Not yet, but many thanks.
I’ll check it ASAP.
I’ll check it ASAP.
Please forgive my not understanding?
Running PMS on a Macbook streaming to an Xbox? I believe you’re in the wrong thread?
yes?
DS118 scannig library works perfect! auto-scan, scan after 1-2 (and other time) too works, no craches.
Meta downloads automaticly, no crash.
I’m got a transcoding error earlier today trying to record live TV from HDHomeRun Extend:
Transcoding Error: DS218play, 1080p H.264 .
It happened on a recording from 3pm-4pm and never saved the actual media file. It would show as trying to record in Plex, but then put up a triangle and give an error. The error logs are attached.
Note: this could be because the TV signal was weak. That station I was trying to record is notoriously spotty.
Also, I successfully recorded and played back a 1080p H.264 program sometime later from a different channel.
@buff_colchagoff_nitorgroup_com
That is a PMS error and not ARMv8 specific but working with my team member, this has been reported to Engineering.
From what your logs show, PMS wasn’t able to tune the channel. It might be weak signal, it might be a resource conflict, or might just be a genuine bug (not so likely) because you were able to tune channel 26.1 successfully.
Is this something that I need to re-download or update? I tried again on my Apple TV and the same message (couldn’t create the playback session for this item) was displayed.
Please let me know.
Thanks,
Jason
Jason,
I’ve got the update here (literally on my workstation).
I’m waiting for the codecs to be deployed so all of you can have access to it.
As soon as I can verify it plays:
)Where do you see this message? On the Apple TV it Plex side?
The Plex AppleTV app reports that it cannot create a playback session.
That’s weird, for me it just won’t play, I click on the play button and nothing happens - no error message at all.
Any ETA for the release of an Apple TV supported version?
It’s through Plex when I attempt to start a movie. It “thinks” for a minute and then displays the message.
Either way, as soon as I get codecs, we all get a BIG update
Codecs deployed. Please see the other topic for the updated download links
You will see:
Have a great weekend and Enjoy!
the download link requires username/password. any idea?
Sorry, Let me go adjust that.
Try that now please. I had accidentally included :443 in the URL
You guys are amazing, this is worth the lifetime Plex Pass on it’s own!
Is here anything in particular which needs testing?
Please go read the companion topic (where the download links are).
In there, you’ll see what’s known working and profiled.
The more we can test & profile, the better. It will give me the clearest possible picture of what I can safely enable in the final release
Ok… I think I’ve fixed the URL for everyone. (Can you tell I don’t do much work with the global deployment system?
Seems everything I could test has been covered. How is migration between windows and Synology, anything I could test here?
