Audio Stops When Doing Certain Things
Server Version#: 1.15.8.1198
Player Version#: 3.104.2
I open up plex and can play a currently playing episode (as in, episode that was already selected when plex starts up) fine. But when I go to a new episode (tested by simply hitting the next episode/skip button in the plex player at the bottom while watching an episode and by backing out and selecting a different episode), plex stops producing any audio. The different episode I’m watching won’t have audio. Other episodes won’t either. The previous episode I was just watching will not. I can “circumvent” the issue by hitting next episode and then restarting plex.
Is anybody else having this issue? Or can you check, if possible?
EDIT: This issue seems to also happen when I change the audio stream or quality during an episode. I changed it when the episode had already “started” and wasn’t “pre-buffering” and it happened. When I first open plex, while it’s still “pre-buffering” the episode, I can change episodes, quality, audio stream and whatever else and audio will play just fine if it’s all done before an episode actually starts playing.
