Android TV requests unnecessary transcoding
@rcrocket said:
@danjames92 said:
@rcrocket said:
@danjames92 said:
@prittstick said:
@danjames92 said:
@prittstick said:
@jmuffat said:
@KarlDag : I am not sure I understand the question.
On the TV, Plex is setup so quality is set to “original” for both local and remote sources, if that’s what you’re talking about.
It depends on how you encoded your files, what container their in etc. Here’s a preset of mine I use for both DVD and Blu-ray rips straight out of MakeMKV, it’s a Handbreak preset. This allows for smooth continuous playback while producing good quality files with minimal file sizes. - filedropper.com/720pdirectplay-plex try this if you want and let us know how it works for you.
The default presets work fine…
Yeah 1920x1080 is totally okay for people with limited storage… and many other settings are not fine, and do need changing for some devices no matter what preset you have. So you were saying?
1080p is a resolution, not a file size. There are multiple presets available for smaller sizes already in Handbrake…
Whatever, man. I prefer to use custom settings, we’re not all the same.
No you are a special snowflake. :wink:
Insults aside. You tried to convince me multiple times that default presets are good enough, and I will agree with you. However… I add filters, custom subtitles, audio tracks etc and tend to crop certain media, in return, becomes a custom preset. Having said that, default presets work for most people, like yourself. :slight_smile:
It’s a joke not an insult, insert South Park’s Mr Garrisons voice here “relax geeees”. :slight_smile:
If it was joke, then my apologies. However, it looked like an insult to me. But, I’ve had worse, so relax. :slight_smile:
