Add a 5-10 second rewind and skip in plexamp app
Plexamp is good but would like a 5-10 second rewind and skip option in plexamp app. I have the 3rd party audiobook integration but even for music sometimes its easier than manually going back or forward.
Thanks, i couldnt find anything when i was researching before. Not sure why this isnt on by default
Because you don’t need it for music. The progress bar is usually accurate enough for scrubbing in a ~4 minute song.
And as I’ve explained in the thread, these buttons appear automatically, if the library has “store playback progress” activated. Which is usually active in a library with audio books.
