Backups failing to rename/purge
Server Version#: 1.32.5.7349
Player Version#: N/A
Hello,
I noticed today that for some reason my PMS was consuming a massive amount of diskspace with only PMS installed an media on network shares (295gb of 300gb), so I started digging and saw that the backups are not getting purged. I have plex setup to backup to a network share and that seems to be working fine, only the 4 most recent backups of blobs and the db each 3 days apart but in the Plug-in Support folder I have over a years worth of com.plexapp.plugins.library.blobs.db-[date]-tmp and com.plexapp.plugins.library.db-[date]-tmp sitting there. I pulled the logs to see what was up and I can see that there is an error trying to rename the files which is likely breaking the cleanup. The permissions on the files and folder are all correct for the plex user. Any ideas?
Ubuntu server 22.04.2 LTS
Backup log.txt (23.0 KB)
