It would be great if Server-Mac, Server-Windows, Player-Mac, etc were alphabetized in the dropdown boxes. It would make searching for the tag so much easier.
I’ll see if that is possible. You can search for tags directly in the dropdown. just type “mac” for example and it will filter the dropdown
Thanks! I have used the search, but sometimes I want to see what’s there to make the best choice.
FYi I changed it back because i got a few messages about it and a bunch folks who were used to having popular tags first started hitting the wrong similar tag because it was before the correct popular one they were used to. ( so we ended up having a lot more incorrectly tagged post than usual)
I appreciate the effort. I now know I can search so that should work fine. Thanks.
