoded instead of Direct Streamed, even if the relevant codec is natively supported for Direct Streaming by the device over the specified protocol.
A TranscodeTargetProfiles element contains one or more VideoTranscodeTarget elements. Each element has protocol and context attributes, which are used in the same manner as described in the Transcode Targets section. Each element also contains at least one VideoCodec or VideoAudioCodec elements. These elements use the same format as described in the Codec Profiles section.
For example:
<TranscodeTargetProfiles>
  <!-- h264 with header stripping or compression doesn't Direct Stream correctly in hls streams-->
  <VideoTranscodeTarget protocol="hls" context="streaming">
    <VideoCodec name="*">
      <Limitations>
        <NotMatch name="video.headerStripping" value="1" isRequired="false" />
        <Match name="video.headerCompression" value="" isRequired="false" />
        <UpperBound name="video.bitDepth" value="8" isRequired="false" /> <!-- Nor does high-bitdepth video -->
      </Limitations>
    </VideoCodec>
  </VideoTranscodeTarget>
  <!-- h264 without cabac doesn't Direct Stream correctly in mpegts streams -->
  <VideoTranscodeTarget protocol="http" context="streaming">
    <VideoCodec name="h264">
      <Limitations>
        <Match name="video.cabac" value="1" />
      </Limitations>
    </VideoCodec>
</TranscodeTargetProfiles>
DLNA Media Profiles
DLNA Media Profiles provide a way to customize the DLNA.ORG_PN values, mime types and file extensions reported by Plex Media Server for specific media types. This is often necessary when authoring profiles for the pickiest devices, such as various Sony products.
A DlnaMediaProfiles element contains one or more DlnaVideoProfile, DlnaMusicProfile or DlnaPhotoProfile elements. Each of these may have the following attributes:
  • container, codec, audioCodec: similar to the attributes described in the Direct Play Profiles section
  • pn: the overridden DLNA.ORG_PN value to be used for the specified media types. When multiple comma-separated values are provided, each value is used to generate a separate res element with the respective PN value. This is useful for devices with regional preferences, such as certain Sony televisions.
  • mimeType: the overridden mime type to be used in Content-Type headers and DIDL for the specified media types
  • extension: the file extension to be used in res elements for the specified media types
Each profile element may have a Limitations element, with the same syntax as the Codec Profiles section.
When DIDL is emitted for a media item, the client profile’s DlnaMediaProfiles are evaluated in the order they appear in the profile. If the container and codecs match, and the limitations do not apply, then the overrides specified in the profile element’s attributes are applied to the res element in DIDL. If no matching media profile exists, then the server’s defaults are used.
For example:
<DlnaMediaProfiles>
  <DlnaVideoProfile container="mpegts" codec="h264" audioCodec="ac3,aac,mp3" pn="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T" mimeType="video/vnd.dlna.mpeg-tts">
    <Limitations>
      <Match name="video.packetLength" value="192" />
      <Match name="video.timeStamp" value="1" />
    </Limitations>
  </DlnaVideoProfile>
  <DlnaVideoProfile container="mpegts" codec="h264" audioCodec="ac3,aac,mp3" pn="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO" mimeType="video/mpeg">
    <Limitations>
      <Match name="video.packetLength" value="188" />
    </Limitations>
  </DlnaVideoProfile>
  <DlnaVideoProfile container="mpegts" codec="h264" audioCodec="ac3,aac" pn="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU" mimeType="video/vnd.dlna.mpeg-tts" />
  <DlnaVideoProfile container="mpegts" codec="mpeg2video" audioCodec="ac3" pn="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO" mimeType="video/vnd.dlna.mpeg-tts" />
  <DlnaVideoProfile container="mpeg" codec="mpeg1video,mpeg2video" pn="MPEG_PS_NTSC,MPEG_PS_PAL" mimeType="video/mpeg" />
  <DlnaMusicProfile container="wav" mimeType="audio/wav" />
</DlnaMediaProfiles>
DLNA custom template
Transcoding while using PMS over DLNA
Player XML User profile not being applied
Transcoding FLAC für UPnP Gerät sonst direkt streamen
Plex transcoding FLAC to 192kbps MP3 only!
Allow sync without transcoding
Plex transcoding profile
How to force transcoding to AC3 or DTS at HTPC
Client Profiles still relevant?
TrueHD Transcoding Inconsistencies - how to avoid Opus?
Plex Server Custom Transcode profiles
Writing a DLNA profile - TranscodeTargets being ignored?
Sync Original Quality still does a conversion
Automatically Set Preferred/Default Audio For Videos (audio format/codec) // mod: option to override
DV Files with type MKV not recognised as DV on LG - WebOS
Transcodificar video para formato reconhecido pela TV Samsung LN55B650 - Transcode video to format recognized by Samsung TV LN55B650
[solved] Help needed to make DLNA profile work for older Sony BRAVIA TV KDL-46HX855
Falsches Augmented Profile der Clients
Plex, Sonos, and Hi Res music content (24bit/32bit 48kHz/88.2kHz/176.4kHz/192kHz)
Plex web app error s3014/5/6 ONLY with AAC 5.1 audio
Plex Server not showing more details in Audio settings
User DLNA Profiles directory
Xml file for Samsung UN40F5500
No 5.1 surround sound - server selects "HTML TV App profile"
DLNA Profiles not being applied
AC-3 no sound
Wow. Looks like I restarted a dead engine. I have read all of your posts and thank all of you for giving all of us your input. I'm not computer savy so I will wait until someone with more computer literacy finds he solution to this problem and then I'll call my brother-in-law to help me.
What I think I'll do is see if Sharp has a computer department that can help us. I was just thinking: If I could plug in a USB stick with a few movies and see them on the screen the answer to this problem can't be too far away.
Introduction
Is there any more detailed documentation on the profile format, elements, fields, etc.? I would like to work on one for my Dish Network Hopper(s)/Joey(s).
Thanks!
No, this is it.
If you have questions that this text and the copious examples shipped in the product can’t answer, ask and I’ll update the text.
Examples will be very helpful. I'll look for them thanks.
I have LG TV from 2013 ( User-Agent="[TV][LG]50PH670S-ZD" ) and I would like to make the profile that would be able to transcode 720x576 anamorphic widescreen mpeg2 videos that should be watched with display aspect ratio 16:9 into 1024x576 to make them non-anamorphic. The pixel aspect ratio of these videos is 64:45, but LG TV shows them like if it was 1:1, i.e. all faces are unnaturally slim.
Unfortunately this makes watching Widescreen videos that are recorded from most european DVB-T programs impossible to use through DLNA.  I have a lot of such recordings (thousands) in mpegts container or normal mpeg program stream container. Also I have one DVD (VOB files, that have the exactly same issue, i.e. are 720x576 but with DAR 16:9), but it is only one DVD, I can transcode it manually with avconv.
I would like to transcode only those widescreen videos even though videos with 4:3 DAR are displayed also incorrectly (720/576=1.25 ; 4/3=1.333), but not so much. If it was unavoidable, I would also go for transcoding all (with additional benefit of having 4:3 rendered exactly to 768x576). I want to keep 576 lines, because the video could stay interlaced. Otherwise it would have to be deinterlaced and it usually does not deinterlace very nicely.
I was following instructions here, with no effect (no transcoding was triggered, it still shows original video badly rendered, even though Plex DLNA log is reporting matching my profile, it even mentioned something with the aspect ratio). This is what I tried :
I thought that I should add Transcoding Profile that would be able to fix the video. I did not find any list of Plex transcoding options, but is seems to be using ffmpeg or avconv transcoding options, so I have put "-vf scale=sar*iw:ih". It is the same as "-vf scale=dar*ih:ih". This is the whole section :
Looking into logs, this is obviously ignored, unfortunately. (I do not know why, CodecProfiles and DirectVideoProfiles seem to be ok)
Then I have added DirectPlay profiles. These include basically all videos as direct-playable. Anamorphic videos will be later excluded in CodecProfiles. At the end this should be used for all DAR 4:3 videos and additional AVIs I have, JPEGs etc. The TV is obviously playing almost everything I have, it is not very picky, (except for the aspect-ratio issue):
Finally CodecProfiles in my opinion is the key place, where I mark videos with certain aspect ration as unacceptable and force their transcoding. I have been doing very thorought research of the XMLs that is Plex providing. Fortunately they are very easily accessible through the Plex Web interface. The key is that I want to transcode videos with Pixel Aspect Ratio 64:45. Looking into Plex DLNA logs, this is actually working. Plex DLNA is mentioning videos that match this. (I can add relevant parts of the log and paste them here). This is the section CodecProfiles, I am using :
In spite of this all, no transcoding is done. The load on processor is insignificant (at CPU Intel Pentium G630T 2,3GHz Dual Core), no "Plex Transcode" process seems to be running (only Plex DLNA Server, Plex Media Server/Scanner) and the TV shows the wrong aspect ratio (unless the TV transcodes it back based on original XML provided by Plex DLNA, is it possible? If yes, could this be used to fake the XML to force LG TV to transcode the stream itself?).
I have put the profile into file : /usr/lib/plexmediaserver/Resources/Profiles/LG-PH50670S.xml
According to the log, it is obviously correctly matched with the TV through the correct User-Agent.
I have Ubuntu version 13.04
Plex is installed from the file plexmediaserver_0.9.7.28.33-f80a4a2_i386.deb
If it was possible, please, somebody from the Dev team look at my attempts to create the profile and perhaps correct mistakes I did. If I find out how, I can append some files, like part of logs or the whole profile. Thanks, Ludvik
Maybe this has already been posted but where do I put the user profiles on a mac? Can't find the info.
/Markus
ludvik02:
Very interesting scenario.
First, I believe PMS will already do the right thing with anamorphic content when transcoding. So you shouldn’t have to do anything special with VideoEncodeFlags. (Nor is -vf in there likely to work consistently, because IIRC ffmpeg cmd lines have limitations on the number of filters that can be provided and we already use filters for various things.)
So… you appear to have done more or less the right thing with your video.pixelAspectRatio limitation. The problem you’re running into is either a PMS bug or some mismatch between the limitation you wrote and the actual metadata. Can you post Plex XML for a sample video, so I can see the metadata the DLNA limitation engine is operating upon?
Also, 0.9.7.28 is fairly old as far as DLNA is concerned. It would be highly advisible for you to be on 0.9.8.4 - currently available from PlexPass, but which will be made public at some point in the near future.
/Markus
Create a Profiles directory, parallel to your Plug-ins directory. I believe that's under "~/Library/Application Support/Plex Media Server" on a Mac, but don't quote me on it.
ludvik02:
First, I believe PMS will already do the right thing with anamorphic content when transcoding. So you shouldn't have to do anything special with VideoEncodeFlags. (Nor is -vf in there likely to work consistently, because IIRC ffmpeg cmd lines have limitations on the number of filters that can be provided and we already use filters for various things.)
So... you appear to have done more or less the right thing with your video.pixelAspectRatio limitation. The problem you're running into is either a PMS bug or some mismatch between the limitation you wrote and the actual metadata. Can you post Plex XML for a sample video, so I can see the metadata the DLNA limitation engine is operating upon?
Hi mfeingol,
so I will try to remove the tag and leave merely this :
What should I look for in logs to check that the transcoding was started with proper parameters (and which log)?
This is an example of media XML. (The second audio channel is just empty - might be intended as comment for visually impaired)
That all looks right, actually.
In the Plex DLNA Server.log file, you should see log entries like this:
Aug 13, 2013 12:05:16:690 [12884] INFO - 480i - video.pixelAspectRatio limitation applies: 40:33 == 40:33
(I took your CodecProfiles snippet, changed the PAR value so it applied to a .wtv video I had sitting around, and ran it. It worked. And the result is an mpegts transcode stream offered to the DLNA client instead of the original file.)
If you’re not seeing this in your own log, it’s probably a PMS bug and 0.9.8.4 should fix it.
@mfeingol - I see such items in the Plex DLNA Server.log, but the video in LG TV is still distorted with wrong aspect ratio and TV reports resolution 720x576. I do not know whether it is transcoding anything, it seems not. I can send you the video to test it with the same video. These Log items seem not to be sign of the actual transcoding process, but rather some scan. They mostly appear when I connect to DLNA server or browse its directories.  They are  appearing for many videos including videos that are not played. There are two identical lines like this for every video:
Aug 14, 2013 02:56:47 [0xabef1b40] INFO - Cesta Do Vtelna 2013 03 25 21 55 - video.pixelAspectRatio limitation applies:
64:45 == 64:45
Aug 14, 2013 02:56:47 [0xabef1b40] INFO - Cesta Do Vtelna 2013 03 25 21 55 - video.pixelAspectRatio limitation applies: 64:45 == 64:45
When I play the video, nothing gets written into Plex DLNA Server.log file. There is also Plex DLNA Server Neptune.log, but results of instant scan of UPnP network seem to be written into this file, so it is hard to find there anything else.
I've been looking several places and still cant figure out some or all of the following
- where to put the file
- how to get it to read
- should I rename the other (system) profile
Here is what I have done on Windwos 7:
1.  Copied "Samsung SmartTV.xml" from "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Profiles"
2.  Placed the file (Samsung SmartTV.xml) in "C:\Users\O\Local Settings\application data\plex media server" and renamed it to "dlnaclientprofiles.xml"
3.  Renamed the file called  "dlnaclientprofiles.xml" in "C:\Users\O\AppData\Local\Plex Media Server\Plug-ins\System.bundle\Contents\Resources" to "dlnaclientprofles_HOLD.xml"
When I look at my log file, it says
"Aug 18, 2013 17:56:23:045 [5628] DEBUG - Reading system DLNA profiles"
with no mention of the client profile.
Please advise.  Thanks in advanced.
Where is exactly located the user client profiles file in OSX?
If it does not exist by default, where should I write it?
Francesco
Francesco
Instead of doing that, try this:
1. Same
2. Place the file in "C:\Users\O\Local Settings\application data\plex media server\profiles". Edit the file as you wish.
3. No step 3.
64:45 == 64:45
That looks like a limitation-induced transcode to me. Can you verify by checking that a process called PlexNewTranscoder.exe is running during playback?
Quote
If nothing is written to Plex DLNA Server.log, then something is wrong with your settings. Ensure you turn on debug tracing in the Web Client’s settings for PMS. Ignore Plex DLNA Server Neptune.log.
Hello Guys,
Would you help me writing my own DNLA profile for my Sharp Aquos LC32LE225? (EU model)
So far I'm not having all the issues that other people has with Sharp Aquos TVs. Actually it works well with Plex DLNA except for subtitles. This smartv has an embebed player called "Onyx" from Oregan Networks (http://oregan.net/dma.php).  In the other hand sharp profiles from plex forum doesn't work with this model
Plex server mapped to a generic profile, and I think uses direct play and not showing subtitles. So maybe with transcoding subtitles should works.
This is what I got from "Plex DNLA Server.log" file:
Nov 09, 2013 19:48:27:759 [2848] DEBUG - Mapped client to generic profile: Accept: */*; Accept-Language: en-gb,en-us; Connection: Keep-Alive; Host: 192.168.1.71:32469; Referer: file:/Home.html; User-Agent: Mozilla/5.0 (avui/tv; avvp/wmp; avkb/pc; Onyx/CelloTV(M&S) Windows; U; Windows NT 5.1; en-GB; rv:1.8.1.13) CE-HTML/1.0 OreganMediaBrowser/4.14.23 Gecko/20080311 Firefox/2.0.0.13; X-Oregan-Browser-Information: Oregan Media Browser-4.14.23r1-Linux-bcm7405-Broadcom-128bit-Ethernet-[USB][NoFontHintingOnFallback][ShockwaveFlashNoSound][NoPlugins][VOD][NoOnscreenKeyboard][NoEnglishIME][NoJapaneseIME]; X-Oregan-Licence-Information: SHRP3; X-Oregan-Screen-Information: Mode=UNKNOWN,Resolution=1280x720,VisibleArea=1152x648; transferMode.dlna.org: Interactive
The tv support Video codec: MPEG4, H.264 and audio MPEG4 AVC, AAC (http://www.sharp.it/cps/rde/xbcr/documents/documents/Marketing/Datasheet/pdf_DS_Datasheet_LC32LE225E_it_it.pdf)
I'm very new with profiles and I would really appreciate if someone could give me a template with this information to working on
Thank you!
Where on earth are user created/modified DLNA profiles supposed to reside on a OS X based PMS???
Yeah, there are a lot of "read the sticky" type answers to DNLA questions... but then improper/incomplete information contained within.  It can get very frustrating.  Skimming through the above, I see three people asked the same question about the very basic (but important) information of "where does it go?", to which there is no definitive answer?  Should it just be clearly documented where EXACTLY this Profiles folder should go, in each of the PMS platforms?
The sticky says:
but where is that?  Where is this supposed "Plex Media Server user directory"?   On a Mac?  On Linux?  Windows?  Etc etc.
Its really hard for anyone to move forward without that, no?
