[3.0.17] Image items issues
My Surface Pro 4 (2736x1824) trying to view images that have the resolution of 5258x2960 do not scale. So I see them closely zoomed and no way to change that.
So next to the wrong scaling it is also not giving controls to zoom are get file info.
Is it just those size images that are not pinch-zooming, or is it all images?
for me its all images. I just checked some really old foto’s at 1536x1024 (should be smaller) and even that opens zoomed. So it seems the calculation is off on my high res screen or due to my display zoom settings (at 200%). I will try that next
Yes that does the trick. When I set it back to 100% (200% is the recommended setting for my screen) than the pictures auto fill perfectly. But than, as can be expected, the letters are really small.
