Now we just need to generate ad markers for PLEX ON DEMAND and LIVE TV
Is there an estimated time frame? None of the my existing videos have commercial markers.
Also, what is the best setup if we donāt want to have ads detected for certain recordings? Should the DVR settings be set to āDetect ads and mark for skipā as the default and change it to disabled for recordings we donāt want detected? I know thereās a bug in the UI where it always defaults to DVR default regardless if itās changed on a per recording basis.
I love this new feature
Itās great to have a non destructive way to skip commercials.
Theyāre handled in a completely different way, and ads cannot be skipped on that content.
I know, I was being facetious
Not really, it depends on your library size and how beefy your server is. It happens during scheduled maintenance. If for certain recordings, then you can disable it at the recording level, like you suggested. However, if you then add that to a library that does detect ads, Iām guessing itāll probably still detect it, just not immediately
Needed more winky faces
Thank you for the info.
I am wondering if anyone in this thread is using a custom comskip file? I am, and could not get 1 of the 3 test shows to populate any markers.
Iām using a custom comskip.ini in a DVR folder in the Plex data directory. Itās working fine after a recording finishes. I can see itās using the custom ini in the logs.
Itās only been working right after a recording completes. It hasnāt created any commercial markers for existing content.
Iām on 1.20 + but In DVR Settings I only see Detect and Delete Commercials or Disabled as my two options. Yes, I previously used the delete option. But what can I do Now to get the Detect and mark for skip Option?
I had to stop and restart the server before I could see the commercial skip option.
You probably need to restart your server and client apps.
Restarting the PMS Got the option to appear, Thanks!
Iām excited to test this. Iām so glad to see Plex is looking to improve this feature. Iāve tried the competitionās mark to skip and mark and delete Feature, and itās very elegant.
My first impressions are that this feature has a lot of potential. the skip ad button is appearing about 2 seconds late, and returns me to the last second or so of the last ad. It also has completely chopped off the end tag (the last tv segment after the last series of ads) on a couple shows Iāve tested.
Itād be nice to see the markings of the ads on the FF tracking line, and to be able to choose if I want Plex to automatically skip.
This is just the first step
Detect ads and mark skip doesnāt appear to be working for non DVRād shows. Only shows recorded in Plex are working. Iāve waited for the overnight scheduled tasks to complete but still not working for manually added shows.
Please make sure you have that preference enabled for your library. It can take a while to run through everything.
I do have the preference checked for the show library and I donāt see a detect ads option in the main server Library settings like Skip Intro.
I created a new library and added one show to test. But commercial detection doesnāt run on shows added manually. Shows recorded from the DVR works great. All recorded shows had skip commercial markers.
Itās under Manage Library -> Edit -> Advanced
