Apple TV - 2026.11.0 (1767) TestFlight
NEW:
- Add actions for adding content to playlists and collections.
- Email to the account settings screen.
- Live TV: Show channel information on channel header focus.
FIXES:
- Deleting a playlist would silently fail.
- Fix initial focus landing on Cast & Crew on some detail pages.
- Fixed a crash that could happen when launching the app from an unknown deep link.
- Fixed an issue that prevents moving focus to the card on activity detail pages.
- Fixed focus jumping to the top navigation when changing a filter or sort on a Library Browse screen.
- Fixed images reloading from the network when returning to a screen.
- Fixed info-only menus (such as the How to Watch side sheet) requiring an extra Back press to dismiss.
- Fixed the empty Watchlist screen so you can select several suggested items before pressing Done, instead of each selection being undone or sending you straight to your Watchlist.
- Focus could be lost when navigating up from the episode list to the season top nav, forcing the user to press back to escape.
- Moderated comments on activity details could not be focused.
- Player: Live TV playback could stop after initial airing ended.
- Player: Marker button would steal focus when seeking.
- Player: album artwork on player could disappear.
- Player: prefer playing versions that exist over ones that don’t.
- The context menu would stay open after performing some actions.
- Using the trackpad to move focus through the jump bar caused it to jitter.
- Wrong initial focus on Play History screen.
