First, Save the configuration in Control Panel - Backup & Restore
Next, follow the procedure above, beginning at step 3 (Mode 2)
3. Mode 2: Reset Synology NAS and re-install the operating system DSM
Be careful to hold the reset button long enough to hear the 3rd beep finish normally.
DO NOT HOLD LONGER
Follow the procedure and after DSM is re-installed, Re-install your applications, including Plex.
You will be pleased to find your Plex data is there waiting for you.
Hi, I have a Synology DS218play and have installed your PLEX SERVER arm8 Alpha package. For what is concerning playing movies everything is working smoothly so far. However I have problems in playing my music library. It has worked for a few songs through my IOS client and then suddendly stopped.
Now, regardless I have tried to play the musing from the FIRE TV Stick client or from the IOS⦠it simply does not work.
yes, the plex server on DS218play works very well with fire stick streaming movies.
I can stream movies on my iPhone as well.
music streaming is not working on both clients
Hi. I want to try the Plex beta on the Synology DS218. I follow both " ARMv8 platform alpha testing - Synology and QNAP" and āARMv8 platform alpha testing - Discussion & Troubleshootingā. I have downloaded the āPlexMediaServer-1.13.6.176-dd1845234-aarch64.spkā file, but when I try to install manually on my Nas trought the manual installation present on the packages center, it says me āoperation failedā. Iām wrong? Do I have to do another procedure to install it? Thanks for now.
