Is there any way to see the address of the IP that is connecting to Plex?
Plex Server is running on a windows platform.
I am doing some troubleshooting and need to diagnose but need to see the ip addresses.
I have Plex Pass if that matters
Do you mean the IPs of Plex clients or all machines which (try to) connect to your server?
The former you can see live in the Plex Web App in the Dashboard section.
Tautulli provides a history of playbacks and the player IPs.
For anything else, you need to enable “debug” logging and then inspect the server logs after the fact.
Yes basically any connection that plays from my plex server. I will install Tautulli, sounds like a great plugin.
Cheers.
