Automatic installation for plugins
It will be great if possible to add plugin into Plex server in automatic way, like is done with spiceworks.
Codes can be inserched directly or build in forum, just click over install button and done… plugin is there where to be.
thx
Plugins have been deprecated for ~4 years. Can you give an example of what this would accomplish?
It seems unlikely that you’re referring to Rockwell Automation. :slight_smile:
