A documentation about the types of objects
I need it very much
Hello everybody!
I need the documentation on the types of objects in Python's development very much.
There I wrote about my problem:
http://forums.plexapp.com/index.php/topic/34451-the-windows-media-format-for-a-plugin-on-plex-server-for-mac/ :unsure:
I realized I need a good documentation about objects.
Can you help me?
To the best of my knowledge (which is very limited) all object types in Plex are documented here: http://dev.plexapp.com/docs/api/objectkit.html
Note this doesn’t cover the old framework. You may want to just dig in to the code for that under ~/Library/Application Support/Plex and ~/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/ to find out any undocumented objects for the v1 Framework.
