Caldera Music Release Notes
Caldera Amp v1.2.0-beta.23, Caldera Music tvOS v1.2.1 (Build 52), Caldera Music for Google TV v1.2.0 (versionCode 30)
Platforms: macOS v1.2.0-beta.23 (Build 44); Windows v1.2.0-beta.23; Linux v1.2.0-beta.23; tvOS v1.2.1 (Build 52); Google TV v1.2.0 (versionCode 30)
New
  • Remotes can turn loudness leveling, the EQ, Sweet Fades and Direct mode on and off through the companion API, and see whether each is on.
  • Now Playing shows the album’s year after its name.
Apple TV and Google TV
  • Settings > Display > Screensaver While Playing lets the TV’s screensaver start while music plays, instead of the app holding it off.
  • Word-timed lyrics light up word by word as they are sung, karaoke style. Line-timed lyrics still light up a line at a time.
  • The Library lists your artist, album and track collections, smart ones included, wherever a library has some. An artist or album collection opens as a grid, a track collection as a track list like a playlist, each with Play and Shuffle for the whole collection.
Caldera Amp
  • The mouse pointer hides over a full-screen visualizer after a few seconds without moving, and comes back when the mouse moves.
Fixed
  • A live DTS transcode no longer sits on the buffering spinner once it starts playing.
  • With Direct on, the signal path no longer lists a dither stage and shows bit-perfect when nothing changes the audio.
  • On a slower connection, such as a remote server, a track that isn’t cached yet starts cleanly instead of playing a moment and then pausing to buffer.
  • A track with a large embedded cover, or one seeked into while it is still downloading, starts playing in a second or two instead of up to twenty.
  • With Match Source, the last track of a queue plays when its sample rate differs from the track before it, instead of playback stopping before it.
  • Grouped rooms stay together when a new album starts, and a group with a room that needs a long buffer no longer drifts apart, skips on the room playing, and keeps growing its delay.
  • Playing a shuffled playlist or library from Plexamp keeps Plexamp’s shuffle button on, and pressing it no longer reshuffles the whole queue.
  • Plexamp’s signal path shows a Caldera player’s resampling rate change once instead of twice.
  • A track that starts downloading while the cache is clearing space is no longer deleted part way through and downloaded again.
  • A room in a group no longer drops out for a moment when the group is paused and played again in quick succession.
  • Plexamp’s Multiroom settings show the app’s real version instead of 1.0.0.
  • Loudness leveling holds each song at one level, instead of dropping it and raising it again in its first seconds, on libraries Plex hasn’t analysed for loudness.
  • The disk cache limit holds for the first tracks after the app starts, instead of a download that fills it there going on past the limit.
  • A room playing another room’s music shows that room’s source and its whole chain in the signal path, graded together.
  • A room that paused its own track to play another room’s music reports the chain it is playing instead of the paused track’s.
  • After skipping to a track that was already loaded, the signal path shows that track’s source instead of the previous track’s.
  • The signal path no longer lists the EQ while it is on but flat, since it leaves the audio untouched.
  • Lyrics show for the track that was playing when the app was last closed, instead of the lyrics button staying greyed out until the next track.
Apple TV
  • Pressing Select on the Library tab from an artist or album goes back to the full Library.
  • Plain-text lyrics say to press Select to scroll them.
  • The tab bar no longer goes missing after Back to the Library from a scrolled artist or album page.
  • Back no longer leaves the app from Now Playing: with the controls dimmed it brings them back, and from the tab bar on any tab it goes to Home first.
  • Scrolling a Home row no longer jumps back toward the start while the rows reload over and over.
  • Music keeps playing when you go to the Home Screen right after signing in, instead of pausing until you reopen the app, and Play in Control Center starts it again.
  • Lyrics no longer get stuck loading while the visualizer is running.
  • In the Library, pressing Up from any card reaches the view and sort buttons, not only from cards right below them.
  • A playlist longer than 200 tracks shows its whole length, not the length of its first 200 tracks.
  • Now Playing’s buttons no longer run into each other: one heart rates the preset (loved, blocked or neither), and shuffle, auto-advance, color tint and preset browsing share one menu.
Google TV
  • Exclusive Audio on a device that can’t provide it no longer pauses playback for about 25 seconds whenever the sample rate changes; the device is asked once, and again after Exclusive is turned off and back on.
Caldera Amp
  • The chosen output device, such as a USB DAC, is used again when playback resumes after an idle pause, instead of the Mac’s built-in speakers when the DAC had gone to standby.
  • On Windows, the tray tooltip and menu show apostrophes and accented letters in track and speaker names correctly.
  • On Windows, Caldera Amp starts on a PC that doesn’t have the Visual C++ runtime installed, instead of failing with a missing DLL.
  • On Linux, Caldera Amp stays in Plexamp’s player list instead of dropping off it.
