Amazon Drive Hanging at "1 sec left"
I know this isn’t a Plex Pass issue, but it’s happening when I’m uploading my media for Plex Cloud. All my large file > 4gb, hang at “1 second left”
I have to restart the drive app, then “randomly” it clears. Anyone else run into this? I’m on windows 10 pro insider preview.
thanks
Yes, I had lots of problems uploading my larger files using the Amazon app. I have moved to odrive and all my movies are uploading happily with it.
Another good uploader is rclone, but that’s a bit more fiddly to set up.
I’m seeing the same, but you don’t have to restart it (if by that, you mean close/open the app). Just hit the pause all button (upper right) and then restart all and they clear out and move on. Sadly, means that it needs to be babysat for larger file uploads unless a solution presents.
