Hi all!
I’m planning to change my old server running on a clone PC to a HP Server with 2X 2.66GHz X5650 processors.
Would the processors be able to do transcoding for 2 or 3 streams?
Thanks in advance!
Hi all!
Thanks in advance!
That is a really bad system for Plex. Outdated CPU, outdated drives with less than 1 TB storage. I would not waste money on it.
You would be better off buying a N100 mini PC with a 1 TB SSD.
CPU: Introduced in 2010, so 15 years old. Pulls 95 watts.
Drives: Less than 600 GB storage (4 x 146GB).
Memory: Uses DDR3 memory, which is OK, but slow by today’s standards.
To directly answer your question: Yes, it could transcode two or three 1080p video streams. 4K is out of the question.
Thanks for your fast reply!
I have other server with the media so drives is not an issue here, but well noted your comments about CPU and RAM.
Thanks again.
Regards.
And what’s your opinion on a i7 7th gen?
Can add also a GTX 1050 2GB GPU…
Trying to recycle here…
thanks!
i7-7700 (plain one)
8800 passmarks (Quad core)
UHD 630 GPU
Solid performer for PMS (I have three of these for PMS testing)
