Caldera Music Release Notes
Caldera v1.2.0-beta.29
A beta of every Caldera player:
  • Headless v1.2.0-beta.29, with Plexamp web 4.50.21-beta.53
  • Amp v1.2.0-beta.29 (macOS, Windows, Linux)
  • Apple TV v1.2.1 (build 56), TestFlight
  • Google TV v1.2.0 (versionCode 35), Play beta
The Apple TV and Google TV builds reach testers once Apple and Google finish reviewing them.
New
  • Search can cover every music library on the server, not just the one you’re browsing: turn on Search All Libraries in Settings, and each result names its library.
Fixed
  • After a player restarts, Plex remotes show its volume where it was left, instead of a default.
Apple TV and Caldera Amp for macOS
  • Starting something new while music plays fades the old music out once, instead of cutting it off, playing it again for a moment, then stopping.
Headless and Caldera Amp for Linux
  • With PipeWire output, the DAC switches to each track’s sample rate when it supports it, instead of staying at 48 kHz and resampling.
Apple TV and Google TV: Now Playing
  • The queue, lyrics and signal chain share the right side: Side-by-Side Queue sits underneath, lyrics or the signal chain show over it, and hiding them brings the queue back. The cover and titles sit centred beside whichever is showing, and the signal chain is no longer cut off.
  • Turning on Side-by-Side Queue while lyrics are showing puts the queue up at once.
  • With the visualizer off, Now Playing follows the Light theme, with a pale wash of the cover’s colours and buttons inked firmly enough to read.
  • The track’s titles stay beside the cover when the controls go away, unless Show Track Titles is turned off in Settings.
  • When Down has put the controls away, pressing Down again brings them back.
  • The visualizer’s on-screen stats no longer show while the visualizer is turned off.
Apple TV
  • With the visualizer off, the background blurs the cover’s colours across the screen instead of a single glow behind it.
  • Now Playing’s More menu has Go to Artist and Go to Album again.
  • A paused Caldera you return to and leave again no longer starts playing by itself a minute later.
