Server Version#: 1.13.8.5395
Player Version#: ?
I am using Manjaro Linux(KDE) which is Arch Linux based. When I reboot I check the status of plex using systemd, and here is the output:
Oct 11 17:59:28 xplorer4x4-manjaro systemd[1]: /etc/systemd/system/plexmediaserver.service.d/override.conf:11: Failed to parse mode value, ignoring: 0027 # this >
…skipping…
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/usr/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/plexmediaserver.service.d
└─override.conf
Active: active (running) since Thu 2018-10-11 13:17:56 CDT; 4h 42min ago
Main PID: 462 (Plex Media Serv)
Tasks: 4 (limit: 4915)
Memory: 1.9M
CGroup: /system.slice/plexmediaserver.service
└─462 /opt/plexmediaserver/Plex Media Server
If I run “sudo systemctl restart plexmediaserver.service” it restarts Plex and I can connect from my TV, connect to the WebUI, Android Player,etc. Here is the status after restarting:
└─override.conf
Active: active (running) since Thu 2018-10-11 18:00:14 CDT; 13min ago
Main PID: 22954 (Plex Media Serv)
Tasks: 98 (limit: 4915)
Memory: 269.9M
├─22954 /opt/plexmediaserver/Plex Media Server
├─22976 Plex Plug-in [com.plexapp.system] /opt/plexmediaserver/Resources/Plug-ins-10d48da0d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstr>
├─23023 /opt/plexmediaserver/Plex Tuner Service /opt/plexmediaserver/Resources/Tuner/Private /opt/plexmediaserver/Resources/Tuner/Shared 1.13.8.5395-10d4>
├─23049 Plex Plug-in [com.plexapp.plugins.WebTools] /opt/plexmediaserver/Resources/Plug-ins-10d48da0d/Framework.bundle/Contents/Resources/Versions/2/Pyth>
├─23113 Plex Plug-in [com.plexapp.agents.imdb] /opt/plexmediaserver/Resources/Plug-ins-10d48da0d/Framework.bundle/Contents/Resources/Versions/2/Python/bo>
├─23390 Plex Plug-in [com.plexapp.agents.none] /opt/plexmediaserver/Resources/Plug-ins-10d48da0d/Framework.bundle/Contents/Resources/Versions/2/Python/bo>
└─23419 Plex Plug-in [com.plexapp.agents.localmedia] /opt/plexmediaserver/Resources/Plug-ins-10d48da0d/Framework.bundle/Contents/Resources/Versions/2/Pyt>Oct 11 18:00:14 xplorer4x4-manjaro systemd[1]: Started Plex Media Server.
How can I fix this so that when Plex starts after booting, it works without restarting plex?
