Is there a way to access the MovieObject/EpisodeObject metadata once you are in the MediaObjectsForURL(url) function while you are in the URL Service? :blink:
I would like to change the thumb image of the MovieObject/EpisodeObject metadata if I find out that the stream video is not available. <_<
-Thanks
No, this is not possible. Maybe you could add some extra check in the MediaObjectsForURL function to check if a video is available or not?
If the video is not available or Host site has changed it's code causing an issue I just make it play an error video if you select the video to play. Thanks again sander for your help!!! I will just leave it as is then.
Off from this topic might look into the idea of multithreading and see if I can use this to help with time out issues loading hosts. Thanks again for your help. :)
