Hello folks,
I'm quite new to channel development so this is probably an easy question for you to answer.
Is there a direct way (via an API) to access the library of the PMS or do I have to make XML request to the API myself?
If I have to use XML is there anywhere an URL Service available which parses Plex items like http://localhost:32400/library/metadata/73863 directly to a MovieObject or any other predefined object class?
CCarpo
