Please tell me how supposedly valid backups taken over a period of time stop working because one single copy get corrupted? This makes no sense.
If you have a valid backup with PMS version X you can always roll back to that version of PMS with that specific backup and it will work. Corrupting one single instance of the database does not change them all.
FYI what you’re saying makes no sense especially if you have incremental system backups made by the OS or another 3rd party application.
I suspect database was broken before the update, but when said, then the scheduled backup should also stop, so puzzled here, thus why I asked for a db copy
I’d like to know too - I’ve tried both the Plex auto backups as well as system backups made by Windows Server Essentials (basically a standard shadow copy/VSS backup service) with the same results.
I even ran the integrity check command that’s in the ‘how to restore a corrupt db’ instructions and the command says that all of those files are corrupt.
It’s weird. Anyway, I sent Dane22 a link to my currently working DB that stops working if I do the 1.26 update (tried 3 times now).
Hi all. Dane22 went over my log files and I’m now back in business.
It turns out that I had a .wal file that was causing problems - even when I tried to use a post-migrated db.
In the end, I also had to delete the com.plexapp.plugins.library.shm and com.plexapp.plugins.library.wal files. Started with just the com.plexapp.plugins.library.db file and all was good (Plex auto created new versions of those files afterwards).
