Agent language
Server Version#: 1.21.2.3943
Player Version#: 4.51.1
When the metadata scanners try to retrieve information for my TV shows they rarely succeed. I have to manually specify “English” instead of “Français” (French) in the dropdown :
Then it works like a charm.
My server’s language settings are :
So, my question is : how do I tell the scanners to use “English” as default ?
BTW : I already checked my agents’ (TheTVDB, The Movie Database,…) and there is no language param to set.
Any idea ?
  1. convert the librtary to use the new agent Migrating a TV library to use the new Plex TV Series Agent/Scanner | Plex Support
  2. make sure your files conform to the naming schema Naming and Organizing Your TV Show Files | Plex Support
  3. the language of the metadata is defined in the properties of each library
