Server Version#: Version 1.32.5.7349 (latest stable)
- I’ve installed docker-compose container with latest plex image
services:
plex:
cpu_shares: 90
command: []
container_name: plex
deploy:
resources:
limits:
memory: 3366M
reservations:
memory: "268435456"
devices:
- /dev/dri:/dev/dri
- /dev/dvb:/dev/dvb
image: plexinc/pms-docker
restart: unless-stopped
volumes:
- type: bind
source: /DATA/AppData/plex/config
target: /config
- type: bind
source: /DATA/transcoding
target: /transcoding
- type: bind
source: /media/devmon/NAS
target: /NAS
ports: []
cap_add: []
network_mode: host
privileged: false
- Enabled HW transcoding
- Tried to open a Movie with Auto Converting On
- I can see in the logs
plex | /data/jenkins/conan_build/1112346209/conan/.conan/data/libdrm/2.4.115-1/plex/stable/build/42eba9224a0a19c9b983c233343e5610c7362833/meson-install/share/libdrm/amdgpu.ids: No such file or directory
plex | amdgpu: The CS has been rejected (-22), but the context isn't robust.
plex | amdgpu: The process will be terminated.
It happens every time, transcoding doesn’t work. Logs archive attached
