Server Version#: 1.26.0.5715
I am hoping someone will be able to help me.
After doing a apt upgrade on the system (Ubuntu 20.04.4 LTS) Plex stopped “seeing” my server. I deleted the Preferences.xml file to start again and re-installed plexmediaserver from the deb file.
This time I get the error “A problem has been detected with a core component of Plex Media Server.” on the Server Setup screen after logging the server in on my account.
I’m not using a proxy or VPN. I was logging in to the web client through the direct local ip address of the server 192.168.x.x:32400/web (where 192.168.x.x is my plex server’s local IP address).
I get the following errors in my syslog:
daniel@badboy:/var/log$ cat syslog.1 | grep plexmediaserver
May 6 00:04:46 retief Plex Media Server[3789]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/PlexSeries.bundle.
May 6 00:22:02 retief Plex Media Server[3969]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/PlexMovieNew.bundle.
May 6 00:22:02 retief Plex Media Server[3968]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/PlexMusic.bundle.
May 6 00:29:35 retief Plex Media Server[4028]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/HTbackdrops.bundle.
May 6 00:44:40 retief Plex Media Server[4187]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/LastFM.bundle.
May 6 00:44:40 retief Plex Media Server[4186]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/MoviePosterDB.bundle.
May 6 00:52:12 retief Plex Media Server[4244]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/PlexThemeMusic.bundle.
May 6 01:07:18 retief Plex Media Server[4332]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-8cf78dab3/PlexMovie.bundle.
Here is a list of recently upgraded packages:
2022-05-04 06:06:31 upgrade mysql-server:all 8.0.28-0ubuntu0.20.04.3 8.0.29-0ubuntu0.20.04.2
2022-05-04 06:06:34 upgrade libmysqlclient21:amd64 8.0.28-0ubuntu0.20.04.3 8.0.29-0ubuntu0.20.04.2
2022-05-04 06:06:36 upgrade mysql-client-8.0:amd64 8.0.28-0ubuntu0.20.04.3 8.0.29-0ubuntu0.20.04.2
2022-05-04 06:06:39 upgrade mysql-client-core-8.0:amd64 8.0.28-0ubuntu0.20.04.3 8.0.29-0ubuntu0.20.04.2
2022-05-04 06:06:43 upgrade mysql-server-8.0:amd64 8.0.28-0ubuntu0.20.04.3 8.0.29-0ubuntu0.20.04.2
2022-05-04 06:06:47 upgrade mysql-server-core-8.0:amd64 8.0.28-0ubuntu0.20.04.3 8.0.29-0ubuntu0.20.04.2
2022-05-04 06:07:08 upgrade mysql-client:all 8.0.28-0ubuntu0.20.04.3 8.0.29-0ubuntu0.20.04.2
2022-05-05 21:40:43 upgrade libssl-dev:amd64 1.1.1f-1ubuntu2.12 1.1.1f-1ubuntu2.13
2022-05-05 21:40:44 upgrade libssl1.1:amd64 1.1.1f-1ubuntu2.12 1.1.1f-1ubuntu2.13
2022-05-05 21:40:44 upgrade networkd-dispatcher:all 2.1-2~ubuntu20.04.2 2.1-2~ubuntu20.04.3
2022-05-05 21:40:44 upgrade openssl:amd64 1.1.1f-1ubuntu2.12 1.1.1f-1ubuntu2.13
2022-05-05 21:40:44 upgrade librados2:amd64 15.2.14-0ubuntu0.20.04.2 15.2.16-0ubuntu0.20.04.1
2022-05-05 21:40:44 upgrade libcephfs2:amd64 15.2.14-0ubuntu0.20.04.2 15.2.16-0ubuntu0.20.04.1
2022-05-05 21:40:45 upgrade libpq5:amd64 12.9-0ubuntu0.20.04.1 12.10-0ubuntu0.20.04.1
2022-05-05 21:40:45 upgrade libsensors-config:all 1:3.6.0-2ubuntu1 1:3.6.0-2ubuntu1.1
2022-05-05 21:40:45 upgrade libsensors5:amd64 1:3.6.0-2ubuntu1 1:3.6.0-2ubuntu1.1
2022-05-05 21:40:45 upgrade linux-firmware:all 1.187.29 1.187.30
2022-05-07 06:12:59 upgrade rsyslog:amd64 8.2001.0-1ubuntu1.1 8.2001.0-1ubuntu1.3
2022-05-07 06:13:03 upgrade mysql-client-core-8.0:amd64 8.0.29-0ubuntu0.20.04.2 8.0.29-0ubuntu0.20.04.3
2022-05-07 06:13:07 upgrade libsqlite3-0:amd64 3.31.1-4ubuntu0.2 3.31.1-4ubuntu0.3
2022-05-07 06:13:09 upgrade mysql-server:all 8.0.29-0ubuntu0.20.04.2 8.0.29-0ubuntu0.20.04.3
2022-05-07 06:13:11 upgrade mysql-client:all 8.0.29-0ubuntu0.20.04.2 8.0.29-0ubuntu0.20.04.3
2022-05-07 06:13:13 upgrade mysql-client-8.0:amd64 8.0.29-0ubuntu0.20.04.2 8.0.29-0ubuntu0.20.04.3
2022-05-07 06:13:16 upgrade mysql-server-8.0:amd64 8.0.29-0ubuntu0.20.04.2 8.0.29-0ubuntu0.20.04.3
2022-05-07 06:13:19 upgrade mysql-server-core-8.0:amd64 8.0.29-0ubuntu0.20.04.2 8.0.29-0ubuntu0.20.04.3
2022-05-07 06:13:28 upgrade libmysqlclient21:amd64 8.0.29-0ubuntu0.20.04.2 8.0.29-0ubuntu0.20.04.3
2022-05-07 20:41:45 upgrade plexmediaserver:amd64 1.26.0.5715-8cf78dab3 1.26.0.5715-8cf78dab3
2022-05-07 21:12:29 upgrade unifi:all 7.0.25-17292-1 7.1.61-17860-1
2022-05-07 21:32:12 upgrade plexmediaserver:amd64 1.26.0.5715-8cf78dab3 1.26.0.5715-8cf78dab3
Plex media server logs attached.
Logs.zip (21.8 KB)
