401 Error
Server Version#:1.41.7.9717
I’ve been running this server in a docker container on an Intel 11 NUC PAH for maybe just over a year now. Have never encountered this problem before.
All my other devices seem to connect to Plex just fine (Android, Tablet, TV). I can also access my content through plex.tv.
Other than updating Plex, I updated ubuntu last night to 24.04.02 (from 22.04, i think).
It’s not a huge problem since I can access my content through other means. Just thought it was very strange.
They seem to have removed the redirect that happened at the base url, if you add /web manually it probably works fine.
Thank you for pointing that out.
As you suspected, adding /web worked.
Having the same issue as others. Putting in /web does fix the issue for now.
Seeing the same thing after updating, rolling my docker container version back and back to old behavior. Hope this is a change that can be reverted. Cheers!
This seems to be breaking Plex on my Google TV (NVIDIA shield). I can’t play anything and only get “An error occurred while attempting to play this video”
Having the same issue here. If you are using a proxy, you can rewrite the URL manually.
They should fix this though, in my opinion.
Hello,
I’m using Windows Server 2019 as Server and a Reverser Proxy (Zoraxy) for External access. The rewrite through the proxy is not working. I have to manualy wirte /web into the URL.
Yes, they should fix this…
Jup same here,
https://plex.example.org/ will fail with 401.
https://plex.example.org/web will redirect.
Also have this using CF zerotrust. Adding /web manually is not a fix right, its a circumvent. Plex please fix this
@dotzeno Please remove “Solved” mark since it isnt solved lol.. thanks
https://support.plex.tv/articles/200288666-opening-plex-web-app/
It’s documented like that since the beginning.
There is no need to use the local web app, unless you need to claim the server, or there is an Internet outage.
@OttoKerner I think you are missing the problem.. We have reverse proxy configuration for the PMS pointing to ip:32400 - nothing more. When accessed Plex at plex.example.com it automatically redirected to the PMS. It worked for years and years.. and suddenly out of the blue it doesnt work:
Based on other users not just me I strongly believe Plex broke it.. I did not find a way to address this change on clients end.. neither pointing RVP to ip:32400/web nor adding segment /web/ to the path etc..
