Android: Material You Themed icon
Please add a Material You Themed icon to the Android app. Makes the app much more visually pleasing, and more likely to be used on mobile.
Would you mind elaborating what you mean by „Material You Themed icon“? Maybe an example and some context…
Maybe it’s just me… but I’ve no idea what you’re suggesting :innocent:
Screenshots would be helpful
Amazingly, plexamp does support the material you theming, but the main plex app doesn’t…
As an example of other apps that support it.
Thanks for clarifying… there used to be a suggestion discussing that option. I’ve just noticed this was automatically closed (this can happen if suggestions were created in a different category). I’ll reopen that threaded it still has a number of vote, closing this one instead)s. I suggest you comment/vote there in order to help us avoid distracting or cannibalizing votes.
