I had created a new folder so there were a 70 items in it. It found the first 4. I also had it scanning ever hour, which Im sure didnt help. I changed it to 12 hour scaniing but have tried every couple of hours to do one manaully, and Im having issues.
2012-05-22 12:42:31,316 (-4b77a490) : DEBUG (runtime:729) - Response: 200<br />
2012-05-22 12:44:49,451 (-4b77a490) : DEBUG (runtime:568) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M1Ck1vdmllczEwCm1lZGlhX3R5cGViMXM2Cm1hbnVhbHIxCnM2Cmt3YXJnczYKczE2CjY5MzM0MTRkNDA4OTFhYzBzMTcKb3BlblN1YnRpdGxlc0hhc2hzMTIKQm9vYmFsaWNpb3VzczQKbmFtZXMxMDAKJTJGbW50JTJGdXNlciUyRlZpZGVvcyUyRkFkdWx0JTJGSGVudGFpJTJGQm9vYmFsaWNpb3VzJTJGTWlsayUyMEp1bmtpZSUyMCUyMFNoaW1haSUyMEhlbiUyRWNkMSUyRWF2aXM4CmZpbGVuYW1lczQwCjlhYjA2NmQwZDMyN2UzZTBhZmRiZWY0MGQyNGI4NTdjZmFmMDBkODZzOApwbGV4SGFzaHM3CjM2MjEwMDBzOApkdXJhdGlvbnM2CjQzMTY5MXMyCmlkcjAK<br />
2012-05-22 12:44:49,452 (-4b77a490) : INFO (agentkit:839) - Searching for matches for {'openSubtitlesHash': '6933414d40891ac0', 'name': 'Boobalicious', 'filename': '%2Fmnt%2Fuser%2FVideos%2FAdult%2FHentai%2FBoobalicious%2FMilk%20Junkie%20%20Shimai%20Hen%2Ecd1%2Eavi', 'plexHash': '9ab066d0d327e3e0afdbef40d24b857cfaf00d86', 'duration': '3621000', 'id': '431691'}<br />
2012-05-22 12:44:49,452 (-4b77a490) : DEBUG (networking:153) - Requesting 'http://127.0.0.1:32400/library/metadata/431691/tree'<br />
2012-05-22 12:44:53,605 (-4bd88490) : DEBUG (runtime:568) - Handling request GET /:/plugins/com.plexapp.agents.anidb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo0CnMyCmVuczQKbGFuZ3M1Ck1vdmllczEwCm1lZGlhX3R5cGViMXM2Cm1hbnVhbHIxCnM2Cmt3YXJnczIKczEyCkJvb2JhbGljaW91c3M0Cm5hbWVzNgo0MzE2OTFzMgppZHIwCg__<br />
2012-05-22 12:44:53,605 (-4bd88490) : INFO (agentkit:839) - Searching for matches for {'name': 'Boobalicious', 'id': '431691'}<br />
2012-05-22 12:44:53,606 (-4bd88490) : DEBUG (networking:153) - Requesting 'http://127.0.0.1:32400/library/metadata/431691/tree'<br />
2012-05-22 12:45:29,523 (-4b77a490) : INFO (__init__:29) - Auth exception msg: Command has timed out<br />
2012-05-22 12:45:29,524 (-4b77a490) : INFO (__init__:138) - Trying to lookup /mnt/user/Videos/Adult/Hentai/Boobalicious/Milk Junkie Shimai Hen.cd1.avi by file on anidb<br />
2012-05-22 12:45:33,194 (-4b77a490) : INFO (__init__:141) - Could not load file data, msg: You must be authed to execute commands besides AUTH and PING<br />
2012-05-22 12:45:33,195 (-4b77a490) : INFO (__init__:148) - Trying to lookup Boobalicious by name on anidb<br />
2012-05-22 12:45:33,195 (-4b77a490) : INFO (__init__:151) - Could not load anime data, msg: You must be authed to execute commands besides AUTH and PING<br />
2012-05-22 12:45:33,196 (-4b77a490) : CRITICAL (agentkit:855) - Exception in the search function of agent named 'AniDB', called with keyword arguments {'openSubtitlesHash': '6933414d40891ac0', 'name': 'Boobalicious', 'filename': '%2Fmnt%2Fuser%2FVideos%2FAdult%2FHentai%2FBoobalicious%2FMilk%20Junkie%20%20Shimai%20Hen%2Ecd1%2Eavi', 'plexHash': '9ab066d0d327e3e0afdbef40d24b857cfaf00d86', 'duration': '3621000', 'id': '431691'} (most recent call last):<br />
File "/mnt/cache/data/plex/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/agentkit.py", line 848, in _search<br />
agent.search(results, media, lang)<br />
File "/mnt/cache/data/plex/Application Support/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/__init__.py", line 180, in search<br />
self.doSearch(results, media, lang)<br />
File "/mnt/cache/data/plex/Application Support/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/__init__.py", line 153, in doSearch<br />
self.disconnect(connection)<br />
File "/mnt/cache/data/plex/Application Support/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/__init__.py", line 34, in disconnect<br />
connection.stop()<br />
File "/mnt/cache/data/plex/Application Support/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/adba.py", line 71, in stop<br />
self.logout(cutConnection=True)<br />
File "/mnt/cache/data/plex/Application Support/Plex Media Server/Plug-ins/AniDB.bundle/Contents/Code/adba.py", line 208, in
