Plex for Mobile & TVs (Android Mobile, iOS, Android TV, tvOS, Fire TV)
Plex for Android 2026.23.0 (Google Play)
Plex for iOS 2026.23.0 (App Store)
NOTE: Timings for submissions, approvals, and releases in the app stores can vary. Each release gets rolled out to users over the course of multiple days. If you don’t see the new release available for your device yet, please be patient.
NEW:
  • Critic ratings on album details.
  • Library folders show as a list or a grid, open without leaving the library, and can be played or shuffled from their menu.
  • Plex Home members can set, change or remove their own PIN, and admins can also set the PINs of managed users.
  • Settings are grouped into Account, Experience, Manage, Advanced and Info sections.
  • Updated the design of the profile’s Lists, Ratings & Reviews and Discussions cards.
  • Video quality can be changed from a movie or episode’s More menu before playback starts.
  • [Android][Android TV][Fire TV] Checkerboard background behind clear logos on the Change Artwork screen.
  • [Android][Android TV][Fire TV][iOS][tvOS] New and improved Player, ready to try under Settings > Player Experience > Next Player.
  • [Android][iOS] You can now search for media items and add media items to a list on the list details screen.
  • [Android][iOS][Meta Horizon] Edit metadata and tags for artists, albums and tracks.
  • [iOS] Settings has a solid background, matching Android.
  • [iOS][Android] The PIN screen shows whose PIN you are entering, and the profile picker scrolls a row at a time.
  • [iOS][Android][tvOS][Android TV][Fire TV] The profile picker has a new layout that fits your screen, with the Manage button below the profiles.
  • [iOS][tvOS] Player: Change the subtitle color, size, position and background in Settings.
  • [iOS][tvOS][Android][Android TV][Fire TV] Browse by style or mood from artist and album pages.
FIXES:
  • Artist and album posters on the Change Artwork screen showed in portrait frames instead of squares.
  • Artists You Might Like tiles from friends’ servers didn’t show which friend each artist was from.
  • Critic reviews would attempt to open outside of the app.
  • Fewer error screens when the service is rate limiting requests, the app now waits and tries again.
  • Fixed subtitles still being burned in when Burn Subtitles was set to Never.
  • Some menus and screens, such as Licenses and the play queue, scrolled inside a second scroll area.
  • The actions menu for an episode or title spun for several seconds and then closed when its actions failed to load.
  • The activity screen for a movie, show, season or episode kept loading forever when its activity couldn’t be loaded.
  • Videos split into multiple parts now explain that the server needs updating, instead of only playing the first part.
  • [Android TV] Dolby Digital Plus and Atmos passthrough could play silent or switch to a converted stream on the NVIDIA SHIELD with the new player.
  • [Android TV] Fixed video shrinking into a corner when opening Quick Settings during playback on some Google TV devices.
  • [Android TV] With refresh rate switching on, playback with the new player could stay paused after the TV changed mode until Play was pressed.
  • [Android TV][Fire TV] Fixed a crash on some Android TV devices when starting a cast session.
  • [Android TV][Fire TV] Fixed crashes in account notifications and when fixing a match with no results.
  • [Android TV][Fire TV] Fixed crashes on the details screen episode row and when refreshing a user list.
  • [Android TV][Fire TV] Fixed focus jumping along the Continue Watching row after an item was marked as watched.
  • [Android TV][Fire TV] Moving down from the top buttons focuses the progress bar again, instead of the elapsed time next to it.
  • [Android TV][Fire TV] Opening an episode from a row on Home focuses that episode again, instead of the season buttons at the top.
  • [Android TV][Fire TV] Pressing Back in All Libraries closed the side menu as well.
  • [Android TV][Fire TV] Pressing Back in Settings or Notifications opened from your profile in the side menu sometimes closed the side menu.
  • [Android TV][Fire TV] Pressing Play or Back on the profile picker started a video behind it or skipped the lock.
  • [Android TV][Fire TV] Pressing left on the first review, list or discussion card in a row didn’t open the side menu.
  • [Android TV][Fire TV] The remote’s direction buttons and Select keep working after you hold Left or Right to fast-forward or rewind.
  • [Android TV][Fire TV][Android] The app could crash when moving focus on devices running Android 14 or older.
  • [Android TV][Fire TV][tvOS] Moving down All Libraries sometimes left focus on the buttons beside each library instead of the libraries.
  • [Android TV][Fire TV][tvOS] Moving through Popular Reviews on TV no longer stutters or leaves gaps between reviews.
  • [Android TV][Fire TV][tvOS] Play and Back on the remote reached the video behind the profile selection screen, letting you skip the PIN.
  • [Android TV][Fire TV][tvOS] Some cards in the Activity feed showed no highlight when focused.
  • [Android TV][Fire TV][tvOS] The Rate & Review panel now shows the season and episode under the show’s title.
  • [Android TV][Fire TV][tvOS] The row above’s background stayed on screen after moving down to a row of review, list or discussion cards.
  • [Android TV][tvOS][Fire TV] Folders holding both subfolders and videos showed overlapping, jumbled tiles.
  • [Android TV][tvOS][Fire TV] The clock no longer wraps onto two lines in the evening for languages that show the time as “11:02 pm”.
  • [Android] A long server name in the Live TV header ran into the buttons beside it.
  • [Android] Downloads watched to the end while offline weren’t marked as played.
  • [Android] Fixed a crash when going back quickly through nested screens.
  • [Android] Prevent bottom sheets from displaying under camera cutouts.
  • [Android] Tapping a push notification didn’t open the app.
  • [Android][Android TV][Fire TV] 10-bit H.264 videos dropped most of their frames.
  • [Android][Android TV][Fire TV] Fixed a crash on the player screen when the layout changes.
  • [Android][Android TV][Fire TV] Fixed a crash when playback starts while the app is in the background.
  • [Android][Android TV][Fire TV] Fixed a crash when rotating the player or leaving a screen quickly.
  • [Android][Android TV][Fire TV] Fixed a frozen image covering live TV and trailers after switching to full screen.
  • [Android][Android TV][Fire TV] Improved scrolling performance of Popular Lists, Popular Discussions and Popular Reviews on Home.
  • [Android][Android TV][Fire TV] Opening a link to the app from an email or a notification sometimes showed Home instead of the linked screen.
  • [Android][Android TV][Fire TV] Playback sometimes crashed the app when stopping or seeking a video.
  • [Android][Android TV][iOS][tvOS][Fire TV] Selecting a Plex rental under Where to Watch did nothing.
  • [Android][iOS] Long pressing a spotlight with no menu actions opened an empty More Actions menu.
  • [Android][iOS] On phones, the music player’s playback buttons sat off-centre and the progress bar was below the play queue and settings buttons.
  • [Fire TV][Android TV] Some library TV episodes cast from a phone didn’t start playing on the TV.
  • [Meta Horizon] The player offered 3D Mode for live TV and Plex streaming content, where it doesn’t apply.
  • [iOS] Menus on iPad could be cut off, which stopped the episode list from scrolling to the end and hid the Go to Season and Go to Show buttons.
  • [iOS] The library title was over-padded and the server name was centered instead of left aligned.
  • [iOS][Android] Downloads stopped working for some people after updating the app.
  • [iOS][Android] Fixed a comment you just posted sometimes not appearing until you refreshed.
  • [tvOS] Fixed focus briefly jumping to the first action when backing out of a menu sub-level.
  • [tvOS] Fixed focus briefly jumping to the side nav account row when backing out of a menu sub-level, such as Settings.
  • [tvOS] Fixed the details shown under a row staying on an item after it was removed from Continue Watching.
  • [tvOS] Holding Left in a row no longer opens the side menu before you reach the row’s first item.
  • [tvOS] Left didn’t open the side menu from some Home rows, like Popular Reviews and Plex Playback.
  • [tvOS] Player: The Skip Intro and Skip Credits buttons couldn’t be reached from the previous button.
  • [tvOS] Player: The controls could disappear while moving between the buttons with the remote.
  • [tvOS] Right didn’t close the side menu on season and episode pages.
  • [tvOS] Search filters would disappear when picking a filter with no results.
  • [tvOS] The main screen content would gain focus when opening the settings from the account popover.
  • [tvOS][Android TV][Fire TV] Opening your profile on TV now focuses the Plex Playback button instead of leaving focus in the side menu.
  • [tvOS][Android TV][Fire TV] Pressing Home while a FAST channel plays fullscreen now stops it, instead of leaving it streaming in the background.
  • [tvOS][Android TV][Fire TV] Shows from libraries using the NFO agent opened without focus on Play, and on Apple TV couldn’t be reached with the remote.
  • [tvOS][Android TV][Fire TV][iOS][Android] The last screen you were on no longer flashes before the user picker when you come back to the app.
  • [tvOS][iOS] Fixed a crash when pressing remote or keyboard arrow keys in quick succession.
