46143 INDIANAPOLIS Missing EPG
Channels missing from EPG list
Local Broadcast Listings
13.13 - WTHR-HD
21.1 - WSWY-LD
21.2 - RTV
21.3 - REVN
21.4 - Action
21.5 - Family
21.6 - Revival
21.7 - GLTVii
32.1 - WSDI-LD
32.2 - WSDI-LD
32.3 - WSDI-LD
32.4 - WSDI-LD
32.5 - WSDI-LD
32.6 - WSDI-LD
32.7 - WSDI-LD
47.5 - TCT
69.2 - WDTI-ES
69.3 - WDTI-SD
UNITED STATES
46143
INDIANAPOLIS
Version 1.41.3.9314
Is this a typo? should it be 13.1? I cannot find a 13.13 anywhere.
If it is a typo do you see a 13.1 WTHRDT in the lineup edit window? When looking up the lineup for that zip code it shows as available.
Nope, not a typo. Wikipedia shows it as a translator?
WALV-CD 13.13 Indianapolis (city)
As far as I can see that is a duplicate of 13.1 so you should be able to set that to use the EPG for 13.1
Also I am still making reports for the other channels but be aware that Gracenote is likely to not add any of the -LD (low definition) channels to their DB if they don’t already have EPG data them.
